Old 01-09-2018, 01:58 PM   #326
67cheby
67cheby
67cheby's Avatar
Re: "Elwood" the 77_remix
so are we getting close to the "good stuff"......just sayin! LOL
67cheby is offline   Reply With Quote
Old 01-10-2018, 11:26 AM   #327
N2TRUX
Happy to be here
N2TRUX's Avatar
Be patient, you got the sneak peek last night.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-10-2018, 11:29 AM   #328
N2TRUX
Happy to be here
N2TRUX's Avatar
With the HQ shocks in place I could hoist the brake assembly on to the bottom ball joint. The Wilwood calipers and rotors are lighter than stock, but that modular spindle is a solid piece. With the bottom bolt secured, I tilted the assembly in place and pulled the upper Strong Arm down to meet.
Articles-
"Refining Sierra"
Old 01-10-2018, 11:41 AM   #329
N2TRUX
Happy to be here
N2TRUX's Avatar
Now that the brake assembly was secured, I determined what fittings were needed to go from the 6 piston caliper to the braided stainless line. a quick trip to www.summitracing.com and my parts are on the way.
Until they arrive, I will continue to press forward. I removed the drag link assembly to prep and paint. While it was drying I started hanging the RideTech Muscle Bar. This new version is larger yet lighter due to tubing being used rather than bar stock. It came with bushing stand to improve end link angle as well.
Articles-
"Refining Sierra"
Old 01-10-2018, 11:49 AM   #330
N2TRUX
Happy to be here
N2TRUX's Avatar
The bushing stands use existing holes on the frame. Be sure to note the orientation of the bracket. It is possible to mount them backwards and not know it till the entire job is done. (So I'm told ) I find it easiest to hang everything and get the nuts slightly started before tightening anything down.
Articles-
"Refining Sierra"
Old 01-10-2018, 12:03 PM   #331
N2TRUX
Happy to be here
N2TRUX's Avatar
Once the end links are attached to the Muscle Bar they can be connected to the Strong Arms. I found it easier to tighten them first as the nut on the inside is hard to access if the angle is to extreme. With the end links tight, I moved on to the bushing bolts, and bushing stands. I ensure the the alignment was correct and tightened to specs.
Articles-
"Refining Sierra"
Old 01-10-2018, 03:22 PM   #332
aggie91
I'm just glad to be here!
aggie91's Avatar
You make this look easy...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-10-2018, 04:25 PM   #333
lolife99
67-72 parts collector,…
lolife99's Avatar
Ken,... do you see any advantage of the new MuscleBar design vs the old MuscleBar design?
Any insight from Ridetech?
Keith
Convert to disc brakes.
Old 01-10-2018, 07:18 PM   #334
67cheby
67cheby
67cheby's Avatar
Looking great!
Old 01-11-2018, 10:41 AM   #335
N2TRUX
Happy to be here
N2TRUX's Avatar
It cant be too hard if I'm making it look easy
Looking great!
Thanks Mike.
Keith I have been told that
Articles-
"Refining Sierra"
Old 01-11-2018, 11:39 AM   #336
JohnJ@RideTech
JohnJ@RideTech's Avatar
Glad you asked, we actually get this question pretty often.
The new bars are 1.25" in diameter and constructed out of .188" wall DOM tubing. These are slightly more rigid than the solid design and show significant weight savings over the older bar.
"Hollow" bars and their related components are now standard equipment in both C10 coilover and air suspension kits.
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 01-11-2018, 12:10 PM   #337
lolife99
lolife99's Avatar
Thanks for the answer.
I knew it had to be more than the shape of the end of the bar.
I also wondered if the frame bushings need to be mounted to the "stands" you provide,... or if they can be bolted directly to the frame like you had them?
Keith
Old 01-12-2018, 10:36 AM   #338
N2TRUX
Happy to be here
N2TRUX's Avatar
......I also wondered if the frame bushings need to be mounted to the "stands" you provide,... or if they can be bolted directly to the frame like you had them?
Keith thats the way I had the previous Muscle Bar mounted. I know this is a common method for mounting stock GM bars. Unfortunately it doesnt work as well on the RideTech Muscle bar. I had issues with excessive fatigue and failure on the end links with the bar mounted directly to the frame. The clamps stands were designed to resolve that issue.
