Old 03-27-2014, 12:02 AM   #51
Rusbuilt
Rusbuilt's Avatar
Re: Lss3
Very nice shifter!
Rusbuilt is offline   Reply With Quote
Old 04-08-2014, 12:39 AM   #52
69cunningham
69cunningham's Avatar
Re: Lss3
I made a little progress on the exhaust. It started with a Flowmaster 2.5” SS tubing kit (FLO-815936). I made a couple of wooden jigs to fit the exhaust to.
69cunningham is offline   Reply With Quote
Old 04-14-2014, 09:00 PM   #53
69cunningham
Re: Lss3
The exhaust work has been going slowly. I just cut down an S bend to get a 2” offset. It positions the mufflers just in front of the sway bar, ½” above the trailing arms and there is about ¾” clearance between the cab and the tubing, Thinks are a little snug. I might have been better with a different sway bay that would not have competed for the space.
Old 04-14-2014, 09:49 PM   #54
Rusbuilt
Rusbuilt's Avatar
Re: Lss3
Looks good!!
Old 04-14-2014, 11:10 PM   #55
mcbassin
Still Learning
mcbassin's Avatar
Re: Lss3
Very nice progress
mcbassin is offline   Reply With Quote
Old 04-19-2014, 08:09 PM   #56
69cunningham
Re: Lss3
I got the crossover pipe installed today. First, I shimmed the exhaust to be centered in the cross member cutout. The crossover is positioned slightly in front of the rear seal on the transmission. I used a die grinder to cut 2” holes in the 2.5” tubes. Like the rest of the exhaust, the crossover was tack welded in place.
Old 04-19-2014, 10:45 PM   #57
birdistheword
birdistheword's Avatar
Re: Lss3
Good looking build.
Erik
1969 Chevy K20 6.0L/4L80E/NP205
1971 Chevy C30 Cheyenne Longhorn 454/TH400
1979 Chevy K30 dually currently in pieces
birdistheword is offline   Reply With Quote
Old 05-07-2014, 10:52 PM   #58
69cunningham
Re: Lss3
I haven’t made a lot of progress lately. I keep trying to complete the exhaust, but I have been having issues figuring out various details. I think I now have a plan. I will have some pictures soon.
Today, I got the fuel pressure gage installed. The gage is an Aeromotive AEI-15633 with a Casper CEI-107133 adapter. Installation required removing the cap and Schrader valve. I used Permatex Aviation sealant on the threads. It is supposed to work with gas.
Old 05-18-2014, 03:58 PM   #59
69cunningham
Re: Lss3
The first exhaust hangers and the O2 bungs got installed this weekend.
The rubber mounts are from Pypes, TPHV6. They Are for a 2000 something Mustang and have an SS bracket. I made the other part of the bracket from 3/8” SS rod.
The O2 bungs got notched to fit tightly to the 2.5” tubing. The bungs were part of the GM controller kit.
Old 05-18-2014, 03:59 PM   #60
69cunningham
Re: Lss3
One more pic:
Old 05-18-2014, 05:16 PM   #61
mechanic350
mechanic350's Avatar
Re: Lss3
Great build. Planning the same motor and trans combo. Subscribed. Looking great so far
1972 Chevrolet swb fleet side. - SOLD
2018 Toyota Tacoma but hunting for another C10
Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303
Instagram: https://www.instagram.com/72c10shortbox/?hl=en
mechanic350 is offline   Reply With Quote
Old 05-24-2014, 09:08 PM   #62
69cunningham
Re: Lss3
I tacked the manifold flange on. When I tried to remove the H pipe, the trans was in the way. I had to jack up the trans to get the pipe out.
Old 05-24-2014, 09:16 PM   #63
69cunningham
Re: Lss3
Time to install the band clamps. Paper was used to shim them so they were properly aligned.
Old 05-24-2014, 10:50 PM   #64
mcbassin
Still Learning
mcbassin's Avatar
Re: Lss3
Awesome work on the exhaust! looks great.
Old 05-25-2014, 08:51 AM   #65
Rusbuilt
Rusbuilt's Avatar
Re: Lss3
Looks great!!
