Old 11-24-2013, 08:58 AM   #26
bj383ss
bj383ss's Avatar
Re: 64 C10 Stepside "Jaybird"
Got my sheet metal!!!!
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 11-28-2013, 09:15 PM   #27
bj383ss
bj383ss's Avatar
Originally Posted by pdxhall View Post
Great progress on the interior metal. Good luck on the patching.
Thanks man following your build pics to guide me. Dumb question but when you put parts back on that were spot welded. Do you just drill holes in the new part to spot weld?
Originally Posted by T.J. MCCAULEY View Post
Truck is looking cool! Like the photo! yeah it does have nice rims in the picture! lol!
Thanks T.J. Found out today my FIL owned this truck twice. This is the first time he owned in the early 70's.
Got about 6.5 hours in today while the girls where cookin'.
I patched the two big holes in the hump. The one on the side didn't turn out to well may cut it back out and start over. The patch metal is two thin and keeps blowing out when I try to weld it up.
Took the fender and door off.
Drilled a hole in each hinge to help me line it back up.
Took off the rocker. Looks like a need a front pillar.
I'm on vacation this next week hope to get a lot done on the truck.
Bret
Old 12-01-2013, 09:36 AM   #28
bj383ss
bj383ss's Avatar
Dove in and cut the Driver floor out!
Old 12-03-2013, 06:39 PM   #29
bj383ss
bj383ss's Avatar
Stripped the front end off. Everything on the front is in good shape except the wiring. All I have to do is blast and paint it.
The dash is almost ready for paint.
Tomorrow I plan to strip the bed off. Have 2 more nice days here in CTX before a cool front blows in.
Bret
Old 12-04-2013, 12:37 PM   #30
aggie91
I'm just glad to be here!
aggie91's Avatar
Nice start, the rust does not look to bad, mines worse for sure. I hope to start back on mine after the holidays...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-04-2013, 12:43 PM   #31
1963c-10
1963c-10's Avatar
Great progress on the metal work. I'll be doing the same in the spring. I'm interested to see how your Top Banana parts will fit. They make nice parts. Also...I did my steering wheel also. I used JB weld to fill in the cracks after sanding and haven't had any issues yet on the repair.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-04-2013, 05:23 PM   #32
bj383ss
bj383ss's Avatar
Its really not that bad. I have see a lot worse on this forum so hopefully I can get it all welded back in right.
Thank you. This is my first time at metal work on an auto body and welding. I am woodworker so this is all kinda of the darkside. I read your post on the steering wheel repair. Will tackle that once my vacation is over.
Its funny you mention the parts I was test fitting all of the driver's side this morning. I ran into some problems. The first is the front hole in the floorboard section does not line up with the kick panel and the bottom fender bracket hole. Its off by a lot. Even when you have the parts off the truck the holes don't even come close to lining up.
I got the holes in the front brace to lineup and this is what is important. I can re drill the hole in the floorboard.
I also have a big gap between the floorboard patch and the firewall. I think I can pull this together and then fill it with weld.
The other problem I see is the kick panel does not fit good against the A-pillar where it has the idention on the inside. The A pillar has a curve to it. I am replacing the A-pillar but I have not ordered it yet so I will wait until I get it before I do any welding. Hopefully the kick panel will fit better with the aftermarket A-pillar.
I know these parts aren't perfect to the original but it looks like I can make them all work right. You see my oops on the right of the picture. Even after careful measuring I cutout too much there in the front.
I had planned on pulling the bed today but after fighting with the step and fender on the driver's side for 2 hours I called an early day. I had to cut nearly every bolt off. After 5 straight days working on her my body has finally given out. Hope to get back on it on Friday. We are having some pretty cold temps come in so that will help cool it down some.
Old 12-04-2013, 05:26 PM   #33
1963c-10
1963c-10's Avatar
Next time drill the heads off the rear fenders bolts from inside the bed....turns it into a 20 min project. The metal work looks great and the panels fit far better than the stuff from LMC and the rest of those vendors. Keep up the progress and posts.
Old 12-04-2013, 05:29 PM   #34
bj383ss
bj383ss's Avatar
I also cleaned the cab corner and only have 3 really small holes I can weld up.
One other thing 1963 C-10. I cutoff the floor patch right at the start of the back pillar. I didn't want to take any of this loose.
Bret
Old 12-04-2013, 05:33 PM   #35
bj383ss
bj383ss's Avatar
Thanks for the tip. I did grind the heads off from the inside. Most of the step bolts I had to cut with a cutoff wheel. The where suppose to be carriage type bolts but everyone of them spun.
I think I stripped the whole front end in the same time as the step and fender. LOL!
I have an air ratchet but my big compressor kicked the bucket and my backup one is a small Sears one that can bearly run any power tools. I asked Santa for a 3 hp single stage. Hopefully I have been good enough.
