Old 07-19-2009, 11:13 PM   #51
19723DR
19723DR's Avatar
Re: 1970 VA Longbed Project
Bagged, shaved, on Dubs..... Sounds like you have a lot of fun planned.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 07-21-2009, 01:45 AM   #52
VA72C10
VA72C10
VA72C10's Avatar
Hoping so...hope to get a lot more done over the next month. Starting next week
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-21-2009, 05:48 AM   #53
n2billet
Village Idiot....
n2billet's Avatar
You have any pictures of the painted frame?
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 07-24-2009, 01:37 AM   #54
VA72C10
VA72C10
VA72C10's Avatar
Sorry, just noticed the post...I haven't painted it yet, but should be in a week or so and will post up then...but by then you might have yours done
Old 07-24-2009, 08:05 AM   #55
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Definitely sounds like it is coming right along. Can't wait for some more pics!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-28-2009, 12:59 AM   #56
VA72C10
VA72C10
VA72C10's Avatar
I will have more pictures tomorrow. Went over to work on it tonight and got a lot done. Bed is off, mocked up some of the airbag stuff before to see how it will fit with the bed on. Front clip is off as well. Was pleasantly surprised to find NO rust on the front of the cab. Very excited about that. Got the core support off and radiator/tranny cooler drained. Going to take the engine out probably tomorrow night and will take some pictures. Decided I'll be taking the cab off too to make it a frame-off. What the heck at this point
It will make it easier to finish up the cab mounts and paint the underside nicely. Going to paint everything off of the truck for better results. Can't wait to get started on the suspension!
Old 07-29-2009, 12:49 AM   #57
VA72C10
VA72C10
VA72C10's Avatar
Here are the pictures. These I took when I got there tonight. Three hours later it looked almost the same minus the steering column, wiring, e-brake, etc. So after the engine and tranny are pulled, it's 4 bolts for the cab and it's off.
Old 07-29-2009, 12:58 AM   #58
VA72C10
VA72C10
VA72C10's Avatar
Wow, sorry they're so fuzzy. they looked fine on the camera
As you can see the exhaust is already close to the trailing arms and runs under the crossmember so we'll be running it through the crossmember. Going with all new exhaust as well.
Here's a few pictures of the rust areas needing attention still and some we've started to fix as well as the nice heated springs I'll be swapping out for bags. Let this be a warning to those considering heating springs...notice they are actually sitting on each other at the bottom.
Passenger rear floor
Patch for passenger rear floor
Driver's rear floor. I will have a box behind the seat so we cut out the rust and put this panel in running it all the way to the cab corner eliminating the factory "hole" there.
New carrier bearing (will probably be flipping before I put the bed back on)
Heated springs
Old 07-29-2009, 01:01 AM   #59
VA72C10
VA72C10
VA72C10's Avatar
and before someone says something about the itsy bitsy air cleaner....I just put it there so I don't drop dirt/bolts down the carb...
Old 07-29-2009, 02:43 AM   #60
VA72C10
VA72C10
VA72C10's Avatar
Here's a current rendering of the finished product. Thanks, Skorp
Old 07-29-2009, 02:54 AM   #61
OARNGESI
OARNGESI's Avatar
Gona be really nice
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 07-31-2009, 07:38 AM   #62
gcburdic
Restoration Virgin!
gcburdic's Avatar
Originally Posted by VA72C10 View Post
Got a bunch of parts, some new Rod doors panels and a good set of hood hinges for a great deal (thanks Gburdic) a 70 outer grille i have plans for, and some 5 lug rallys on bald tires i'll use temporarily when i do the 5 lug swap. Hopefully will have a chance to work on this in the next few weeks before it gets too cold
Hey Jonathon,
I don't know why I haven't subscribe to this earlier, but here I am....ghlad to help out with the door panels....they'll look good with what you are planning (if it doesn't change again).....I like the rendering of the finished product...looking forward to watching it come together!!!....Also, saw you spent some time w/ LHM...hopefully he inspired you as well!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-31-2009, 07:52 AM   #63
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That rendering looks killer!
