Old 08-17-2013, 10:50 AM   #351
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Ps. I am looking for a steering wheel with nice center cap from a 67 or 68. I don't mind if the wheel itself needs a little repair. Don't care for the 69 steering wheels. Hope to find one at the swap meet. If you have one let me know.
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 08-17-2013, 06:23 PM   #352
jmking9
jmking9's Avatar
Re: Project 69SWB
Sorry, I dont have, or know of any leads on a steering wheel. Hope you find one at the swap meet. I always say I'm going to that meet, and something always causes me not to. Went to the H.A.M.B. Drags at Mo-Kan today instead
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 08-17-2013, 08:31 PM   #353
CC69Rat
CC69Rat's Avatar
Re: Project 69SWB
You might check with Jonathan.. VA72C10
Tell him I sent you if you want. I'd say he has more than one he'd part with.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 08-17-2013, 08:40 PM   #354
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Project 69SWB
If VA72C10 doesn't have one, PM uncle. He should have some of them.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 08-20-2013, 09:33 AM   #355
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
The swap meet was great.. lots of good stuff, but not one 68 steering wheel. :-( I did find one though up in KC, having a friend pick it up for me.
I found one, but thank for the lead.
I appreciate it, thank you, but I've got one on the way.
Jimmy
.69SWB Build.
Old 08-20-2013, 09:41 AM   #356
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I finally got busy and got my Cowl and fenders in primer.
I had sandblasted the cowl a while back, it was still pretty clean, but I went ahead and wiped it down with Fast Etch then PRE, as with everything else, shot epoxy first...
Then laid down the Poly
I'll have a little work to do on this around the antenna hole and a little on the passenger and driver side
Jimmy
.69SWB Build.
Old 08-20-2013, 09:48 AM   #357
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
The fenders, I filled in all the trim holes with my mig, and as you seen from earlier posts I had spent a lot of time stripping them, but couldn't get up inside the top part, so I called the Sandblaster and he blasted it out for $10 for both fenders. He also said whoever quoted me that crazy per fender price was nuts and wrong... $35 fender is what they charge. I could have save myself a lot of time! ha.
The inside top of the fender is rust free and this shot is after the epoxy and poly. I just spray epoxy up in there real good.. they grey you see is just overspray from the poly.
The epoxy laid down so smooth, I was pretty happy. Could have went straight to paint if I didn't have body work to do.
Hanging around waiting to dry.. You gotta get creative in such tight spaces, so a little bailing wire and my open garage door... and wallah!
Jimmy
.69SWB Build.
Old 08-20-2013, 09:54 AM   #358
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
After the fenders dried enough to handle them, I just softly bolted them to the core and cab, because I needed to close the garage at some point and since I used the garage door to hang the fenders, they had to come down.
I have the 4/6 drop on here from ECE, but still have a lot more weight to add to the truck, so hoping it settles on down a bit more.
It's sooo nice working on clean stuff.. took a while to get to this point.
Working on the doors next.... metal work is done on them, just got some stripping and priming to do.
Jimmy
.69SWB Build.
Old 08-20-2013, 10:11 AM   #359
Low Elco
Re: Project 69SWB
Good Progress-I also used the "Garage door rack system" to do mine. Parts look nice- you shaving the antenna?
Low Elco is offline   Reply With Quote
Old 08-20-2013, 10:30 AM   #360
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I was going to... but decided to leave it at the last minute. :-/
Jimmy
.69SWB Build.
Old 08-20-2013, 10:35 AM   #361
KSWes
KSWes's Avatar
Re: Project 69SWB
Looking sharp!
70 Chevy C10 LWB
My Build:http://67-72chevytrucks.com/vboard/s...d.php?t=513002
KSWes is offline   Reply With Quote
Old 08-20-2013, 10:56 AM   #362
Bomp
Bomp's Avatar
Re: Project 69SWB
Niiiiiiice.
Looking really good.
Bomp is offline   Reply With Quote
Old 08-20-2013, 11:17 AM   #363
Xeen
Xeen's Avatar
Re: Project 69SWB
Look out it's starting to look like a truck again!
Maybe it's an optical illusion but it looks like the backspacing on the front wheels isn't going to allow the tire to sit inside the wheel well, I hope that's not the case or you might have an issue once you instal the engine.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-20-2013, 11:22 AM   #364
El Campo
El Campo's Avatar
Re: Project 69SWB
Truck is looking nice! Fenders are beautiful. I just read your whole thread. Was wondering what to do with bottom of cab and bed and the Berliner you used looks great! Will have to check it out closer.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 08-20-2013, 04:27 PM   #365
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Originally Posted by Bomp View Post
Niiiiiiice.