Articles-
"Refining Sierra"
Old 01-12-2018, 01:03 PM   #339
N2TRUX
Happy to be here
N2TRUX's Avatar
I got the last pair of fittings needed to finish the Wilwood install yesterday. I put those on and adjusted the strain reliefs holding the stainless lines in place. This weekend I will install the Wilwood adjustable proportioning valve and the braking system should be complete.
Articles-
"Refining Sierra"
Old 01-13-2018, 10:31 AM   #340
aboesec10
aboesec10's Avatar
Love how detailed your threads are, I get out in the garage and start thrashing and then remember that i didn't take any pics....... My threads are start......done! lol
c10clubtexas
aboesec10 is offline   Reply With Quote
Old 01-13-2018, 03:03 PM   #341
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by aboesec10 View Post
Love how detailed your threads are, I get out in the garage and start thrashing and then remember that I didn't take any pics....... My threads are start......done! lol
I'm really anal about working in clutter. I usually take pics as I put up tools between rounds. Its just something you get used to.
Articles-
"Refining Sierra"
Old 01-14-2018, 11:49 AM   #342
N2TRUX
Happy to be here
N2TRUX's Avatar
Friday night I worked on my exhaust system again. I realized that I was not going to have time to take it to New Star and have it ran the way I did on Scarlett so I opted for plan "B".
The V bands that Kevin from Deeds Engineering sent would have to wait. Till then, I used parts off the previous system and added the new components. It's not what I wanted, but it gets the job done for now. I will add Deeds billet hangers to hold it in place.
Articles-
"Refining Sierra"
Old 01-14-2018, 11:00 PM   #343
gringoloco
A guy with a truck
gringoloco's Avatar
Looks pretty good to me!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-15-2018, 01:38 AM   #344
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks. I had hoped to run it out the back like I did on Scarlett. Unfortunately there's just not enough room. Eventually I will route it out the wheel well opening. For now, this will do.
Articles-
"Refining Sierra"
Old 01-15-2018, 11:45 AM   #345
blazer2007
Originally Posted by N2TRUX View Post
With the paint cured, I bolted the new upper shock mounts in place. If your not running these mounts on your lowered or bagged truck, you should be. There is no way a shorter shock has the same damping ability as a longer shock. By adding additional length you gain fluid capacity and travel.
The RideTech HQ shocks are adjustable so you can dial in your rebound and firmness preference. They have 24 positions to choose from. RideTech suggests starting in the middle and tune to your driving style.
I can,t find the upper shock mounts on the ridetech web page, all that comes up is a 3 sided box type
blazer2007 is offline   Reply With Quote
Old 01-15-2018, 12:00 PM   #346
N2TRUX
Happy to be here
N2TRUX's Avatar
I looked and couldn't locate them either. I sent a text to John so we should have an answer soon.
Articles-
"Refining Sierra"
Old 01-15-2018, 12:07 PM   #347
N2TRUX
Happy to be here
N2TRUX's Avatar
This weekend I focused on getting the wiring corrected on the RideTech system. I have an older version of the Big Red valves (ARV 7000) that was connected to a Ride Pro E3 management system. The Big Red valves have had some updates including changing from 4 two pin connectors to 2 four pin connectors.
I was able to get the system running using an adapter harness that was on my Ride Pro E3. Unfortunately it was too short to route inside so it had to be under the cab. I decided to clean things up and convert the valve harness to 4 pin connectors. I had the pin extractor tool and 4 pin connectors, but had to chase down new pins locally. Just so you know, Oriellys Auto Parts does carry them.
Articles-
"Refining Sierra"
Old 01-15-2018, 12:16 PM   #348
N2TRUX
Happy to be here
N2TRUX's Avatar
I was forced to tape rather than use loom, but they look so much better now. Everything is working correctly and I eliminated the jumper harness. Time to move on to the next item on the list.
Articles-
"Refining Sierra"
Old 01-15-2018, 02:02 PM   #349
JohnJ@RideTech
We sell the brackets with our shock relocation kit for CoolRide setups. Sorry for the confusion on the website. They are a component that is included in the kit listed below. They do not appear in the stock photo. Check out the link and let me know what you think.
http://www.ridetech.com/products/coo...th-stock-arms/
John J.
Sales/Tech
Old 01-15-2018, 06:16 PM   #350
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks for sharing JohnJ.
Articles-
"Refining Sierra"
