Old 08-07-2013, 09:27 PM   #51
Mattman2010
Mattman2010's Avatar
Re: Ultra Family and Hauler Mobile
There ya go! That will work!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 08-07-2013, 10:08 PM   #52
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Originally Posted by ryanroo View Post
cutting the rear body would be bad. do this instead
Did a guy that came to look at something you had for sale on craigslist have that?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-30-2013, 04:19 PM   #53
Dieselwrencher
No real big progress on this lately. Been spending time with the family, and trying to tie up other loose ends. I did finally get the injection lines de rustized, primed and painted. You wouldn't think a set of $600 lines would freakin rust! Oh yeah, the builder cheaped out and used non coated lines to start with!
Ryan
Old 08-31-2013, 10:55 AM   #54
6BT 56
6BT 56's Avatar
Hey ryan . A little off topic here buy you always have good insite , you know how the 2wd guys Z the front frame section to get lower . Could a guy Z the frame a few inches to acheive a cheap lift ? Just go the other way ? Im looking to start building a s 10 with my boy and i thought a bit of lift would be cool , A body lift will just fall apart with the way kids drive and this would be free , minus labour . fe stuff would be all stock to so it would still drive the way it was meant to . Just a thought . Sorry to hyjack but you seem like the man to bounce things like this off of . (Thats a complement ) Lol.
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 09-03-2013, 02:52 PM   #55
Dieselwrencher
I don't see why it wouldn't work. A friend of mine built a truck when I was in college and he stacked two K20 frames together. But anyhow, I don't see why a Z'd frame wouldn't work as long as the joints are welded and gusseted right.
Ryan
Old 09-15-2013, 12:13 AM   #56
andrewmp6
6bt 65 get on a s10 forum and see if you can get a used lift cheap.When they do a solid axle swap they end up tossing the whole front suspension.
andrewmp6 is offline   Reply With Quote
Old 10-08-2013, 05:39 PM   #57
Dieselwrencher
I keep getting pulled off this project so it's taking way longer than I'd like. But, what do you do? I've gotten the fuel lines ran and got the injection lines back on. I still have to add protective covering in areas and secure some of the fuel lines. I installed a pro comp black pump on the LH frame rail for the lift pump. I have to wire the pump, put fuel in the tank, and prime the system. I also repainted my turbo compressor cover as the red just didn't do it for me. I'm going to be painting some items under the hood body color. I think it looks much better. I also installed a new belt tensioner and had a fiasco with my new a/c compressor. I finally got a non damaged one and installed it.
I'd like to start the engine this weekend but we'll see how other things go. I've still got a decent amount of work left to do to the truck to finish it, and I'm switching the front over to an 05 style as well. I have to repaint the top part of my new bumper, and I might get a different HID kit as the one I got doesn't have a wire harness.
Ryan
Old 10-08-2013, 09:02 PM   #58
brimc
brimc's Avatar
That is looking great! I dig the red. Can't wait to hear it.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 10-09-2013, 10:49 PM   #59
Dieselwrencher
Thanks! Me too.
Ryan
Old 10-10-2013, 08:46 PM   #60
Dieselwrencher
I didn't have room for the air filter so I moved the vacuum reservoir and added another vacuum reservoir on the LH side behind the battery tray. I'm trying to get the other intercooler pipe painted. I've already painted the RH one, the elbow for the turbo, the intake horn and grid heater too.
Ryan
Old 10-20-2013, 11:46 AM   #61
Dieselwrencher
I've been working on it when I can get the spare time. I'm working on eliminating un-needed wiring from the V10, I also need to move the speed control servo from the RH side to the LH side. I got in an F-550 that I have to basically restore, and all the V10 stuff is parts or scrap. So, today I got the missing A/C harness and a plastic wire cover that I broke when I installed my engine for the second time.
Intercooler piping sprucing up
I made all the battery cables, positive and negative, and also made a ground cable to go from the engine to the frame.
Air filter pipe and placement.
Here's the second pile of scrap connectors and wire I removed from the stock V10 harness.
Here's what I'm left with. The oil pressure sender wire, coolant temp sender wires, crankshaft position wires, and the old coil power wire which I plan to use for key on injection pump power. The A/C is all in the truck harness which is kind of odd.
Here's the loom cover/holder I got and cleaned it up and painted it with trim paint.
I got my fan blade cleaned up and painted as well.
Here's what a V-10 engine compartment looks like.
Here's with the 24v Cummins.
