Old 07-04-2016, 12:27 AM   #326
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: 1961 Crew Max
Quick update. Got both inner rear tubs made and sorta mocked up for now. Cut the inner chevrolet panel out of a tailgate for the raised bed filler at the back tailgate. Then we made a fuel filler in the same panel. DIESEL FUEL ONLY. Thanks CHIZZLER. Happy 4th everyone.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 07-04-2016, 07:01 AM   #327
Re: 1961 Crew Max
Old 07-07-2016, 10:33 AM   #328
lower50's
lower50's's Avatar
Re: 1961 Crew Max
Nice are you putting a door over the cap?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 07-07-2016, 10:39 AM   #329
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
No fuel door. It will be hidden behind the tailgate.
61-crew cab D-max
Old 07-07-2016, 10:44 AM   #330
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: 1961 Crew Max
Good progress man I need to get me some more vise grips..
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 07-07-2016, 04:42 PM   #331
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1961 Crew Max
Very nice work! That fill tube is cheating in a way.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-08-2016, 11:35 PM   #332
namloc
namloc's Avatar
Re: 1961 Crew Max
Nice progress.Good thought out idea's.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 07-10-2016, 01:08 AM   #333
slammed427
slammed427's Avatar
Re: 1961 Crew Max
You're killing it Chizzler!
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 07-10-2016, 12:23 PM   #334
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Worked on the tailgate area yesterday. Went to my local junk yard and got some hardware from a couple tailgates to get some straps figured out. What we did was cut some 1 1/2" round bar and tapped them for spacers for the the top mounts. We then took the Bracket out of the tailgate that the chain would hold onto in the open position and re-tapped it for the new size that was bigger. Cables were purchased new and measure 21". We cut the flanges down on both sides of the tailgate. Next will be some sorta hidden latch in the tailgate. CHIZZLER
61-crew cab D-max
Old 07-10-2016, 09:40 PM   #335
Advanced Design
Advanced Design's Avatar
Re: 1961 Crew Max
That is a good idea. Truck is coming along really well Chizzler.
Advanced Design is offline   Reply With Quote
Old 07-10-2016, 11:40 PM   #336
lower50's
lower50's's Avatar
Re: 1961 Crew Max
Looks good! Are the cables universal or from a ___ truck?
1951 MG TD
Old 07-10-2016, 11:50 PM   #337
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
I just googled the length of cables I was looking for. It spit out 2000+furd.
61-crew cab D-max
Old 07-10-2016, 11:54 PM   #338
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Thanks doug.
Thanks.
I was lucky that my buddy had a fill tube with cap from a swap he did. Worked out well for me.
61-crew cab D-max
Old 07-13-2016, 10:10 PM   #339
youngrodder
youngrodder's Avatar
Re: 1961 Crew Max
looking Good Chizzler. I dig the gas hole..he he
I need figure out something similar for my Suburban...
Keep at it.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 07-17-2016, 11:09 PM   #340
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Little update. Had to fix the drivers side tail light panel. Cut a piece out of A donor and made it fit. Also noticed about 16" of bedside was separated at the pinch weld between the top and bottom area. Got my new Ridetech f9100 bags for the rear and looking at what's needed to make them fit. The firestone 9000's just didn't have the lift this truck needs. You can see the difference from the pic. We may consider putting A bridge on the rear end and triangulating the rear. Don't like how much the axle shifts over with the pan hard bar. Here is a pic I found of my truck photoshopped before I got it. Thanks CHISELER.
61-crew cab D-max
Old 07-18-2016, 06:37 PM   #341
Dieselwrencher
Re: 1961 Crew Max
Holly cow those are wicked air bags!
Ryan
Old 07-18-2016, 10:39 PM   #342
youngrodder
Re: 1961 Crew Max
Nice repair and yes, those bags should work...they look frickin huge.
Marc
Old 07-21-2016, 10:02 AM   #343
66ChevyMax
66ChevyMax's Avatar
Re: 1961 Crew Max
Those bags are sweet, loving this truck. Congrats on TOTM!!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 07-25-2016, 07:47 PM   #344
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: 1961 Crew Max
Congrats glad to see this thing getting done
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-26-2016, 07:04 AM   #345
lower50's
lower50's's Avatar
Re: 1961 Crew Max
Ya the new bags should work, with about 10" of travel should be lots.
1951 MG TD
Old 07-27-2016, 12:36 AM   #346
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 1961 Crew Max
ha! that photo chop was one I did when I was dreaming about getting a crew..if you look closely you can see that the top is chopped about 2 inches as well.
looks like I better get busy on mine and catch up with you!
lookin good!
Old 07-27-2016, 06:37 AM   #347
496 chevy
496 chevy's Avatar
Re: 1961 Crew Max
This is one sweet project man I love it and making memories with your son he will never forget. I see you are in sherwood. I live in longview so I hope to see this truck around sometime .
I am building a daily driver 65 right now and have a few others. Keep up the good work.
crew cab chevy cummins powered
496 chevy is offline   Reply With Quote
Old 07-27-2016, 08:18 PM   #348
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
lookin good!
I thought you might have something to do with that pic.
61-crew cab D-max
Old 07-27-2016, 08:23 PM   #349
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Thanks everyone for checking in. My work load has been crazy lately. Trying to get away for one day on the weekend is difficult. My business is really getting in the way of building this truck. LOL CHIZZLER.
61-crew cab D-max
Old 07-28-2016, 03:21 AM   #350
Grizz1963
Grizz1963's Avatar
Re: 1961 Crew Max
That is great news.
Looking good on progress.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
