Old 11-23-2013, 10:34 AM   #551
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: My Unexpected '66 SWB-Fleet-Restomod Project!
Originally Posted by chad64chevy View Post
ya, I was thinking of that too! just wire up the dash and engine, just to heard it run!!
Yeah Chad,
I have been working very hard to figure out all of this engine management wiring! Holy crap! There is a lot of B.S. to think about...Relays for the cooling fans, electric water-pump, fuel-pump, and I also added a relay that will drop-out the fuel-pump in the event that the engine gets over 250 degrees, because I am unsure about the reliability of the electric water-pump on the street....Then we added a separate fuse block for all of the relays...Wires here, wires there, wires everywhere!
At the same time, I am trying to keep everything sanitary looking, and document how it is wired for the future. What a P.I.T.A.
Things are getting a lot closer to firing her up though!
I have almost all of the engine wiring completed, but need to run fuel lines, and block off a few vacuum ports, and finish connecting the steam tube line to the radiator...
I haven't taken many pics lately, because nothing looks much different.
I did however, fabricate a cool mount for the engine computer from aluminum, and mounted it to the side of the steering column support, so that it is tucked-up nicely under the dash, and easily removable in the event of more re-programming!
A view from under the dash.
Here is a view looking thru the gage cluster opening
Kinda hard to see, but a view from the passenger side floor.
I also messed around trying to figure out the air-cleaner/intake tube set-up that I will use. Far from done with this though, I don't really like the way it looks, so I ordered a bunch of stuff from Summit for this!
Gotta run for now!
I need to get back to work on this thing!
Modges'66 is offline   Reply With Quote
Old 11-24-2013, 11:54 AM   #552
chad64chevy
chad64chevy's Avatar
wow, that is a lot of wires! now the ecu wont be in the way of the duct work of the defrosters or the heater knob cables??
chad64chevy is offline   Reply With Quote
Old 11-28-2013, 12:09 AM   #553
Modges'66
Modges'66's Avatar
I don't have much to post right now, but I would like to wish that everyone has a spectacular Thanksgiving holiday!
Good times spent together with family & friends is never forgotten!
Have a great day everybody!!!
Old 11-28-2013, 12:24 PM   #554
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Same to you! And that is A TON of wiring!!!! Wonder ware it all goes! lol!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-28-2013, 03:43 PM   #555
Trsmotrhed
Trsmotrhed's Avatar
Happy Thanksgiving to you and your family.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 12-05-2013, 07:35 PM   #556
Modges'66
Modges'66's Avatar
A lot of wires is an understatement!!!!
You got me Chad, it looks like the computer may interfere with the heater controls/cables...But I have a built-in solution!
Since I am determined to use the billet heater knobs that I built, and I am also gonna use a Vintage air unit, therefore, I will also be using Vintage air's cable converters....
This will allow me to flip over the lever bracket on the heater controls, so that the fan switch is on top, and also flip over all of the levers!
This means that my cables would be pointing up instead of down, but clear the ECU.
My A/C controls will then work in reverse, but who will know?
I will post more pics on how I WILL make this work when I actually do it!
I may need to tip the computer slightly, but my goal is to keep everything hidden from view.
Ha-Ha!
I am finding out where it all goes as I pick away at it!
Thanks man!
I had a great day, hope you did too!
Old 12-05-2013, 10:32 PM   #557
McMurphy
McMurphy's Avatar
I will post more pics on how I WILL make this work when I actually do it!!
Dude... That is so totally like a mentality quote I can identify with !!
Rock on man, you will get this, I am sure of it
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 12-05-2013, 10:59 PM   #558
Modges'66
Modges'66's Avatar
Ha-Ha!
I hate to say it, but Chad was right!
Dude, I am sooooooo close to starting this thing right now that this issue is the least of my worries!!!
I've Been bendin' stainless fuel lines & wirin' the fuel pump!!
So close.
Old 12-11-2013, 07:33 PM   #559
flips72
flips72's Avatar
waiting on the start up video, I know its coming soon.
flips72 is offline   Reply With Quote
Old 12-12-2013, 11:17 AM   #560
aggie91
I'm just glad to be here!
aggie91's Avatar
I have been working on a bunch of different things this week, with no single goal in mind.
I figured out a kinda cool way to route my front brake lines (at least I think so) that works great no-matter which height the bags are at, bent & flared some stainless brake lines for the rear, mounted the radiator support with radiator & fan, and hung the headers & ran spark-plug wires.
So many things to work on, and sooo very far from boring!
Check out the pics!
I did the same front brake routing on mine a long time ago before the internet . So I think it is it cool too!
Do you remember the part number for the brake line that you used? I have to redo mine and can't find the PN for what I used back then....
BTW..Your truck is looking good and I know what you mean about the wiring. I did an LS swap on my son's truck and did the harness myself.
Looking Good!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-15-2013, 07:57 PM   #561
clemdaddy
clemdaddy's Avatar
i hate wiring... sorry, i mean i strongly dislike wiring. probably some medical term or phobia about it. but dude you are a wire maniac. to me its gotta come in a plastic bag and plug into something else from a plastic bag or theres no way.
you've got it going on modges. closing in on startup.
clemdaddy is offline   Reply With Quote
Old 12-15-2013, 09:42 PM   #562
Modges'66
Modges'66's Avatar
Dude! you are so right!
Tryin to sort out all of the datails, but I want to make a vid of the start-up!
I have already cranked it a bit without fuel to see if I had oil pressure!
Looking Good!