Yesterday I did more searching and found the source of my no power to my starter solenoid. When the tcase exploded and the driveshaft smacked the frame, it cut half the wires to the neutral safety switch. I repaired them to check the starter operation. It works! Sweet! Now to seperate the wiring for the 4x4 ranges, and shorten the wiring to make a clean install. I also started removing the harness that goes across the top of the fire wall so I can move the speed control assy to the LH side. I've got that about half way done.
Ryan
Old 10-20-2013, 07:16 PM   #62
6BT 56
6BT 56's Avatar
This is by far my fav build on here rite now . mainly becouse my family needs one of these as well ! Cant wate to see finished product. Im sure your wife feels the same !
Old 10-21-2013, 03:28 PM   #63
Dieselwrencher
Thanks, and yes she does. I want it done too so I can work on my ugly duckling, and I have some changes I want to do to the Longhorn and test it before the white stuff flies. I've been wanting an Excursion for a long time. I just really never had a real reason to have one before we had kids. Now the ol crew cab ford is stuffed.
Ryan
Old 10-25-2013, 03:51 PM   #64
Dieselwrencher
I've been working on the wiring on this beast. I got the lift pump wired up, oil pressure gauge, water temp gauge, fuel shut off solenoid wired, cruise servo moved and wired, and started wiring the ford external voltage regulator. I have the cruise all hooked up and the throttle cable is hooked up as well. I have to hook up the TV pressure cable and add some return springs on the linkage. I'm having some issues getting the lift pump to pull fuel from the tank. I may have to remove the line and help it out. I'm still waiting to hear on my A/C lines, and I'm waiting on some wiring connectors so I can finish up the wiring.
Ryan
Old 10-26-2013, 12:45 PM   #65
6BT 56
6BT 56's Avatar
Looken good . Has that engine made any smoke yet ? It was in another truck before wasnt it ? Real interested in how the 24V with the old school pump works .
Old 10-27-2013, 02:38 AM   #66
Dieselwrencher
No, no smoke yet. This engine was one I pulled from a truck and had a VP on it. My previous VE 24v had a bad dealing with moisture and the long block is sitting in the corner of the shop. I've got some things I need to finish before I fire it up.
Ryan
Old 10-27-2013, 08:01 AM   #67
ryanroo
ryanroo's Avatar
Looking pretty darn good Mr. Lusk!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 10-28-2013, 02:49 PM   #68
Dieselwrencher
Thanks Mr.Roo. Little by little. Yesterday a guy I know just got an 05 Ex and he offered it to me. SOB! I might have to do another one after this one..............
Ryan
Old 10-29-2013, 10:38 PM   #69
Dieselwrencher
Still working on it. Working on wiring and doing paint work. Here's the new valve cover for it.
Ryan
Old 10-30-2013, 12:36 AM   #70
jbclassix
Junk Yartist
jbclassix's Avatar
puuuurrrrdy
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 10-30-2013, 08:04 PM   #71
Dieselwrencher
Smile Re: Ultra Family and Hauler Mobile
Thanks. I put it on today. Too bad it wasn't just a unbolt and bolt it on deal. Oh no, these autoworld mounts have the engine pretty far back and pretty high making it real hard, oh wait, impossible to remove the valve cover. You have to remove the trans mount and lower the trans to get enough room to get the valve cover to clear everything to come out.
Now this thing has a chevy part on it too! I used a 67-72 tail gate hinge/strap to make my air intake support bracket out of. I also decided to body work this pipe as it had lines on it from being bent and I knew it would drive me nuts.
Ryan
Old 11-08-2013, 04:59 PM   #72
Dieselwrencher
Been getting some stuff done on this thing. Repainted some piping and the front bumper.
I got the AC lines installed, got the last bolt in the turbo compressor housing, wired the external voltage regulator, wired the lift pump, had my brother prime the lift pump and fix a leak on the return side, and I set the intercooler back in there so I could see if my hot pipe would clear the AC lines. I also got the throttle linkage made. Built a bracket for the throttle pressure valve for the trans as well. Filled with fluids, fought and fought it but finally got it to run! Then I had some tach issues and figured that out. Waiting for a new tone wheel for that. I'm planning on a test drive this weekend................
Ryan
Old 11-09-2013, 01:29 AM   #73
Average Joe
Average Joe's Avatar
Nice work! You make it look easy.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 11-10-2013, 01:35 PM   #74
Dieselwrencher
Thanks Joe!
Ryan
Old 11-10-2013, 07:02 PM   #75
6BT 56
6BT 56's Avatar
So the wknd is almost over . Has there been a test drive ?
