Old 12-02-2014, 07:15 PM   #426
thebebop
thebebop's Avatar
Re: 58 TRUK intro
I sure did thanks
1955 2nd Series Truck
thebebop is offline   Reply With Quote
Old 12-09-2014, 09:08 PM   #427
jratz1966
jratz1966's Avatar
Re: 58 TRUK intro
I just read your thread Ogre,you did an awesome job on your build.enjoyed your thread.
jratz1966 is offline   Reply With Quote
Old 12-10-2014, 06:26 PM   #428
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
thanks jratz, i enjoy driving it more than building it and i enjoyed the build
bring your truck over to bakers in milford when salt season is over
shop air compressor timer
Old 04-17-2015, 04:39 PM   #429
_Ogre
_Ogre's Avatar
door mirror mod
like everything else... i made a new drivers door mirror
similar to ogre... ogre's truk spare tire was too big
the original side mounted spare was 4.5'' wide; the P235/70R15 tires i mounted were a lot wider
this made the drivers side mirror worthless for seeing behind me, great for looking in the next lane
i figured the mirror needed to be moved out 2'' to be able to see past the spare tire
and i like the art deco look of the stock mirror arms
i drew up the stock mirror base in autocad and cut it out of 3/8'' stainless steel on the plasma table
counter sunk the screw holes and started shaping the base
more shaping with a flap wheel and then hand sanding to get the sanding marks out
i tried the da sander it just left more flats and swirls
i bent 1/2'' ss rod aver a 4'' pipe to get the arcs needed and forged a mirror mount on the end
then hand sanded and polished
had one of the guys at the shop tig weld it; he didn't do such a good job
no grinding or mechanical sanding... all hand sanding starting with 80 grit to shape the weld
this is the start of 80 grit, then progressively finer to 1600 grit
the mirror arm turned out decent enough, still some under cut and porosity in the weld
but now i can see behind me
i can actually see the shop door frame now, before all i saw was wall
all done i might have 10 hours in this bad boy
i initially made it too long and ended up cutting the forged end off and just made some flats to mount the mirror
i wish it was this easy to see past ogre's spare tire
Old 04-17-2015, 04:55 PM   #430
Advanced Design
Advanced Design's Avatar
Re: 58 TRUK intro
Really nice work Ogre. Ten hour labor of love. Does the mirror head mount through a hole? You mentioned you cut the flat off.
Advanced Design is offline   Reply With Quote
Old 04-17-2015, 05:05 PM   #431
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
back in post 399 of this thread i mention i had lost my speedo coming home from the hot rod power tour
that was way back in june, i ordered 3 speedos and they either came mangled or so far out of calibration i ended up returning them all
i finished the year off with my neighbors old android phone with the speedometer app loaded
i had stupidly sold my old speedo and bought a new one to have the mileage reset to zero for the rebuild
a member on another forum sent me an used stock speedo that worked but was way off calibration
another member on this forum tbone1964 had mentioned he did speedo and gauge rebuilds and calibration
he was in the middle of moving from michigan to oregon last summer,
i ended up sending my speedo off to him in october and received it back a couple weeks later during a very cold winter (coldest feb on record)
just started driving truk for the spring and installed the speedo last month
the speedo is dead on; cudos and a shout out to tbone1964
nice to have a working speedo again...
if anyone needs speedo or gauge work done on their classic tbone is the man
he has a website http://www.classicgaugeandcluster.com/ where you can see some of the work he's done
he was also 1/3 the cost of dealing with a local speedo shop here including the shipping cost both ways
not sure if that was a forum discount or just his standard rate for ogres
Old 04-17-2015, 05:08 PM   #432
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
thanks; i cut the forged end i had made off the rod, not the mounting plate
Old 04-17-2015, 10:43 PM   #433
DransportGarage
DransportGarage's Avatar
Re: 58 TRUK intro
Very nice, Ogre. It must be spring...
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 04-18-2015, 12:24 AM   #434
Kim57
Kim57's Avatar
Re: 58 TRUK intro
Nice job on the mirror.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-18-2015, 12:39 AM   #435
TBONE1964
Cluster King
TBONE1964's Avatar
Re: 58 TRUK intro
Hello Mr Ogre,
I am glad you are happy with the speedo work. I try to make sure they are correct the first time I repair them so I am not getting phone calls. I appreciate your trust and business. It is very rewarding and comments like yours make me want to continue doing great work for great people.
Enjoy spring in Michigan and say hello to the pot holes for me
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 04-20-2015, 04:45 PM   #436
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
i'm headed your way this summer, i will get you for this
Old 05-19-2015, 04:31 PM   #437
oldcouple
oldcouple's Avatar
Re: TRUK doors 2.0
I am gonna try to make something like this, but I cannot read the dimensions on the drawing, mainly what is the length of the tubing. Also any other pics showing the other end where it goes into the door? Maybe even inside the door? Great job and the work you have done. Maybe someday I will be able to dive mine again.
running wires into the door from the door jam proved to be a challenge.
i had 2 speaker wire, 2 solenoid wires, 2 window wires and a safety door release cable to run into the door.
the release cable is a bicycle brake cable ~3/16'', needless to say i had a fistful to run into the doors.
i tried the spring like door wire loom; it wouldn't carry half the wires and wouldn't work with the door hinge geometry on 55-59 trucks.
again, necessity is the mother of invention...
i drew up the hinge geometry to design my door wire loom, just basic pivot points and door locations.
using 3/4'' sq aluminum tubing and some 1/4x2 flat stock from home depot, i made these.
pivot is a 1/8'' roll pin.
door open
door closing
they worked out rather well.
