Old 03-10-2015, 08:32 AM   #576
Kim57
Kim57's Avatar
Re: 1958 Apache 38 Dually Dump Project
Nice looking tank.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-11-2015, 02:55 AM   #577
RockTonka
RockTonka's Avatar
Thanks Kim, it's a big tank but with the flat bed frame work we knew we could push it up farther than normal...fits in nice for 44 gals.
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 03-11-2015, 03:06 AM   #578
RockTonka
RockTonka's Avatar
We finished fitting and welding the exhaust up tonight...gonna run through some FM 40s under the door to behind the side boxes to slash cut tips at the top rear of the boxes...might be a little loud.
My build thread
Old 03-11-2015, 08:11 AM   #579
Kim57
Kim57's Avatar
Very nice looking.
Kim
My build thread
Old 03-15-2015, 04:40 AM   #580
RockTonka
RockTonka's Avatar
Thanks for the continued support Kim!
Worked on the rear of the bed, added some detail work.
My build thread
Old 03-15-2015, 08:46 AM   #581
Advanced Design
Advanced Design's Avatar
The exhaust and rear bed detail is very nice!
Advanced Design is offline   Reply With Quote
Old 03-15-2015, 10:33 AM   #582
Kim57
Kim57's Avatar
Your fab and detail is some of the best on this site.
Kim
My build thread
Old 03-15-2015, 10:42 AM   #583
6BT 56
6BT 56's Avatar
Looking good guys. I hope you never meet a guy who likes to,put square holes in everything. He'd be like your evil twin. Lol. What are your plans for sound deading for the cab. Noise is cool out side but as I get older I like it less inside . That thing is going to have a rumble to it for sure .
Keep up the great work.
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 03-15-2015, 02:35 PM   #584
OrrieG
OrrieG's Avatar
Am I missing something? It looks like the exhaust goes thru the upper dump bed side rail??? Did you decide to eliminate the dump feature?
OrrieG is offline   Reply With Quote
Old 03-16-2015, 12:15 AM   #585
RockTonka
RockTonka's Avatar
Thanks AD!
Kim
Thanks Kim, you and many others have set the bar high...we're just trying to keep up!
Sound deadening matting will be used where possible and the bottom half of the interior will be rhino lined...will help a bit
The exhaust tip is capped off flat at the back. The exhaust tubing comes up behind the side box and goes into the side of the tip...dump feature is alive and well.
My build thread
Old 03-16-2015, 12:35 AM   #586
RockTonka
RockTonka's Avatar
Welded some angle to the tank and some tabs on the frame, 3/8" rubber strips in between tank and frame at the three mounts and tank is bolted in.
My build thread
Old 03-16-2015, 08:27 AM   #587
Kim57
Kim57's Avatar
Nice.
Kim
My build thread
Old 03-20-2015, 02:38 AM   #588
RockTonka
RockTonka's Avatar
filler neck access...
My build thread
Old 03-20-2015, 08:19 AM   #589
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
Old 03-20-2015, 09:06 AM   #590
Advanced Design
Filler access looks really good!
Old 03-20-2015, 12:11 PM   #591
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Everything looks super! That tank is awesome!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-21-2015, 03:21 AM   #592
RockTonka
RockTonka's Avatar
Looks good.
Kim
Thanks guys!
My build thread
Old 03-21-2015, 03:57 AM   #593
RockTonka
RockTonka's Avatar
We're starting to fit the cylinder/scissor lift into the frame and are figuring out a few things...
It's going to have to sit on top of the truck frame (driveline clearance) so we removed the rear crossmember we had previously flipped upside down to support the lift framework (won't work like we had thought ) and added some internal gussets into the frame where the front bed feet hit, the lower lift pivot will sit, and the frame splice is.
We then boxed the frame in from just behind the rear cab mounts, over the gussets, and back to the previously boxed rear portion of the frame.
I'm not worried about the integrity of the frame in this area...
Got some smoothing to do tomorrow then onto the lift mounts...
My build thread
Old 03-21-2015, 08:35 AM   #594
Advanced Design
Yep, that is one stout frame section! Looks really good.
Old 03-21-2015, 10:43 AM   #595
Kim57
Kim57's Avatar
As always very nice work.
Kim
My build thread
Old 03-21-2015, 06:47 PM   #596
cAlvis165
cAlvis165's Avatar
Very nice fellas!:metal
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill
DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans
Project Dooley One-Ton 4x4 on 38.5s Corn-binder build
cAlvis165 is offline   Reply With Quote
Old 03-22-2015, 01:44 AM   #597
RockTonka
RockTonka's Avatar
Kim
Thanks! We're glad to have that behind us
My build thread
Old 04-06-2015, 03:18 AM   #598
RockTonka
RockTonka's Avatar
We got the exhaust back from being ceramic coated...came out pretty good.
We added one last section of through tube to the frame rails between the spring hanger brackets on each side and got a good start on the lower lift pivot.
My build thread
Old 04-06-2015, 05:51 AM   #599
47 Fasttoys
47 Fasttoys's Avatar
Thanks for the details and pictures, your at a good point for me right now as I may be doing a tilt on mine soon. Do you know how much weight you will be able to tilt? Are you going to use hydraulic or electric ram? Your fab skills are top notch.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 04-06-2015, 09:56 AM   #600
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
