#51 |
![]() Join Date: Nov 2004
Re: What brand 15 inch tires are you running
Bfg 235/75/r15
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#52 |
Ya know it's all in your taste and style. I like to stay in the stock size range and use the same size on all fours, that way I can rotate and get the most milage out of a set for my money. It seems that these days I get alot more milage than I used to out of a set. Seems like I don't light em up as often. Not sure if it's because of the price or my advancing age.
But man there are so many choices. When you start getting into fat, racing, performance tires and wheels the sky's the limit.
69 sweet long fleet, David |
#53 |
Questionable
I looked my damned truck up and down but I couldn't figure out what brand my tires are! I'll post a picture of them anyway, maybe one of you guys knows
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#54 | |
Neighborhood Pickle Slinger
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
#55 | |
here are the latest pictures with the new tires! ![]() ![]()
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan Last edited by 72BLUZ; 02-16-2008 at 11:23 AM. |
#56 |
Everyone runs the BFG's. Nothing wrong with those, but I wanted something different & went back to a good reliable tire from back in the day. They ride great and handle great. Did I mention they look great also. And at a good price. "Uniroyal Tiger Paws". Been around for ever.
1997 GMC Sierra Ext 1965 Mustang |
#57 |
I had BFG T/A's on my '79 Suburban, 255/70-15, for about four years, maybe 20,000 miles or so. Over a period of a few months, three failed drastically, and judging from the bubbles, the fourth one was fixing to go real soon. None had ever seen less than 30psi, and they were never used off-road or with extreme loads. They all had the same serial number on the side, so maybe it was just a bad batch. I decided not to buy any more T/A's after the third one took a dump.
I now have two T/A's on the rear, bought before the third tire failed, and two Yokohama Avid ST's on the front, same size as the old ones. I think the Yokes might be a little better tire, but they're only a year or so old, so the jury's still out. Diameter is supposed to be 29.1", on 15x8 rallys. Last edited by jimfulco; 02-16-2008 at 10:24 AM. |
#58 |
Also, Firestone FireHawks Indy 500 275/60/15 on all 4 corners. Great rain traction.
1972 Cheyenne Super 10 LWB 1965 Nova SS Evening Orchid 1967 Nova Wagon Factory Disc (1 of 565), 327/PG 1964 Ford Fairlane 500 HT 1962 Nash Metropolitan Convertible (Wife's car) Last edited by 67L30WGN; 02-20-2008 at 03:43 AM. Reason: Figured out how to post picture off Picasa |
#59 |
lots of good stuff in here guys, now to weed thru this and make a decision.
Does anybody run the occasional drag radial?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#60 |
Does anybody have the occasional rubbing on the front. Mine will hit my inner fender well (I assume) on a dip at a moderate speed? for that reason I thought about the 255 front and 275 rear. Right from the pictures I like the looks of both
#61 |
[QUOTE=Custom 68;2581164]Does anybody have the occasional rubbing on the front. Mine will hit my inner fender well (I assume) on a dip at a moderate speed? for that reason I thought about the 255 front and 275 rear. Right from the pictures I like the looks of both[/QUOTE
i had that problem, just recently changed mine. i went to 255/60 15 for the steer axle and 275/60 15 for the drive axle. only problem i have now is the rear needs dropped another inch and the 15 inch rims are hitting the lower control arm in a sharp turn. all this will be modified soon.
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
#62 |
Thanks 72BLUZ. They look good. I will have to check to see if I thought I would have clearance problems with the LCA. I ran 255 60-15 on all 4 corners for several years and didnt have any problems but I have chenged my suspension around now so I might.
Your truck looks great. Dave
#63 |
![]() Join Date: Jan 2000
I am using Uniroyal Tiger Paws 235/75/15. for the most part, my tire brand is used take-offs for $25-35 each mounted/balanced.
...How I got Tiger Paws... Back betwen 1997-1998, I repalced tires when they weren't legal to pass inspection with used Firestone ATX for 25-35 each mounted and balanced. I had a set of 4 on the truck when Firestone issued their recall in 1999. So...I got a set of new Tiger Paws for free! Three are still on the truck today. Most likely I will replace these Tiger Paws with used tires when these tires wear out to the point that they can't pass inspection. |
#64 |
Right now I am running General Ameria-Star's 235/75/15 rear 235/70/15 front. They are used but they had some good tread left on them. Only problem is that they have little to no snow traction or lose gravel (Rear end of the truck tries to "walk" around the front when shifting gears.) I am looking at getting a set of Kuhmo Road Venture AT KL78 tires for the truck, where I live having a set of on/off road tires even on a 2wd is a good idea.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." [Cherokee saying] 2001 Dodge Ram Sport 1500 4x4. (old ride) 1987 GMC V1500 Sierra Classic ("new" ride) |
#65 |
What tire size do you have?
How much is the truck lowered?
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
#66 |
Florida Edition
![]() ![]() Join Date: Oct 2010
This post is 7 years old.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
