08-07-2015, 03:31 PM | #251 |
GEARHEAD
Re: Project Madera: A Jimmy GT
So why not just use a grab handle for the E-brake?
BTW, it's August. Have a chassis yet?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
08-07-2015, 09:12 PM | #252 |
I'd stick with a manual brake, hand or foot operated. Unless you're some drifter or something I don't think it's purpose would be for "dynamic" use. If you're away from the house and had a differential failure, u-joint failure or something like that you'll want one that works.
I had an '07 GTI and never used the hand brake. When wifey parked it in the winter she'd yard on the handle and it'd always be frozen ON in the morning (moisture in the cables). Her '09 Tiguan has an electric park brake that operates all on it's own, every time. It also has a selectable feature where it sets when you come to a stop in gear. You can let your foot off the brake, then it automatically releases when you push on the gas pedal. My '12 Silverado has a similar feature (not selectable) where the brake comes on if your rolling backwards in drive. It holds you in place if your stopped, facing uphill. The electric actuator kind of falls in line with the rest of your tech, but unless you're going to automate it, I'd keep this one simple and reliable. $0.02
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
08-10-2015, 03:56 PM | #253 | |
And in answer to your 2nd question, um nope. |
08-10-2015, 04:27 PM | #254 |
maibe just use a line lock system on the rearbrakes
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
08-11-2015, 01:47 AM | #255 |
Collector of Projects
I had originally grabbed a brake lever out of an early 2000 Range Rover. Well built with a nice handle and leather boot. My problem is the mounting location. I kept changing my center console design, and may end up going with e-stopp so I can just have a button on the dash... They did have something in the works with UPS so that the brake automatically sets when you put the vehicle in park...
I also always use the e-brake even with an automatic. I would rather have the have the pressure of the car (on an incline) on the brake, rather then the parking pawl in the automatic transmission. |
08-11-2015, 11:24 AM | #256 |
A guy with a truck
What's the latest from PB?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-27-2015, 03:59 PM | #257 |
I've made some pretty wordy posts in this thread but a picture's worth a thousand words, so here's a couple grand worth:
08-27-2015, 04:08 PM | #258 |
...and with the top:
08-27-2015, 07:27 PM | #259 |
Looks awesome! If you can pull it off it'll be one of a kind in so many ways.
08-27-2015, 07:57 PM | #260 |
Nice renders :P
08-28-2015, 06:24 PM | #261 |
09-11-2015, 08:33 PM | #262 | |
EDIT: hellaflush3d, i assume. Great work.
▀▄▀▄▀▄ __www.c10crew.com__ ▄▀▄▀▄▀ ▀▄▀▄▀▄ C10CREW on Instagram ▄▀▄▀▄▀ ▀▄▀▄▀▄ The 1971 Blazer Project ▄▀▄▀▄▀ |
09-12-2015, 02:36 PM | #263 | |
09-14-2015, 10:50 PM | #264 |
What a great build! Really fun to watch.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
09-27-2015, 06:38 PM | #265 |
09-27-2015, 06:54 PM | #266 |
I'm looking for an opinion here, a lot of the '60s-70s convertibles had the windshield frame clad in stainless trim, I'm considering the idea of going with that look by nickel plating the frame, the vent window door supports, and of course the vent window frames. Here is 2 renders I had Chad the render master do, the original with the blacked out windshield/vent trim and one with those pieces plated (as well as the mirrors and wiper arms). Which do you guys like better?
Blacked Out: Nickel Plated: |
09-27-2015, 07:12 PM | #267 |
I get the cleanliness of the concept, and it'd be cool as hell but I like the look of the black frame better.
09-27-2015, 07:39 PM | #268 |
might look better if you slant the sides inwarth a bit
will give you problems fitting the side windows unless you dont make them roll down but more of a canvas pull out style
09-27-2015, 07:57 PM | #269 | |
hmm, probably a bridge too far, I like the idea and I have thought about laying down the windshield a bit as well, but all this screws with the vent windows, the fitment of the top, etc, etc. I am building this to be a daily driver, and even though I plan on modifying virtually every panel, it's still something that could be repaired if it ever needed to be without huge effort. |
09-27-2015, 08:24 PM | #270 |
I vote black.
03-29-2016, 04:27 PM | #271 |
Whats the latest?
Ryan... 1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain http://67-72chevytrucks.com/vboard/s...11#post5532411 |
03-29-2016, 04:41 PM | #272 |
kindah interested too , aspecially at how far you gotten with the engine
been looking intoo some problems of my own with the jaguar inline 6 the engine is normally mounted at a 21 degree slant and i want it straight up in the truck problem is the automatic trans , could make an adapterplate rotating the mountingholes or make a new engineplate where the trans mount too doing the same thing but the starter cant be moved and i have doubts it will clear the bellhousing if the divit for it has rotated 21 degrees away from the starters nose might need to cut a hole for it in the side to get everything to play nice again , i wish the bellhousing was bolted to the trans but it isnt unfortunately
04-16-2017, 02:58 AM | #273 |
Anything new on this build?? Been about year now,. Curious to know how things with PB played out
72 GMC Suburban (dads) 69 SWB Chev (frame off father/son) 70 2wd Jimmy+69 4WD Blazer = PHASED 71 SWB stuffed in the barn |
05-28-2017, 12:05 PM | #274 |
Yea, I'm getting ready to do the same 4.2L vortec and 4L80E swap into my C50. Probably going to buy the pre- machined pump face and adapter ring and cut the bell off myself.
Any progress?
1967 Chevy C50. Vortec 4200. 4L80E. |
