12-09-2009, 12:51 AM | #26 | |
3DrDwn--the 'burb not the band
Re: Step by step Flip kit install 1 ton dually square (now with pics)
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
12-09-2009, 12:56 AM | #27 |
Looks good
Justin |
12-09-2009, 01:19 AM | #28 |
Looks good ....... are you still sporting the running boards??
Keep us poste to any progress. Ratty 46 |
03-02-2010, 08:54 PM | #29 |
Sweetness...incidentally, I ultimately ended up ditching the swaybar.
I didn't notice a difference. |
05-14-2010, 12:48 AM | #30 | ||
Josh
05-14-2010, 12:54 AM | #31 |
Why the tire size change?? Do you get a better feeling of the road with the 60's??
Ratty 46 |
05-16-2010, 07:14 PM | #32 |
Do you have a write up or pictures for the front bag setup? or the rear 4link? Thanks for doing this for us SquareCrewDually guys.
11-18-2011, 03:25 PM | #33 |
Final step.... reverse entire process to install air ride.
12-02-2011, 10:02 PM | #34 |
I'm itching to lower my dually, but I am wondering what kind of clearance is left between the axle and the frame, or bump stop with a flip?
12-03-2011, 08:54 AM | #35 | |
I measured 7.5" of clearance between the top of my axle tube & the bottom of the frame rail. The leaf pack is about 5" tall & the rear axle tube is 4" OD. Since the tube is moving from below to above the leafs w/the flip kit, the spring pack height + 1/2 of the axle tube OD should yield the amount of drop or roughly 7". C-sections can be installed for a little more clearance but the bed floor will make contact w/the rear end differential housing.
12-03-2011, 11:05 PM | #36 | |
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 Last edited by RunninLo; 12-03-2011 at 11:09 PM. Reason: added reference to post #26 |
12-04-2011, 06:22 PM | #37 |
Thanks for the info. I'll probably do a hanger\shackle drop and remove a few leaves to lower it. This was a great thread by the way.
12-26-2013, 12:14 PM | #38 |
did you have an issue with the rear having the casted saddles and the flipkit not fitting
08 cc silverado dropped on 24's 82 1 ton c30 Dually |
08-23-2015, 11:50 PM | #39 |
Where did you get your kit from? I've been struggling to find anything for my '64 dually. Ultimately I'm just looking for a 3" static all the way around and eventually bag it.
08-24-2015, 12:43 PM | #40 |
Western Chassis has flip kits for 73-87 (-91 cc's) 1-tons. Might require some mod's to work on earlier stuff. For 3", you can do spindles for a 73-87 1-ton up front. The rear would require a shackle/hanger combo or shackles & removing some leafs. A flip kit would yield double that 3" drop
08-24-2015, 02:04 PM | #41 |
Perfect. Thanks so much man.
