Old 12-12-2014, 07:38 PM   #551
Re: Project Family Chummins
Very nice and congrats! Be good to see some more postings on your work with the ole truck. Forgot you moved down towards Wichita. I was just there over Thanksgiving. Drove right by you on the way to Hutchinson.
Old 12-15-2014, 03:03 AM   #552
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice on the new buildings! The point had a sweet set up and collection! Congrats!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-19-2015, 01:38 AM   #553
jbclassix
Junk Yartist
jbclassix's Avatar
So I read through your build thread again because I am starting in on a Cummins swap but on a 6.5L which means I have more work to do with electronics. I was hoping you could help me out with were you got the information about speed sensor communicators and not triggering any SES lights if using the ECM.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 02-05-2015, 02:24 PM   #554
Ackattack
Ackattack's Avatar
I don't have an ECM
If you're using a dodge 241 transfer case, apparently you can swap out the tailshaft portion of the case for a chevy one and get your speed signal from there.
Since the dodge dana 80 had a speed sensor for the RWAL system, I just used that as my speed signal and then converted that signal with a dakota digital box to calibrate my speedo. My cruise control is also ran off the same wire as well.
Ackattack is offline   Reply With Quote
Old 02-05-2015, 02:43 PM   #555
Ackattack
Ackattack's Avatar
We got moved into the new house.
The good news is the Chummins fits in the attached garage. The width with the mirrors makes it a tight squeeze.
The bad news is I have this huge shop and now I have to fill it up
Since I haven't really worked on either of my trucks since at least June, I have a few items to take care of once I get the shop set up.
The chummins needs:
the headlights aimed
sway bar fixed
rear axle seals
valve cover gaskets replaced
adjust the fueling
I also have a larger turbo for it that will need rebuilt and intake and exhaust work to get it installed (HE351CW iirc)
The 68 also needs a few things:
temp sensor hooked up
replace the power steering gear box
A/C line fixed and charged
I'm thinking of my next project in the new shop as well. Its going to be a bit of a departure from my other builds. I'm thinking of building a BMW 5 series (E39) with an LS engine with the plan of a turbo on it at some point
Old 02-05-2015, 05:27 PM   #556
Dieselwrencher
That sure is a nice shop! Enjoy that!
Ryan
Old 02-05-2015, 10:15 PM   #557
cAlvis165
cAlvis165's Avatar
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill
DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans
Project Dooley One-Ton 4x4 on 38.5s Corn-binder build
cAlvis165 is offline   Reply With Quote
Old 02-06-2015, 01:09 AM   #558
jbclassix
Junk Yartist
jbclassix's Avatar
I don't have an ECM
I'll have to dig into my schematics to see if I can eliminate the ecm all together like you did. if I don't need the ecm for cruise then all I need is a gasser cruise module and wiring. I was expecting I'd have to go with the DD converter boxes. I think 96 and down dodges still had a VSS on the tail shaft. I don't know when they made that switch.
-Jeremy
Rebuilding an NP205
Old 02-06-2015, 09:21 PM   #559
Dieselwrencher
On the both the 241d and 241DHD's 97 was the last year for it. 98 up 241d and 241dhd had none. They went to picking the speedo signal up from the speed sensor in the rear diff. Bit, you should be able to put the chevy stuff on the back of a dodge 241d. It's nice how universal new venture kept them.
Ryan
Old 03-07-2015, 10:39 AM   #560
Ackattack
Ackattack's Avatar
Old 03-08-2015, 06:51 PM   #561
Now that is nice!!
Old 03-08-2015, 07:48 PM   #562
y5mgisi
Second Chance Program
y5mgisi's Avatar
I would kill for that shop.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-08-2015, 09:04 PM   #563
COS399
COS399's Avatar
I'm Jealous. Nice shop and nice lift.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 03-23-2015, 12:51 PM   #564
Ackattack
Ackattack's Avatar
Ran into a little problem: I noticed some coolant leaking the other day, so I pulled the truck into the shop and started to investigate. It was coming from the area around the thermostat. It was difficult to see, so I broke out a mirror to have a better look. Unfortunately it was the head gasket right above the thermostat
So yesterday I started the teardown. Everything went fairly smoothly until I got to removing the push rods. The back two pushrods are back, under the cowl and I couldn't just pull them out. I tried lifting the head along with the pushrods, but the pushrods were still in the block. At that point I figured my options were pulling the whole engine or drilling holes in the cowl.
So now my truck has "pushrod access holes"
Luckily I was able to get the pushrods out. Upon removing the head, sure enough the head gasket was damaged right above the thermostat. Everything else looked good. For having probably 250k miles on the engine, I could still see cross hatching on the cylinder walls, I think its pretty good.
I'm hoping to get the head machined tomorrow and start putting it back together on Thursday.
Old 06-21-2015, 08:09 AM   #565
steppside69
steppside69's Avatar
Awesome build. Planning on putting a 6bt in mine soon.
How did the repair go?
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 06-25-2015, 10:43 PM   #566
Ackattack
Ackattack's Avatar
The repair went well, and the trucks been running good!
Onto a new adventure in life: I'll be putting my shop to use. My wife and I bought a CNC plasma cutting table and will be starting a metal cutting business. We're going to be cutting some art type projects as well as make some vehicle parts. We're probably a month or more away from actually getting it up and going and open for business.
So as part of this, I've decided to sell the Chummins and buy a Jeep as a development/marketing vehicle. We'll also get another pickup with a flatbed on it to haul sheet metal/plate, tow trailers, etc.
It will probably be a week or two before I get a few things cleaned up to sell the Chummins. More to follow.....
Old 07-12-2015, 10:02 PM   #567
95 S_Trucker
95 S_Trucker's Avatar
Sounds like it's time to put a flatbed on the chummins and call it a day. Then you could tow a trailer and haul metal on the back.
95 S_Trucker is offline   Reply With Quote
Old 07-22-2015, 03:37 PM   #568
Ackattack
Ackattack's Avatar
I thought about it, but I decided against it. Main thing is since I made it into a SWB truck, it wouldn't be long enough. I'll be using 5x10 sheets of steel, so a 6.5' bed doesn't work so well.
I bought a 1990 K3500 extended cab with a 454 and a flatbed to be the new work horse.
Old 01-19-2016, 12:25 AM   #569
Ackattack
Ackattack's Avatar
Well the Chummins is sold. I mentioned it on a diesel facebook group and someone jumped on it. Sad to see the truck go, but it was time to move on.
BTW, the flatbed now has a 4.8L LS engine in it .
Old 01-20-2016, 12:34 PM   #570
y5mgisi
y5mgisi's Avatar
Interesting! I'll have to check out your other projects.