2-#16, 4-#14 and the 3/16'' cable fit in with room to spare.
everything mounts and pivots on the door jamb.
i cut an over sized hole in the door and made a plastic bushing to guide the loose end in and out of the door.
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 05-20-2015, 04:22 PM   #438
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
your truck is looking good, very nice
the door harness loom i made has worked well for 5 yrs and 26,000 miles
no shorts or broken wires to date
the tube is 5.625 long, the tube slot is 3.5'' long and maybe a 1/16'' wider than the tube
the important part is the pivot placement; .375'' from the end of the slot and the tube
the pivot is a 1/8'' roll pin, drill the pivot in the tube right on the edge of the wall
only the bottom hole in the plate is 1/8'' all others are a loose fit to make it easier to install the pin
the loose fit means i can drop the pin in 75% and less hammering near finished door jamb paint
the aluminum plate was cut with a jig saw and filed to shape, same for the door jamb hole
here is a link to the pic so you can download it and zoom in, if you want
http://s306.photobucket.com/user/_og...ml?sort=3&o=26
my paint was done as is yours so tape everything up well
in the door i have a round 1.5'' hole, it was easier to drill with the door hung
to line up both holes in the jamb and door i laid out the tube location when the door was closed
then drilled a hole in the jamb to match the center of the tube; closed the door and transferred the center to the jamb
i made a .25'' pvc guide with a square hole as a guide and used double side tape to secure it
the pvc failed, try to use delron or some other plastic sheet material and screw it to the door
right now i have no in door guide on the drivers door, it has been that way for 3 yrs
i recommend doing the pass door first as you will learn a lot on the first install
i did the drivers door first... it has always squeaked a bit
if you need any more info or help post back
Old 05-20-2015, 06:03 PM   #439
oldcouple
oldcouple's Avatar
Re: 58 TRUK intro
Thank you so much, Now I just have to make the journey to the nearest place that stocks the supplies needed, some 27 miles, gotta love living in the wilderness.
Old 05-21-2015, 03:04 PM   #440
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
check home depot i bought everything there
though it may still be 27 miles
Old 05-21-2015, 09:54 PM   #441
Hubscrub
Cruzin
Hubscrub's Avatar
Re: 58 TRUK intro
i've made it to page 8 tonight, i just want to say wow i like it and the yellow
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-22-2015, 11:59 AM   #442
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
thanks hubscrub
had i found this forum when i started my build, there'd be a lot more build pics
Old 05-23-2015, 04:55 PM   #443
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
my truk is finally back together for the first time since speedo problems started last june
the dash fascia and column cover have been out since then
hooray!
pulled the headlight rings out last month to aim the headlights, both were pointing in the right ditch
got those back in today too
Old 05-23-2015, 08:53 PM   #444
Advanced Design
Re: 58 TRUK intro
Great, nice cruising weather right now. Are you going on Power Tour again?
Old 05-23-2015, 10:35 PM   #445
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
it's about time we had good cruising weather
last weekend it was in the mid 80s, tried to go to a cruise in on tuesday, it was cloudy windy and 52*f
brrrrr
to bad most of the country is going to rain for the holiday
not sure about the power tour this year; at this point i'll say no
Old 06-26-2015, 04:50 PM   #446
samples45
samples45's Avatar
Re: 58 TRUK intro
Alright man I'm wanting to keep my drip rail/ ledge on the firewall but I want to smooth out the cowl to firewall seam that's above the drip rail. Can you explain how to do it? I just didn't wanna make it weak when I smooth it out!
samples45 is offline   Reply With Quote
Old 06-27-2015, 02:27 PM   #447
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
post a pic of what your talking about in the thread you started, i didn't see your thread on the topic
we're unsure of what seam your referring to
i tried to pm you back, your ''in box'' is full, you need to delete some pm's
Old 06-29-2015, 11:55 PM   #448
samples45
samples45's Avatar
Re: 58 TRUK intro
It was the same seam yall were talking about.. outer cowl meets the firewall.. the cowl was overlapped the fire wall and just had some spot welds from the factory. but i got it all taken care of and smoothed out. turned how just fine! Now im needing advice on smoothing the vents.. If you could tell me what sheet metal you used and how you put the curve in it. thanks!
Old 06-30-2015, 09:46 AM   #449
Kim57
Kim57's Avatar
Re: 58 TRUK intro
I just used 16 gauge steel.
Here are a few pics.
Kim
My build thread
Old 06-30-2015, 01:23 PM   #450
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
shaving the cowl vent eliminates the entrance hole for water that destroy our cabs
the rust found in; front cab corners, vents and hinge pockets can usually be attributed to this vent
i always recommend shaving the vent
kim did it the right way, i cheated and used longhair filler to plug the vents and then welded the panel in
my original intent was to leave the vent loose so that it was removable
you can see the screws in this pic
