02-26-2015, 11:11 AM | #26 |
Re: '53 duramax
Guess we'll find out lol. Motor doesn't weigh anymore than an old iron hemi and they stuff them in a lot of stuff without problem. I can't imagine that the front end couldn't hold an additional 300 lbs over what it would've weighed if I had put a 6.0 in it like I had originally planned. I know it sounds like a lot more tho.
02-26-2015, 02:08 PM | #27 |
Re: '53 duramax
And if they're gonna make a 700 lbs spring I would think the rest of it would be designed to take it, trust me it's been on my mind lol. If I take my first trip down the road and the front wheels fly off, I guess it couldn't handle it lol
02-26-2015, 04:51 PM | #28 |
6>8 Plugless........
Re: '53 duramax
I think you'll be fine. I pondered putting a 5.9 in my 40 Ford and the only thing I'd be worried about is lower ball joints. Like you, I figured an old hemi with a blower would weigh just shy of 1000lbs. I see hot rods with blown hemis racing and being beaten with MII's all the time with no issues. I have an old friend that had a 49 Chevy truck that was pro streeted and had a cab that was crew cab length, but only a 2 door. It was a heavy ride to have a MII front suspension. He had a lower ball joint rip out of the socket once. He baught stronger ones and kept an eye on them and never had a problem after that.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-26-2015, 05:10 PM | #29 |
Re: '53 duramax
Kinda what I thought too, it's a trial and error build, with most of it being error lol.
02-26-2015, 05:14 PM | #30 |
Re: '53 duramax
You can't prevail without some failure first.
02-26-2015, 05:32 PM | #31 |
Re: '53 duramax
Can't wait to see it. We go every spring and fall and drive right through Red lion to get there. Hope to have my suburban there this year
03-03-2015, 09:27 PM | #32 |
Re: '53 duramax
Very cool!! Nice to see another out of the box thinker like my '52 with a 7.3L. Just use all high quality suspension and steering components and check often. What rear end are you going to use?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
03-03-2015, 09:53 PM | #33 |
Re: '53 duramax
I have a chromoly fabricated 9" housing with a set of currie forged axles.
03-04-2015, 06:16 PM | #34 |
Re: '53 duramax
Yup that should handle it!!
03-12-2015, 05:49 PM | #35 |
Re: '53 duramax
03-12-2015, 05:50 PM | #36 |
Re: '53 duramax
03-12-2015, 06:37 PM | #37 |
Re: '53 duramax
Looks great. We're either doing a Duramax or BBC
03-12-2015, 07:35 PM | #38 |
Re: '53 duramax
So far the duramax has been pretty easy, a lot of cutting, grinding, one off parts and welding tho. we made everything to pit this motor in from scratch and we don't have any fancy fabrication tools other than a plasma and a welder lol
03-12-2015, 08:56 PM | #39 |
Re: '53 duramax
Sounds good. We arent scared to cut or weld . Will be watching for when yours is running. Thanks
03-12-2015, 09:23 PM | #40 |
Re: '53 duramax
This is sooo freaking cool. I love the Allison in my '02...actually shifts very smoothly for such a large beast and I'm told can be made even better with some tuning. Your creating is going to be a tire fryer, but you already know that! Thanks for the entertainment!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
03-12-2015, 09:46 PM | #41 |
Re: '53 duramax
If one will fit in that, I should be able to put one in my 3 ton 50 GMC 5 window cab firetruck. Still looking for the DMax. Could you have put a remote oil filter setup in?
03-12-2015, 09:52 PM | #42 |
Re: '53 duramax
I looked into them, but one, they're $400 and a grinder wheel and a lil weld wire and a lil 75/25 is cheap lol. Plus it wouldn't have really helped because all it does it relocate the filter itself. The problem was the filter head was hitting the frame as well as the filter so it was easier to just notch the frame. You should have no problem putting a duramax into a 3 ton. A local shop to me is building a COE AD truck on a duramax chassis. It's an awesome build too
03-13-2015, 08:07 AM | #43 | |
Re: '53 duramax
Great work in getting the front end on !!! Fits in there really nice. Why is your turbo/intake apart?
03-13-2015, 09:27 AM | #44 |
Re: '53 duramax
Tore it all apart to paint the motor parts, as soon as the body guy comes and looks at the body work, it's all coming back apart to get new head studs, injectors, gaskets thru out the motor. I just set the turbo on to make sure it would clear the firewall recess.
03-17-2015, 11:29 AM | #45 |
Re: '53 duramax
very cool build, my friend and I always thought a diesel build would be great. He'd luv this, as he has diesel everything, even his lawnmower! I'll be taggin along.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
03-19-2015, 08:55 PM | #46 |
Re: '53 duramax
Got the grill and running boards on today, grill was a royal pain in the butt! Doesn't line up quite right with the rest of the mounting holes in the fender so I guess I'll have to figure something out. Hood fits like crap too, seems to be too wide in the front...anyone have any ideas? I guess if I have to I'll split it and make it fit!
[IMG][/IMG] [IMG][/IMG] |
03-19-2015, 10:44 PM | #47 |
Re: '53 duramax
It's looking nice! Every after market grill I've had to put on any of these trucks never went well and was a PITA!
03-19-2015, 10:46 PM | #48 |
Re: '53 duramax
yeah grilles can be a pain, same with hoods. are those repop fenders? also if you replaced your cowls its possible its throwing off the fenders. Do you have your hinges on the hood? coming along nicely.
03-20-2015, 12:22 AM | #49 |
Re: '53 duramax
I like your wheel choice. What size are they? Are you going to have to tub the bed to clear the rear tires?
My 1950 Chevy build |
03-20-2015, 08:29 PM | #50 | |
Re: '53 duramax
before: [IMG][/IMG] aftereven tho they're opposite sides you get the point) [IMG][/IMG] |