-Nate
Old 07-31-2009, 08:43 AM   #64
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by gcburdic View Post
Hey Jonathon,
Andy....he made me want to quit the build
just kidding of course. Went to drop off a part for another boardmember and ended up having a 3-hr mini-board meet
You came on board at the right time as I finally am doing some real work on it. The last year has been buying parts and changing my mind
Thank Skorp for that. It's a photo I pulled from another member (sorry, saved it a year or so ago and forgot who it is) and had trim/rally rims, vent windows, etc and Skorp P-shopped it for me. I can visualize the truck but it never hurts to have a hard copy to drool over and show others
Old 07-31-2009, 09:03 AM   #65
VA72C10
VA72C10
VA72C10's Avatar
Well, got the engine and tranny pulled last night. Found out the PO had NO bolts holding the motor mounts to the front crossmember. In fact, the passenger mount fell off of the rubber mount on the engine as soon as we pulled the block. Meaning no bolts from the mount to the block OR crossmember. Also the tranny mount only had one bolt in it and it was loose. Also the rear U-joint fell apart when we pulled the driveshaft and it had NO grease in it. And the tranny was just installed last year...think he should have re-used the mount???
I'm glad I'm doing a frame off to correct these issues. I will know everything about the truck and know it will be solid and safe as well as hopefully a sweet looking ride
Here's the rest of the pics from the evening
engine will at minimum be cleaned, painted body color, and dressed up with a BUNCH of chrome goodies. May do some more power upgrades as well depending on timing/budget
010 block at least
Just the cab left now...
Waiting patiently to be purdied up
Old 07-31-2009, 09:20 AM   #66
70k52wd
Blaze-Air
70k52wd's Avatar
It's funny that I thought you sold this. It's coming along very nicely.
70k52wd is offline   Reply With Quote
Old 07-31-2009, 10:14 AM   #67
gcburdic
Restoration Virgin!
gcburdic's Avatar
Nice...progress!!!.....That mount looks terrible!!!
JMHO....with the engine, if you aren't going to do anything to it, I would suggest at least replacing all the gaskets you can....I didn't do anything to my motor, but spruce it up with paint and bling, but never did the gaskets....DUMB I know....I can't tell but I think the oil pan gasket or the front seal is leaking!!!...YUCK.....
Geoff with a G
Old 07-31-2009, 11:35 AM   #68
VA72C10
VA72C10
VA72C10's Avatar
Well, I might wish I sold it when I add up the receipts
The good news is the motor is a fresh rebuild with less than 2500 miles on it. No leaks I ever saw or see now. The tranny pan leaks but I'm putting some bling there and the oil pan so it should be good to go.
Old 08-08-2009, 10:54 PM   #69
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looking great man. Cant wait to see more pics. Keep at it.
--Josh
Old 08-10-2009, 09:37 PM   #70
VA72C10
VA72C10
VA72C10's Avatar
Thanks, I'll have more pictures in a few...
Old 08-10-2009, 10:16 PM   #71
nuke1
nuke1's Avatar
that thing is coming along great, when do you plan to have it done?
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 08-11-2009, 02:13 AM   #72
VA72C10
VA72C10
VA72C10's Avatar
I wanted it done for the summer shows but that's not going to happen...hopefully it'll be done in a couple months and catch the few fall shows....
Old 08-11-2009, 02:14 AM   #73
VA72C10
VA72C10
VA72C10's Avatar
Here's the money shot...frame on a trailer to get it out of the way and outside for me to clean. Cab on stands and everything apart...
Old 08-11-2009, 07:35 AM   #74
70k52wd
Blaze-Air
70k52wd's Avatar
Looking good. Your going to have a brand new 70. How cool is that.
If that's a kitchen in the shop, you have it made. Why would you ever leave.
Old 08-11-2009, 08:11 AM   #75
splehigh
splehigh's Avatar
Looking good!!!
splehigh is offline   Reply With Quote
