Old 11-16-2009, 12:44 AM   #326
Frizzle Fry
Frizzle Fry's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
yeah. I'm going to adapt the rsx gauges to fit this panel
Frizzle Fry is offline   Reply With Quote
Old 11-17-2009, 12:25 AM   #327
Sub-versive
Boss Hogg
Sub-versive's Avatar
*****in !
Can't wait to see more!
Sub-versive is offline   Reply With Quote
Old 11-17-2009, 03:00 AM   #328
Frizzle Fry
Some REAL pics of REAL work
The steering column/firewall pass-through I'm working on. The tubing ID matches the column OD:
The S2000 R&P mocked into place to determine tie-rod placement:
Built a jig to allow me to duplicate factory tie-rod geometry when I install the new rack:
Rack removed:
Old 11-17-2009, 03:13 AM   #329
Frizzle Fry
With the tie-rod removed from the rack, I added another reference bracket to the inner ball joint (a 4-link bracket I had on a shelf):
Here's the Triumph rack. I've fitted some bolts in place of the tie rods:
The S2000 shaft, and joints are on for a test fit. I may use them.
Just a very rough placement of the TR7/8 rack to show the offset between the rack output and the factory S2000 tie rod location. For those who didn't read the whole thread; the crank pulley is to far forward thus the rack must move forward. With a little inventiveness I should be able to retain proper tie-rod positioning while gaining the needed engine clearance. More to come on that:
Old 11-17-2009, 08:28 AM   #330
my67chevytruck
Under Construction
my67chevytruck's Avatar
Looking good Mike!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-18-2009, 02:11 AM   #331
Frizzle Fry
I welded in the column passthru today. Stitched up the DS inner fender too. Started reinforcing the PS frame rail. But what took the most time was figuring out what tie-rod arrangement to go with. I got to know two very thick MOOG catalogs quite well today (thanks again Vern). So more parts are heading this way
Old 11-20-2009, 11:16 PM   #332
Frizzle Fry
One of the side projects that's been holding up progress on the Minx is my "Mini Shop." It's about a 10x15 (if that) building that had been left unused for about ten years. After cleaning it out and fixing a broken window I decided to move in It's a perfect place for the tube bender, air compressor, Blasting cabinet, and powder coating oven.
So I rented a trencher and buried some 3/4" pex and 10ga 3 core wire to run 220 out there. The pex and all the push-lock fitting are awesome for this. Here's what I've done so far. Now back to the car!
(just some bad cell phone pics):
Old 11-20-2009, 11:45 PM   #333
BlueJeep
BlueJeep's Avatar
What size compressor is that? I'm assuming you did your research first, but that 10ga seems a little light. A buddy burned up the motor on his compressor powering it with 10ga. wire. Seems like the IR book for mine said 6ga...so that's what I ran on a dedicated circuit for it (7.5hp).
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 11-21-2009, 12:36 AM   #334
Sub-versive
Boss Hogg
Personally I'd #4AWG or #6awg copper, with the compressor and oven.
Just thought I should mention also, it should be 4-wire for a subpanel.
Old 11-21-2009, 12:41 AM   #335
Frizzle Fry
You know, now that you mention it I think I went with 8 gauge copper. I'll have to check again. I remember seeing that it was good for 40A. Yes it is 4-wire and I installed a sub panel. In fact I installed a ground rod too. The compressor draws a max of 21A (5hp).
Old 11-21-2009, 12:53 AM   #336
Sub-versive
Boss Hogg
Awesome. I saw the panel to the left of the blast cabinet in the photos. And an oven should be less than 40A. I would run either a 30A or 40A circuit to most wall ovens(not ranges-those are 50A). So as long as they are not on together you should fine.
Old 11-21-2009, 02:51 PM   #337
ERASER5
ERASER5's Avatar
Just my .02, but I would lift the stove top and unplug the top burners.
An ounce of prevention ya know. Maybe you already have. It is hard to see under the table.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 11-21-2009, 07:11 PM   #338
Frizzle Fry
Burners are removed. Kids love to turn knobs. Thanks for lookin out guys
Old 11-22-2009, 11:19 AM   #339
dammitmitchell
the pollock
dammitmitchell's Avatar
YOU make me feel small inside....
ha ha ha
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 12-01-2009, 10:35 PM   #340
Jvsapp
Jvsapp's Avatar
Originally Posted by Frizzle Fry View Post
lookin good FF. wanted to ask what the PEX is? is it that white line from your water trap? how much is is per foot in your neck of the woods? what PSI can it handle? looks flexible and something i might be looking at for my shop. i like your copper "cooling loop". i have soldered a whole bunch of copper tubing up to make a radiator to the same effect for my compressor. just wish that when i bought mine, the newer model was out. same price, 15 gallons more. oh well cant' win them all.