Thanks Bomp! I REEEAALLLY need to get over to your thread and see what you've been up to. Doing that tonight!
FINALLY looking like a truck again.
as far as the wheel backspacing, they're not going to be tucked too far up in there since I'm running 17's and not slamming it. They're not sitting outside the fender. Here's my W&T set up
On the front is 17x8 with 4" bs wrapped up with 255/60's
on the back is 17x9.5's with 5.5 bs wrapped up with 275/60's
Thanks a lot El Campo! I'm going have to get over and see what you have going on... took just a sneak peak and that engine has got me all jealous!
Jimmy
.69SWB Build.
Old 08-20-2013, 10:06 PM   #366
sduckworth13
sduckworth13's Avatar
Re: Project 69SWB
Nice job!! Jimmy the truck is coming along nice.
Scott
sduckworth13 is offline   Reply With Quote
Old 08-20-2013, 10:45 PM   #367
Bennett68C10
Bennett68C10's Avatar
Re: Project 69SWB
Really nice job on everything
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 08-20-2013, 10:49 PM   #368
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Project 69SWB
Looks really good. I thought I recognized your parts hanging system, I have the same one! Dont be like me and hit the garage door opener without removing parts first!
--Josh
Old 09-02-2013, 10:48 AM   #369
jmking9
jmking9's Avatar
Re: Project 69SWB
Looking good! I'm thinking about drivin the truck over your way on the 28th for the street machine nats. If you're around I'll have to swing by and check out your truck. Looks like you're doing an awesome job!
1970 SWB Build
Old 09-02-2013, 10:58 AM   #370
Xeen
Xeen's Avatar
Re: Project 69SWB
Ouch! I know that made you wanna puke when it happened.
Old 09-02-2013, 11:09 AM   #371
RCbowtie69
RCbowtie69's Avatar
Re: Project 69SWB
Looking good,keep up the hard work & pictures coming.Keep on Truckin''
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 09-26-2013, 03:26 PM   #372
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks Scott!
Thank you Keith!
Looks really good. I thought I recognized your parts hanging system, I have the same one! Don't be like me and hit the garage door opener without removing parts first!
No worries, the rack system operated as it should... But I did think of that and hoped I wouldn't do it by mistake.
Jonathan .. we leaving town for the weekend. I hate to miss the event and your truck too! We probably won't leave until 10ish. How early are you going to be in town. You're definitely welcome to stop by before we leave.
Thank you!
Guys, I've been slacking in my build here, just been too hot this summer to work on the truck... I like working more in the cooler months. Now that it's getting cooler I've started getting back to it.
I just got my doors back from being blasted. Had a lot of hole filling with the mig to do. I also started using some stuff called All-Metal to fill in any spots before I put down the epoxy. It's pretty easy to work with and can be laid on bare metal without worries of it drawing moisture like filler would. so far so good with it. I have a question that I'll post in the body section too but though I would pose it here as well.
You can see in this pic of the upper passenger door jam I have some joints that I need to fill. I'm planning on using the All-Metal to fill these in which I think would be ideal, but wondering what some of you all did for stuff like this ... ? I want it to be smooth when I done so you can't tell there where even seams there in the first place.
Lots of hole filling on the doors ... mirror holes, trim holes, sheeze... but all in all real solid doors.
Jimmy
.69SWB Build.
Old 09-26-2013, 03:48 PM   #373
Xeen
Xeen's Avatar
Re: Project 69SWB
For the upper door channel you could use seam sealer.
Old 09-26-2013, 03:57 PM   #374
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
how would I smooth it out and finish it flat with the rest of the door jam? Want it so you can't tell there are seams there after I'm done. I've always been told putting filler on top of seam sealer is a bad idea. Have you done it with good results?
Jimmy
.69SWB Build.
Old 09-26-2013, 04:10 PM   #375
mcbassin
Still Learning
mcbassin's Avatar
Re: Project 69SWB
Ah, bringing back memories of when I worked on my doors. All those hole are very time consuming and can warp your metal if you hurry them.
Very nice progress since I checked in last.
On those seams, I used Plio-Grip seam sealer. The no sag stuff if I remember right. LINK
mcbassin is offline   Reply With Quote
1969, black, custom 10, fleetside, shortbed