Aggie,
I have no idea what the part numbers for these hoses are, they were in a box that came with all of the other stuff that I got with the truck when I purchased it.
I will try to decipher weather they have a usable part# on them, or not.
I had to modify the bend on the banjo fitting to get the angle that I wanted though!
Thank for lookin at my thread!
Clem!
It would have been a lot harder for me if my dad wasn't sorting a bunch of this out for me!
He has been making some color-coded diagrams for me so I just have to hook-up wires!...Takes some of the thinkin out of it!
Old 12-15-2013, 10:42 PM   #563
Modges'66
Modges'66's Avatar
I have been making some slow but steady progress lately...Not nearly as fast as I would like to be moving, but moving forward nonetheless.
I finally got the wire conduits for all of the wires to my doors installed, which was no easy task, considering that the reinforcement at the front of the door blocked this area, and needed to have a portion removed to do so....Man, I love plasma cutters!
I also wired-up my gage cluster with plugs that disconnect, so that I can simply remove it at any time, in order to address any areas behind the gages.
I also installed a hidden headlamp switch under the dash, as I didn't want to add any exposed switches, and retain a really clean look to the dash.
I used a headlight switch from a '95 astro, and made a bracket to mount it under the dash...It all worked out pretty slick!
Here are some pics!
Check-out my plug-in gage cluster!
BTW! It is always good to have a cluttered workspace when performing delicate work!
My hidden Headlamp switch...
Some pics of the gages operating under their own lighting!
Old 12-15-2013, 11:56 PM   #564
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Oooooooooooh! Looks sweet!
Old 12-16-2013, 12:09 AM   #565
Bomp
Bomp's Avatar
I almost can't stand looking at your build. I swear it makes my brain hurt.
Cool stuff Man! Coooooool Stuff!
If for some reason you look at my build in a few years when I get to where your at and you say,"hey, he copied me." you will be most correct.
Looks Awesome!
Bomp is offline   Reply With Quote
Old 12-16-2013, 09:40 AM   #566
McMurphy
McMurphy's Avatar
I had the same issues with the door man.
Would have liked to see how you resolved it with your plasma cutter.
I used a step drill and a lot of curse words....
I wish I could find those multi wire connectors you used on your guages around here. I did my guage harness with a ton of flat spade connectors and though I achieved the removability, it isnt as clean as I would like.
Yours turned out awesome!
I may revisit mine now....
Love the look of the shaved guage bezel too, so much nicer without all the controls popping out of them!!
Nicely done Modges
So what is next?
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 12-16-2013, 12:37 PM   #567
65Gregg
65Gregg's Avatar
Murph if you will PM me your address I'll send you the ones from my Painless harness that I didn't use, I spliced mine back into the factory plugs. It still unplugs and works fine.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 12-21-2013, 02:20 PM   #568
Modges'66
Modges'66's Avatar
Thanks man, these gages weren't my first choice, but they will work!
There will always be room for improvements!
Looks Awesome!
Thanks Bomp!
I am sure that you know what they say!!!
"Imitation is the largest form of flattery"
Nicely done Modges
So what is next?
Murph!
I just had my dad hold a wet sponge on the front wall of the door, and burnt a 2" dia. hole where the conduit came thru....and I cut it in small increments, so that nothing got too hot. Then I lined the opening with rubber trim channel, so that nothing would chaff. The entire process took about 5 minutes, with zero profanity!
I got the plug connectors at Radio Shack, they sell many versions, male & females separately. Or just google weatherpack connectors, that is what I was going to use!
Yeah, I'm trying to keep the dash as clean as possible, BTW, that is a stock gage bezel trim ring that I polished & epoxied an aluminum piece into to hide all of the holes...
Am I on the wrong thread?
Ha-Ha-Ha!...Jus-kiddin!
HAPPY HOLIDAY'S GUY'S!!!
Thanks for lookin'
Old 12-22-2013, 09:33 PM   #569
Ta2Don
Ta2Don's Avatar
Recently got an offer from a bud, complete LT1 with computer and all accessories... Cheap
Gonna have to steal the ECM mount idea you are using...
Merry Christmas!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 12-26-2013, 09:09 AM   #570
Modges'66
Modges'66's Avatar
Merry Christmas!!!
Very cool, Don!
If I happen to take the mount out for any reason, I will take some pics of it for you.
BTW, I hope that you, and everyone else on this site had a...
Merry Christmas!
Old 12-26-2013, 09:50 AM   #571
flips72
flips72's Avatar
wow, dash looks great, and the door wiring as well. bet it was kinda scary taking a plasma cutter to a freshly painted door though, and to do it with 0 profanity great work my friend, great work. and hope you had a great Christmas.
Old 12-26-2013, 11:59 AM   #572
Modges'66
Modges'66's Avatar
Thanks for the compliments Flip!
Yeah, I did have to grow some balls to get the courage up to attempt the plasma cutting! I have been putting it off for a while, and I was pretty sure that I could do it....But, just not by myself.
I all worked out great, and was fairly easy... Just a little nerve-wracking, thats all.
Old 12-26-2013, 10:38 PM   #573
Strodder
Daring to be Different
Strodder's Avatar
Looks great
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 12-31-2013, 11:27 PM   #574
Modges'66
Modges'66's Avatar
Originally Posted by Strodder View Post
Looks great
Thanks Dennis!
Been working hard on it, but it doesn't always show.
Old 12-31-2013, 11:52 PM   #575
coulter
coulter's Avatar
killer work on the wiring man!! its a cool feeling when it starts to come to life
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