Old 06-10-2014, 10:11 PM   #66
69cunningham
Re: Lss3
I continue to work on the exhaust. It is going pretty slow. I ended up taking it apart in a couple of places and re-welding to get better fit.
I made a bracket that holds the mufflers from rotating since the band clamps allow rotation.
I also made some more wooden jigs to hold the mufflers in the right position so the tail pipes could be worked on. The passenger side tail pipe is starting to take shape. It’s made it over the rear end, but it still needs another turn to head it out the back. The driver’s side should be easier. I have test fitted the passenger pipes on the driver’s side and they look good so it should be possible to copy the parts.
I still haven’t decided how the pipes should exit the truck. I’ve been considering notching the stock bumper just outside of the frame rails, like the fleet side bumper from LMC Truck. Of course it would be way easier to drop them below the bumper.
Old 06-27-2014, 09:37 PM   #67
69cunningham
Re: Lss3
I finally made some progress on the bumper exhaust cut outs. After considering a bunch of ways to cut them, I decided to use a hole saw mounted in a mill. The tricky part was figuring a way to hold the bumper securely at the proper angle. I ended up using some 1X2” tubing with tabs welded on it that picked up six mounting points on the bumper. The tubing was clamped into the mill vise. A wooden shim has you near the cut to reduce vibration. The hole saw wasn’t deep enough to through the edge. Fortunately, the final cut is pretty straight and can be cut with an angle grinder.
At the end of the first cut, the hole saw caught the edge of the bumper and ripped out the threads where the arbor screws into the saw. This weekend I will weld the arbor to the saw so the last cutout can be finished.
Old 06-27-2014, 10:21 PM   #68
tune_1
Re: Lss3
Really like the work that you are doing. Thanks for posting.
Dwight
tune_1 is offline   Reply With Quote
Old 06-28-2014, 01:32 AM   #69
boynton
boynton's Avatar
Re: Lss3
One thing you can try is running the saw/drill in reverse once you get going. It is obviously slower but this is what I did when I cut the holes for a/c in the dash of my red step side. Running in reverse still cuts but prevents the teeth from catching on the metal edges.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 07-05-2014, 11:39 PM   #70
69cunningham
Re: Lss3
Here’s the bumper with the notches finished.
The bottom edge of the bumper has several irregularities.
Since it will need to be re-chromed, I decided smooth to bottom.
Old 07-06-2014, 10:15 AM   #71
boynton
boynton's Avatar
Re: Lss3
Nice work.
1970 SWB Step-Side
Old 07-31-2014, 12:24 AM   #72
69cunningham
Re: Lss3
It’s been a while since my last post. There has been progress though not as much as I would like. Some off the work has involved making things over again. Earlier I pointed out that it was difficult to remove the exhaust because it interfered with the trans and cross member. I could do it with the cab off, but it would be next to impossible with it on. To help I ended up building a new cross member that doesn’t attach to both the top and bottom of the frame. Now the trans can be jacked up slightly, then the cross member can be twisted out. If I had it all to do over, I would move the exhaust crossover behind the trans, but that would be a lot of work thrown away. The cross member will be enough.
Old 07-31-2014, 12:26 AM   #73
69cunningham
Re: Lss3
Several months ago when the bell housing was bolted to the engine I notice gaps on each side where the flywheel was visible. These could let water and dirt into the clutch. A couple of weeks ago I discover the solution on EBAY. Hawks Third Gen was selling some plastic dust covers for 98 to 02 Camaros. I haven’t installed them yet, but they look like they will do the trick. The AC Delco part numbers are 24261712 and 24261714.
Old 07-31-2014, 12:27 AM   #74
69cunningham
Re: Lss3
One of the big hold ups has been finishing routing the exhaust out the back. As always, the solution will involve some sort a wooden jig. I hope to make some serious progress this weekend.
Old 07-31-2014, 05:28 PM   #75
shearjs
shearjs's Avatar
Re: Lss3
Nice work!!
shearjs is offline   Reply With Quote