Bret
Old 12-05-2013, 01:13 AM   #36
62 Barnfind
62 Barnfind's Avatar
Your truck is comming along nice. Good work on the metal and welding. Before you know it you will be done. I cant wait for the bed to be off. Are you going to use POR 15 or rustoleum? Did you decide to work the bed first or last? I will be home In Jan, so if you need some help on something wait and I can help you. Like cutting the bed wood or body work! Good job!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 12-06-2013, 06:44 PM   #37
WhippinSaw
WhippinSaw's Avatar
Nice work on fitting the sheet metal. I just did some first time welding on mine and had a lot of fun, You get much better at it really fast, Since then I've repaired some lawn furniture, a lamp and our pull out bed. , I like where you go on "vacation"
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 12-06-2013, 09:32 PM   #38
bj383ss
bj383ss's Avatar
Thanks John WhippinSaw. Hopefully it will resemble what it looked like from the factory when I get done with it. I always stay at home and do projects on my vacations. Going places on vacation stresses me out! LOL.
I didn't get anything done on the truck today. But I have a good excuse. They wife told me last night we had to be at the in laws today(where the big garage is) from 9a-5p. She was expecting a delivery and it was to heavy for her to deal with.
Hmmm. An early Xmas present to me from my Mother in law. She is awesome!
I kinda of knew what it was so I spent the morning cleaning up the southwest corner of the garage and running some wiring for said item. I went ahead an insulated the corner too.
I broke it in but didn't have the right fittings to hook it up. Made a trip to Lowes on the way home to get the fitting I needed. While I was there found a vibration pad kit on clearance for $7.
Look forward to using it tomorrow. Should keep up with my sandblaster quite well. Next thing on the list is to build a sandblasting cabinet. I found some really cool plans here.
http://www.scribd.com/doc/14152057/P...net-Blueprints
Bret
Old 12-07-2013, 12:13 AM   #39
WhippinSaw
WhippinSaw's Avatar
That's a game changer in any garage, very nice mother in law. Light bulb went on when you mentioned a vibration pad, maybe that will stop mine from walking around in the garage.
Old 12-09-2013, 07:57 AM   #40
pdxhall
pdxhall's Avatar
Nice Christmas present. That will definitly make a difference. The one I got recently isn't quite as beefy as that one and I can run my bead blast cabinet and never have to stop and wait for air. You're going to love it.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 12-09-2013, 01:52 PM   #41
bj383ss
bj383ss's Avatar
Thanks guys. The air compressor is definitely save my arms. I used it to disassemble the whole bed and it came on once and shutoff while I was using my air ratchet! Awesome.
Between last night and this morning got the bed off, headers off, starter, exhaust, and drained the radiator. Looks like I will be able to just blast the headers. Which I am happy with because they fit very well. Although PO had the speedo cable and the brake line laying against the driver header. I don't know how the speedo even worked. Maybe that's why it read slow.
That's it for awhile vacation ends today.
Bret
Old 12-10-2013, 02:10 AM   #42
62 Barnfind
Looking good! Are you going to take the cab off?
John Z
62 Barnfind
Old 12-10-2013, 07:09 AM   #43
bj383ss
bj383ss's Avatar
Yes sir. I want to finish all the floorboards and rockers before I remove the cab. Need to get a engine hoist so I can pull the engine and trans and then the cab.
Bret
Old 12-10-2013, 11:56 AM   #44
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Ah! It's nice to see the rear frame isn't cut up and modified like mine is! I about killed the PO when I saw what type of "Welding" he did....
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-15-2013, 07:12 PM   #45
bj383ss
bj383ss's Avatar
I agrees with that but he did take out the last crossmember to mount the cheap plastic fuel cell.
I worked on the driver door today. I wasn't planning on replacing the whole skin but looks like I might have too. It appears the was a dent put in the front right below the belt line. All of the undercoating is knocked off in this area and the metal is kinda spongy. It had about a 1/4" of bondo on it. Along with the lower repair. I am also going to need the bottom for the inside. Not looking forward to repairing this.
Bret
Old 12-16-2013, 12:02 AM   #46
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Well, you might consider finding a donor door instead....may cost more but it will be easier if you don't like body work....what I would do anyhow. Not that I don't "Like" body work....just plain don't know how ta do it! lol!
Old 12-16-2013, 02:44 PM   #47
timmytimm3
My doors are in similar shape. I would suggest skinning the whole front. Much less chance of warping and it's not that much more for a full skin.
http://www.topbananaparts.com/driver...door-skin.html
That's my plan anyway.
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 12-17-2013, 07:41 AM   #48
bj383ss
bj383ss's Avatar
This is what I was planning to do. There is less chance I will mess it up. Plus the undercoating on the inside would be almost impossible to get off and redo.
I didn't get any work done on the truck yesterday but I did finish my mom's Xmas present.
Bret
Old 12-17-2013, 09:10 AM   #49
Grizz1963
Grizz1963's Avatar
Bret
Hey Bret, you genius. You do know how to work wood ehhh??
That is just lovely.
How hard was it to make and more importantly, the painting and finishing.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 12-17-2013, 09:34 AM   #50
WhippinSaw
WhippinSaw's Avatar
Bret
I like it to. Nice build
