#326 | |
Re: Dug's 1959 Fleetside
Bro-in-law Bruce sent me a period correct California black on yellow license plate the other day so the truck can enjoy a bit of its' heritage. Tossed in a handful of vintage Hot August Nights (Reno) medallions as well. Also, included a picture of the dead Trailblazer SS with 6.0 LS that will be donating its' drive train to someone's new project.
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
#327 |
That TB was the recipient of a serious T-Bone! I'm sure you thought about it, but why don't you get the fuel lines from the TB SS for your truck. It would save a lot of time.
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod |
#328 |
Man, good thing one of us is thinking. This is now on the TB SS "To Do" list. Thanks. dug
#329 |
I'm sure what ever you do will turn out to be real nice on the bed.
Are you sure that TB/SS is only a 6.0. I got my LS out of an 07 TB/SS and it's a 6.2. Kim |
#330 |
I posted this on another build, but thought you may be interested in side mirrors. I have been looking at mirrors for the last several weeks to find an electric set that would look good on the truck - after stretching my body to adjust the mirrors on the GTO, the truck's had to be electric. I have seen Honda and Lexus models that have mirrors that appear to work (bolted to the door skin from below), then I saw tbrown5079 - "56 Cameo Build" build with some side Mirrors from a 944 Porsche. See his post 94 and 103. The installation sure looks slick. The 944 mirrors can be had for about $150.00. I also looked at an article about installing Porsche Teardrop mirrors from a Porsche 968 on a Porsche 944 - looks to be a direct swap between those two models, thus the 968 mirrors would work on your truck. Of course the 968 Mirrors are app $500.00 a pair! I'll try and help you spend your money - because you are a lot closer to needing side mirrors than me!!!
Ricky
#331 |
Just assumed it. 6.2 sounds even better. Cant wait to dive into it. Dug
#332 | |
#333 |
Took the front clip back off and leveled up the frame and started over. Turns out I had the small "L" bracket flipped where the inner fender is mounted to the cab. Threw everything off a bit.
Work included installing the hood which we tried to make hard. After deciding it fit satisfactorily, I proceeded to install the hood latch only to find that the little tab that holds the coil spring had broken off and was replaced by a nut and bolt....which interfered with the operation of the latch. After 45 minutes figuring this out and 5 minutes welding on a new tab, the latch operated like new much to my surprise. Note the penny I used to keep from welding the latch together. The penny is actually where the bolt head was that interfered with the operation. Discovered the old floor jack spring expansion technique on the internet while trying to decide if my new hood hinges were ok. Latch the spring onto the floor jack and spread it to the desired length. Fill the gaps with shims. Install the spring on hinge and when you close the hood, the shims supposed to fall out. In my case, we had to yank them out. What a time and life saver. Body gaps are way better than expected. Will tighten all body panel bolts tomorrow and attempt align the bed. Also installed the tailgate to square up the bed.
#334 |
...a few more shots. Tailgate and hood gaps.
#335 |
wow, that looks good. never seen that hood spring/door shim thing before. musta been a hotrodder who figured that out. more brains than bucks, ha ha.
I finally found a day and a half to work on my truck. trying to fab up a new cab extension panel for the pass side. I would snap a few pics except the wife has the camera, the tablet etc etc. could use my phone I guess. anyway, your truck is really coming along and I can't believe those gaps, way closer than my truck. keep at'er dennis |
#336 |
there are little rubber buttons that go on the fender against the hood, correct? are yours in?
#337 |
just a note, be careful doing that floor jack manoever, if it was me I'd probably end up with some black paint on my teeth somehow when the jack pad came off, ha ha
#338 |
No...nor are the rubber stops at the top of the hood. The ones across the front lip are in place. Will buy a fresh set before final alignment and install. May have to open the gaps a bit to fit that stuff.
#339 |
Shot of the truck with mufflers and bed. Running an errand in the neighborhood.
https://www.youtube.com/watch?v=aTsg...ature=youtu.be Video of the truck quietly idling and hood operation. Gotta watch your front teeth when opening the hood. It is well lubricated and opens quickly. https://www.youtube.com/watch?v=8Xay...ature=youtu.be
#340 |
Those aren't my hands....tricked Jim into loading the spring with shims. I'm just the camera guy.
#341 |
a quick way to install or remove the hood springs is to use a loop of rope a foot long
hook the loop on the spring end and pull, the end will come out with out scratching any paint reverse the procedure going in. one end in the hinge with a rope loop on the other end, pull back and have a second person push the end into the slot 30 seconds per side max in my prime i could install them by myself, not any more ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#342 |
just watched he youtube, then there was another one there with your son driving and no box or mufflers. I knew he was gonna try the burnout thing. I was just siting here watching and realized I had a smile from ear to ear. cool how that brings back memories from my early days when the neighbours watched me doing burnouts and stuff out front on the street. well, except for one old guy who only allowed a few test runs before the shotgun would appear, cradled across his arms as a warning as he stood at the end of his drive, ha ha. we still talk about him and if he woulda actually given a warning shot across the bow or just take out a rad or something.....
great to see your truck running, did you decide if you are going to lengthen the rear trailing arms or do some creative bodywork? wish my truck was as good condition as yours is. I am starting with a glove box door and working my way out, ha ha. just wondering if you plan on using the headrests on the seats or if they will hit the rear window. that is one reason I am extending the cab on mine. dennis |
#343 |
A320 Pilot/USAF Retired
Man, if your truck were mine I wouldn't think of painting it for a long time!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#344 |
The better it runs the less I want to take it back apart and paint it. Maybe I will reconsider the whole painting thing and slap a clear coat on. Next job is to move the rear wheel opening.
#345 | |
Will move the wheel opening rather than do the trailing arms. Need body work practice. Headrests will not hit the glass. To insure this, I probably need to move the brake and gas pedals closer to the floor and maybe even make the foot well deeper so I can move the seat up. The pedals are a bit unnaturally high. Don't really like the headrests but do like my neck. They are less obtrusive than some of the seats I have seen filling a big window. I can always store them when parked if I ever get it complete enough to do a cruise-in.
#346 | |
#347 |
Truck sure looks good all together.
Kim |
#348 |
![]() Join Date: Jul 2012
Dug the truck looks great!
#349 |
Got the front clip and cab leveled. Had to shim the front and back right corners about 3/16" and the front left core support about 5/16". Tightened all the sheet metal bolts which ultimately tightened up all the gaps..... maybe a bit too much. Still looks pretty straight. Re-hung the passenger door several hundred times and finally got it to a point that proves to me I can get it to a final position after several hundred more hangings. By the way, both doors are a different color than the cab so they did not come on the truck...not that they would have been any straighter. I will definitely be adding and subtracting door edge material to get the gaps right.
Was going to weld a stud onto the body line on both sides in the front and back so I could pull a string and establish the body alignment. Decided to utilize the existing holes in the fenders and bed sides instead. Used a bolt and bushing. Worked nicely. The only problem I am having is seeing the door. The body line in the door is not quite as crisp. Also, the bed is about 1/4" wider than cab (1/8" on each side). Jim pointed out that I can probably pull it in by loosening the bed front bolts and pulling the sides to towards the middle.
#350 |
Your truck looks so good with all the sheetmetal on it! And even better that it moves under its own power. Plates, taillights and a windshield and you could drive it without worrying that you were going to turn the corner and see the local police.
Now that you have the truck mostly assembled, what is the ground to rocker measurement at the front of the door?
