#401 |
I'm trying....
![]() Join Date: Oct 2013
Re: Attempting my first build 72 K5
Turned out great Mike...and I feel ya. There's not a lot of bright work on the interior, but it put me on dialysis too. Keep up the good work.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#402 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Nice chrome! Thanks for the update.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#403 |
Now I remember why I decided to de-chrome.....looks great though.
#404 | |
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
#405 |
Long story,but going to keep it short for board. The body is at a new shop and it's in much better hands now.
This is how I found my truck after they closed down for business. This is the shotty work from the first shop. Their idea of how they would fix the rear quarter panel.. putting 1/2" to 3/4" of bondo.. Unbelievable! First of all, you're not supposed to bondo over primer. It took 8 hours to remove 2.5 gallons of bondo. He's going to fix the rear quarter panel properly by pulling and straightening the areas that are pushed in.
#406 |
Sorry to see you were the victim of a POS body shop. It's hard to find a reputable body shop who will do the work correctly. The worse part is, if you don't keep track of what they're doing, you may never know. Body men are paid to make dents disappear and unfortunately, some body men despite having a good rep can do shady work and are VERY good at making things "look" great. I found bondo work on my Blazer that was laser straight, not cracked and looked like the sheet metal was never damaged, but ended up having 3/4" to 1" of putty. The funny thing is, me as an amateur was able to straighten the metal with basic body work tools and used less than 1/16" of bondo in less than two hours. Go figure.......
#407 |
I'm just thankful they never were able to finish my Blazer because I would've been driving a frame off restoration with a ton of bondo.
#408 |
Charlie is making a great progress on the panels and removing some of the dents the "right" way. The black is the low and high spots that he is going to remove by block sanding so everything is straight and smooth
#409 |
A couple dents repaired the "right" way (no bondo!)
#410 |
That sucks Mike.
Glad it is getting back on track for you.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
#411 |
Carpe manana
I'm glad to see your build is back on track and in the right hands. It's going to be top shelf once complete. Hang in there. Sorry that you had deal w that dishonest shop.
#412 |
I'm trying....
The worst part of what that other shop did was that you have such a great tub. They're so hard to come by, that to disrespect it like that is almost sacrilege. Good on you for getting it back on track.
#413 | |
#414 |
Looks good. Who is doing your body work now?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#415 |
![]() Join Date: Jan 2007
Good call on moving to a new shop!
#416 |
Agree with the shop move comments - - thats a scary situation in my opinion. Sucks to feel taken advantage of........
I know your build evolved and changed after having started it awhile back, which leads me to an engine question. I have been advised to save getting the engine for as long as possible so as not to have the engine sitting idle and immobile (valve springs compressed in the same position, etc.). Any issues with that (that you can tell) or are you cranking the engine over every so often? Curious how you are managing that. Thanks! |
#417 | |
Thanks guys. I'm really happy with the new shop. Stopped by today to drop off the top so they can make sure the doors align. I'm going back again this Saturday to deliver the chassis. If I originally was going to do a frame off I would have planned this a lot better and held off on the engine. I haven't fired it up since I've had it. I'm just gonna pray to the engine gods and hope it fires up and runs good!
#418 |
BFS Auto. He brought in one of his go to guys for these particular restoration projects.
#419 |
Question about correct steering coupler...
I ordered a new rag joint from Advanced Auto - Lares part # 201 and it says it's an exact fit. It seems odd to me that the new rag joint has only 11 splines. I did replace my steering gear box with an AGR and it has the same spline count as my original. It is possible my "original" might have been replaced with a later model but I highly doubt it. I initially tried to rebuild my old coupler but failed miserably. I bent one of the studs trying to press them in the back of the coupler. Does anyone know if this seems right?
#420 |
I don't remember if mine had the full amount of splines all the way around or not. If memory serves, I remember the shaft size on the 67-72 chevys was 13/16" whereas 73 and up are 3/4". I'd say if it fits nice and tight, you have a winner.
#421 |
![]() Join Date: Apr 2012
Here is a picture of used one I bought from Thomas at DLTruck1973. You might give him a try if you are unhappy with the new one.
#422 |
Carpe manana
FWIW - I bought one a while ago from Eckler's and it fit fine.
#423 |
#424 |
2WD Jimmy
![]() Join Date: Mar 2005
Yea... that spline count is not right.
#425 |
I sent the one from Advance Auto Parts back and they refunded my money. I called AGR and they weren't much help, but I did find out that after reading the product description on Summit it requires a 36 spline so I'm going to give this one a shot since the description matches the specs for my application. Ecklers says 13/16 but no list of spline count so I'm gonna assume it's for an original with 31 splines.
http://www.classicparts.com/1967-76-...info/SS-5152/# Jeff - the link didn't work. Website says it temp out of service
