Old 03-22-2017, 12:05 PM   #51
indymachinist
Re: 68 shortbed stepside stripper truck build
This is still going on, and I am building up a collection of pictures on my phone. It's just hard to post them from a phone so I haven't been.
I picked up a 2006 4.8 engine the other day so I am going to run it instead of the 5.3. Hoping the bigger rods will allow it to hold 800 whp for a while.
The "goal" is to wrap this up and run at least part of the Hot Rod Power Tour this summer. I don't know if I can make it yet. Everything takes longer than I think it will.
Build goals haven't changed much since I started.
Junkyard 4.8 LS engine
78/75 On3 Performance single turbo
Built 4l80e transmission
ProEFI engine management system
Traction control
E85 fuel with flex sensor
Boyds under bed tank with custom dual Bosch 044 pumps
12 bolt rear w/ 3:42 ratio & Eaton posi upgraded as best as possible
17" wheels (keeping 6 bolt)
Junkyard big disc brakes from NBS trucks
Hotchkiss springs & sway bars (4/6 drop)
CPP modular spindles
Power steering
Air conditioning
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 03-22-2017, 01:02 PM   #52
indymachinist
Ok so I have taken a bit of lunch break time to gather a few pictures....
Lets start with one of the truck as it is pretty much going to look when finished.
Now the rear end
New brake mount flanges at the end of the axles, and center section welded to axle tubes. I weld, but I don't weld that nice. It is good to have friends available to help you where needed.
I am a CNC machinist/programmer so I have access to solid modeling software that helps greatly when you are trying to assemble parts and you really only want to do it once. I often measure and draw everything up so I can look at it on the screen before making it. This is an assembly of the end of the axle tube with the axle, brake backing plate, and a wheel speed setup I am custom making so I can have traction control on a 68 truck.
Rear brakes are starting to come together. I haven't got the wheel speed setup done yet.
This is the start of putting a trigger wheel on the passenger side axle for the wheel speed sensor.
Mark Williams billet diff caps to help stop the diff from being spit out the back of the housing. I am also going to use a braced Moser cover with the cap bolts.
Now for a little of the Eaton diff build.... take brand new Eaton posi
Tear that all down. Keep this, get rid of the rest.
Get hardened spider gears and steel clutches to replace stock parts.
R.E.M. polish that stuff because it was ugly.
Put diff back together.
Now on to the fuel system...
Start coming up with a plan.... do a lot of drawing again.
Buy some materials from McMaster
Boom. Cut that stuff all up.
Cut bigger hole in Boyd tank, test fit parts.
Get the aluminum parts anodized and final assemble.
Now here is the engine. The $200 4.8L bomb.
This thing has 213k miles on it. It is not going to get rebuilt. New bearings, rings, rod bolts, etc are NOT in its future. I will put an LS6 cam in it, a new set of lifters and new timing chain, and an oil pump. That is all. 800 whp from this? Maybe. We will see.
-Curt
Old 03-22-2017, 01:03 PM   #53
indymachinist
And thats all there is time for right now!
-Curt
Old 03-22-2017, 02:32 PM   #54
MMcMasters
MMcMasters's Avatar
You have talent!! I can't wait to see it come together.. Keep the updates coming!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 03-22-2017, 08:28 PM   #55
Advanced Design
Advanced Design's Avatar
Nice work, big difference between the material from McMaster and cut it up...nice looking parts!
Hope you can make some of HRPT.
Advanced Design is offline   Reply With Quote
Old 03-23-2017, 10:52 PM   #56
t300
holy crap thats awesome. loving the machine work!!!
t300 is offline   Reply With Quote
Old 03-25-2017, 06:23 PM   #57
slowcpe
slowcpe's Avatar
Nice work
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 04-03-2017, 10:51 AM   #58
aggie91
I'm just glad to be here!
aggie91's Avatar
Cool build and awesome machine work.
Could you briefly explain the REM polishing and its benefits?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-04-2017, 05:59 PM   #59
indymachinist
https://www.youtube.com/watch?v=M6FxilBXNhg
the music is pretty awful but the video gives you a pretty good idea of how rem polishing works
-Curt
Old 04-04-2017, 10:08 PM   #60
Advanced Design
Thanks for the link. Interesting and the video mentions the finish facilitates lubrication. Does the process reduce possibility of stress fracture of the part?
Old 06-20-2017, 02:53 PM   #61
aggie91
aggie91's Avatar
What's the latest on this build?
Karl
The LST Challenge:
Old 06-20-2017, 03:18 PM   #62
faribran
Do you still have the spare tire rear fender?
faribran is offline   Reply With Quote
Old 07-20-2017, 08:23 PM   #63
indymachinist
Its still underway. I havent had a lot of time to do any updates here but I have been taking pictures along the way. (Pictures are time consuming to load from a phone)
The suspension work is nearing completion. I hope I never have to cut/grind/drill/hammer another rivet in my life!! I am sticking with a quite "stock style" suspension. No air bags, drop members, rack and pinion swaps or that kind of thing. Too much money, and I am not into slammed trucks. I just like a nice low functional look. So where the suspension stands now:
-stock front upper and lower control arms
-Brothers front shock relocators
-all new Moog tie rods, ball joints, idler arm, pitman arm, cross shafts, etc etc
-CPP 2" drop front modular drop spindles
-stock rear trailing arms stitch welded top and bottom
-flipped stock trailing arm mounts
-Hotchkiss swivel joints to replace stock rubber trailing arm bushings
-Hotchkiss front and rear sway bars
-Hotchkiss 2" front and 6" rear springs
-No Limit rear shock relocators
-No Limit adjustable panhard bar
This pile of parts is all ready to be coated and installed.
