04-08-2015, 11:13 AM | #26 |
I'm just glad to be here!
Re: Rear Axle Codes
For the RAX W3512
I get: RAX - 1972 3.73P (I believe the P stands for positraction) W - Warren, MI assy plant 351 - 351st day of the year, Dec. 16th (1972 was a leap year, otherwise it would be the 17th) 2 - Second Shift
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
04-08-2015, 11:42 AM | #27 |
Re: Rear Axle Codes
Karl thank you for the info I appreciate it.
That was fast Scott
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
04-08-2015, 12:37 PM | #28 |
Re: Rear Axle Codes
RAX 72 KS-KE10 3.73 posi
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-08-2015, 01:02 PM | #29 |
Re: Rear Axle Codes
I wish it was complete but all I got was the housing, axles and an open dif. but it was free so I will just assemble with new parts. Thanks Guys
04-08-2015, 02:16 PM | #30 | |
The Older Generation
Re: Rear Axle Codes
Look up the RAX in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578793 LockDoc
04-22-2015, 11:38 PM | #31 |
Re: Rear Axle Codes
The code on mine is HC1217W on the axle tube with the casing code of NF3890838 on the front of the pumpkin... can anyone give me some insight to what I have? Is there an easy why to determine the spline number with out pulling the axles?
04-23-2015, 12:03 AM | #32 | |
Re: Rear Axle Codes
Use the "HC" and look at the code lists in the link I posted in the post above.... Pay no attention to the C-14 it should be C-10. Lock Doc
04-23-2015, 10:06 AM | #33 |
Re: Rear Axle Codes
from the factory, your rear was a 3.73 positraction. If it is a '65 or later GM 12bolt truck rear end, the axles should be 30 spline. If you are unsure, the only other way to check is to pull out an axle and check it...
08-28-2015, 07:45 PM | #34 |
Re: Rear Axle Codes
Found this thread while trying to get info on a axle I bought for a project. It's a dually axle from a cab & chassis truck. it is supposed to be the narrowest Chevy/GMC dually axle. It's from a early to mid 80's truck. I tried all the links above but they didn't get into the 80's trucks. So... Here are the codes-
KMR G0 342, I think that last number is a 2 as it wasn't stamped real well. Hope someone can help, or point me to where the info might be located. I'm really after what year truck this might be from so i can get all the right bearings, seals, and brake parts also. Thanks, Mike |
09-26-2015, 11:54 PM | #35 |
Re: Rear Axle Codes
65 3 tree, 230, stepside
HA 08 15K?? Ratio? Posi? What can I switch out a little more highway and still keep 6 lug? Last edited by sharkskinman; 09-26-2015 at 11:58 PM. Reason: added yea, motor |
10-14-2015, 02:45 PM | #36 |
Re: Rear Axle Codes
I searched the threads and found that the rear end in my 1970 parts truck (TDE 1219 W2) is/was a 3:07 built on Dec 19 at Warren and the 2 is 2nd shift, right?
10-14-2015, 03:30 PM | #37 | |
Re: Rear Axle Codes
http://www.348-409.com/differential.html Every code for 1959-1970 C10's are listed. |
10-14-2015, 03:51 PM | #38 |
Re: Rear Axle Codes
I have an 71 c10 swb step side with 307 4 speed, my spid says positraction rear A. Looked on the rear end the only thing i could find was NF3896838 could someone tell me what type of gears do i have?
10-14-2015, 03:55 PM | #39 |
Re: Rear Axle Codes
Every code for 1959-1970 C10's are listed. Went there. TDE code is not listed. |
12-27-2017, 02:19 PM | #40 |
Re: Rear Axle Codes
can someone decipher these codes. I know its a 12 bolt. Casting 3896839 GM83, axle tube stamping TBT 219 01. Thanks
12-27-2017, 02:48 PM | #41 | |
Re: Rear Axle Codes
LockDoc
12-27-2017, 02:51 PM | #42 |
Re: Rear Axle Codes
Double and triple checked. It is plain on the tube TBT. I couldn't find that code either. Closest was a 1971 TPT, but you can clearly see it is a B
12-27-2017, 02:54 PM | #43 |
Re: Rear Axle Codes
I bought the front and rear diffs out of a 1981 Blazer and am putting them in a 1964 K10 short box. I had to move the spring perches in 1" on each side. The 1964 spring set up is 40.5 " and the diffs i bout were 42.5"
12-27-2017, 03:04 PM | #44 | ||
Re: Rear Axle Codes
That would explain the 01 in the date code then. The code lists I posted only include up to '72 so you will have to find the later code lists. Maybe in the "PartsWiki" links that SSTim posted above. LockDoc
03-17-2018, 02:06 AM | #45 |
Re: Rear Axle Codes
Reviving this old one...
1982 SWB K10 Rear Axle Tube reads “KBD G356” Casting #1254333 on diff ball driver side Casting on top left side of diff ball is “L141” Casting on diff ball pass. side is “GM36” Any help is greatly appreciated. Parts store can’t seem to find the correct brake drums I need to get this baby back on the road. Posted via Mobile Device |
08-24-2022, 04:46 PM | #46 |
Re: Rear Axle Codes
Can anyone help me identify the axle in my 1970 C10?
On the Axle Tube it is stamped HC 06 0 8 W ................................................E I am thinking it is a 3.73 Posi out of an early truck???? The Dropped E has me confused. I think that HC is a Posi 3.73, but on my axle tube it definitely has a E, but it is dropped down one Row from the rest of the stamping. |
08-24-2022, 05:11 PM | #47 |
Re: Rear Axle Codes
Based on the charts LockDoc posted in the following thread, it looks like HC is 3.73 ratio with posi. 1970 was a transitional year where they went to a wider overall rear end width. Since the HC code is listed in the 1969 chart, I'm wondering if your housing might be the narrower design. I may be wrong about this, but I believe the wider design had GM54 cast into the center housing, whereas the narrower design was GM51. That's how it was on a wide 1970 housing I sold recently vs. a 1968 housing I purchased to replace it. Measuring the width of the rear end would be the conclusive way to tell.
https://www.67-72chevytrucks.com/vbo...d.php?t=578793 Copied from the thread below: axle width is 55.5 wide with 30.5 long axles on the narrow rear end. earlier rear end axle width is 57 wide with 31 5/16 long axles on the wider rear end. later rear end http://67-72chevytrucks.com/vboard/s...d.php?t=640514 |
08-24-2022, 05:13 PM | #48 |
Re: Rear Axle Codes
pjmoreland-Thank you so much !!