Jvsapp is offline   Reply With Quote
Old 12-02-2009, 02:54 AM   #341
Frizzle Fry
Yes, it is that white line after the water trap. I kept that service loop since that's the buried line. Here's a link to some info on PEX.
It is generally used for water plumbing and radiant floor heating. But it can be used for low pressure air as well. The 3/4" tube I used is spec'ed out for 160psi at 70* and gets lower as temp increases. I'm regulated down to 90psi right off the tank so I'll never come close to 160.
Can't remember the exact price but I think it's around 40-50 cents a foot in 3/4". The fittings aren't cheap either but the install was so fast and easy, not to mention expandable, flexible, easy to work with; it is well worth the money IMHO.
Old 12-02-2009, 04:26 AM   #342
Jvsapp
Jvsapp's Avatar
thanks for the info on the PEX. better alternative to what i was planning to use.
man FF, the more i look at your shop and mini shop, you really got a good deal on that property. i'm wondering if you have a barn stashed on the other end of the property. wish i could score a place like that. sweet...
Old 12-03-2009, 12:30 AM   #343
Frizzle Fry
Yeah, I know it was quite a score. Right place at the right time for once The house needs a remodel and you know I have some ambitious plans there, but it's very livable as-is for now. It's also 2.5 miles from the largest employer in town (Intel, where I work), and even closer to Costco (but not too close). Yet it feels like a very rural property.
No barn ...and no garage to park the drivers in. It does have a big carport that the 64 lives under. That will become a garage in time though
Off to the shop!!!
Old 12-03-2009, 12:38 AM   #344
Jvsapp
Jvsapp's Avatar
dang you work for intel? had i stayed @ devry i'd probably have wound up there too. but your shop and mini shop would be an instant buy for any gearhead. the wife can have the house, i'd take the shop and mini shop and be willing to do any repairs to make the house work for her
my old man setup my moms place pretty good before he passed. the garage is 25X60 and i also have a 10X30 corrugated galvanized shop in the back yard. my blast cabinet and compressor are back there with the oven. i thank him for that, but i just gotta convince the mom to let me keep my toys there and bring more back. hopefully one day that place will be mine. hmm thinking of that i should post pics of my shop.... maybe we should start up a post your shop thread? or is there one already?
anyways back on subject. where's the updates of the minx
Old 12-04-2009, 01:47 AM   #345
Sub-versive
Boss Hogg
Updates?
Old 12-04-2009, 05:50 AM   #346
Frizzle Fry
I was waiting to have a bit more done but at the rate I've been working lately I might as well...
First of all this is required before any work begins these days:
and here's the column passthru (will clean up):
Boxing the frame rail in. This outer piece sits on the frame rail's lower edge (rail has a lip that extends out). Because of that lip it does not sit against the upper edge of the rail. This was the solution:
Inner plate template:
and in metal:
Top Plate:
and more templates to fill all those gaps:
That's it for now. Believe it or not; those templates can take some time to make. But the better they are, the less work required to make the real thing fit. Plus I should be able to use them again on the other side.
Old 12-04-2009, 11:19 AM   #347
BlueJeep
BlueJeep's Avatar
Frizzle, since all your projects seem to be grafting all sorts of sheetmetal together in different configurations, how do you address the metal shrinking at and around the weld? Do you hammer them out to try to flatten them, or what advice can you give? Last weekend I experimented with grinding my welds down with the edge of a .045 cutoff wheel, and then finishing them out with a flap disc and noticed that using the edge of the cutoff wheel resulted in significantly less heat than a grinding wheel, in fact by the time I put the grinder down I could touch the area I just ground...but I still noticed the metal shrinking some.
I was splicing 2 bed floors together, so the shrinking really doesn't matter much...but here is where I'd like to learn before moving on to exterior panels.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-04-2009, 02:42 PM   #348
woodwright
Enjoying left field
woodwright's Avatar
I'm wondering about this too. I've had alot of trouble with this. I've used my flux-core mig, and my tig and seem to have the same problem.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 12-04-2009, 04:23 PM   #349
Frizzle Fry
I don't seem to get shrinkage from grinding. Maybe I use less pressure. I have been taking the welds down to near-surface level with a grinding wheel, then hitting them with the flap disc, then 80 grit DA.
The key to avoiding warpage starts with the weld itself. On thin stuff I tac-tac-tac, jumping around to avoid too much heat in one area. It ends up looking like the steering column pass-through pic in my previous post before grinding. Not the prettiest to look at but it all gets ground smooth anyway.
Old 12-04-2009, 04:28 PM   #350
Jvsapp
Jvsapp's Avatar
i've used roloc disc to gently take the metal away when i do some grinding. i've used the cut off wheel technique too, but flap or grinder to knock most of it down, then i use roloc red or brown to smooth it out. i've really been pleased with how it comes out.