Here are the old rubber bushings vs the Hotchkiss swivel joints
Flipping the trailing arm mounts underway
The rear end is all cleaned/assembled. Here is a test fit of putting some of the suspension together:
This is some of getting the rear wheel speed sensor set up for the traction control system. Had to do pretty much the same thing on a front wheel as well.
Custom designed/made bracket to hold a 2001 Tahoe ABS sensor
Here is a test fit on the housing with the axle
And here is the same thing but with the inner drum style parking brake and backing plate mocked up
The Boyd fuel tank is finished and powder coated. The dual Bosch 044 hanger is finished and assembled. The tank needs put under the truck and needs plumbed and wired. I also still need to finish up the behind the marker hidden fuel filler I started forever ago.
I don't think I commented on it much here but I was not wanting to hard mount the fabricated aluminum gas tank to the frame rails. My thoughts were similar to a hard mounted radiator, I expected it would crack. So instead of doing that I got rubber grommets from McMaster car. (a great place to get racecar building supplies!) The rubber grommets press into oversize holes I drilled in the flange of the tank and they have a sleeve in them I made so they can tighten down without smashing the rubber. The end result is a tank with a small amount of "float" to prevent cracking.
You can kind of see it here
With the help of this board (thank you clinebarger!) and multiple others I bought an unknown condition 1993 4L80E transmission and completely rebuild/upgraded it. It now has all new high enegry clutches, all new Delco electronics and solenoids, upgraded input shaft and forward drum, and a Circle D multi disc torque converter.
The before and after pictures don't look much different. That is partially by design as I had no interest in painting the housing. I have a TON more pictures of this but they are pretty borning trans internal shots without anything special going on.
Before:
After:
-Curt
Old 07-20-2017, 08:24 PM   #64
indymachinist
Sorry I don't. I cut it up and sold part of it as a patch panel and junked the rest. Wasn't much of any interest in it when I had it for sale.
-Curt
Old 07-20-2017, 08:33 PM   #65
indymachinist
Also of note... I took the heads off the junkyard 4.8 I got to find a badly scored cylinder wall. It looked like a piece of the porcelain from the (original and TRASHED looking) spark plug tip got loose and found its way between the piston and cylinder wall.
So now I am a bit stalled out on what exactly I am going to do with the engine. Time will tell.
-Curt
Old 07-20-2017, 09:48 PM   #66
nds1968
nds1968's Avatar
Bummer about the motor... Nice work so far, do you feel the swivel joints were worth the money? Who did you buy yours from? Thanks, Nate
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 07-21-2017, 12:07 PM   #67
aggie91
aggie91's Avatar
Nice update, too bad about the 4.8.
Karl
The LST Challenge:
Old 07-29-2017, 12:16 AM   #68
indymachinist
Well, all the suspension should be done with powdercoat here soon. After that I can get it back on the truck and have a roller again.
Project frankenengine is underway as well. 3 junk yard engines are mixing with a few new parts. Block and crank from one engine, pistons from another, heads from another. I am attempting the build myself. It was going to be the only thing I hadn't personally rebuilt so I figured what the hell.
-Curt
Old 08-21-2017, 08:32 PM   #69
indymachinist
This stuff almost looks too good for this build. Really glad I decided to powdercoat all the suspension.
Circle D pro billet multi disc converter ready to go.
Engine all put together and mated to the transmission. Hopefully it goes in the bay soon.
-Curt
Old 09-29-2017, 05:11 PM   #70
indymachinist
I don't have a picture but engine and trans are in now hopefully to stay.
Front suspension is going back together. It's almost too nice for the truck honestly. Haha.
The front is just stock crossmember and upper and lower control arms, Moog cross shafts and ball joints, and CPP modular spindles. Everything was powdercoated and the lower cross shafts were redrilled for more caster. The little bracket and sensor you see on the spindle is for wheel speed. Need a non driven wheel speed for traction control.
Life got in the way big time this month so progress has been really slow.
Edit: I just cant seem to find a decent picture size. Just too big or too small.
-Curt
Old 06-16-2023, 01:05 PM   #71
indymachinist
This thing is on the road now! I enjoy it quite a bit but I wish it was quieter! Haha.
-Curt
Old 06-26-2023, 11:35 AM   #72
aggie91
aggie91's Avatar
Curt,
What spindle and hub did you use to be able to add the tone ring and sensor for your traction control?
How about some updated pictures?
Karl
The LST Challenge:
Old 07-01-2023, 08:40 PM   #73
indymachinist
Curt,
The spindle is the CPP modular lowering spindle. I added the holes for the sensor bracket myself. I also made the sensor bracket.
The hub is from a cut down 1994 - 1998 Chevrolet C2500 front brake rotor. That type had the hub as an integral part of the rotor. It also included a pressed on ABS tone ring. I cut the rotor part off in a lathe.
-Curt
Old 07-01-2023, 08:48 PM   #74
indymachinist
Here are a few current pictures
-Curt
Old 07-01-2023, 08:56 PM   #75
indymachinist
Its running pretty good and gets a ton of attention on the road. I’m pretty pleased with how it rides and drives. Most of the suspension is Hotchkis and No Limit stuff. AC is cold as can be which is super nice in summer.
I’m not going to be able to get a proper tune done on the computer until late August but based on how it feels with no more than about 25% throttle it is going to be a monster.
-Curt
