Old 07-25-2017, 04:53 AM   #51
lower50's
lower50's's Avatar
Re: 51 GMC 'Project Why Wait'
Looking good Dave you will have a roller in no time.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 08-04-2017, 09:55 AM   #52
Dave_The_BMXER
Chipping away at the management mounts, I'll have a closer look at them once all the fab is done.
Dave_The_BMXER is offline   Reply With Quote
Old 11-29-2017, 10:29 PM   #53
Dave_The_BMXER
So I've been working away at a few things in the garage. I took the mock up above and made it reality.
It's actually bolted in and not welded because I didn't want to paint the frame (again).
I also dialed in my fuel system
Because the back half is all boxed I had to go through the frame. It looks trick, but it was a bit of a pain in the ass to do. However I am quite happy with how it all turned out. The Aeromotive Phantom stealth install is super simple to do and I didn't have to worry about finding a place for an external fuel pump which was nice.
And finally the cab is home for the winter
Hope to get working on that but first I am going to plumb and bleed my brakes then the motor should be coming home early next year and that can be mounted before I figure out my firewall and the like.
I know I am going to have to at least to cab corners on the cab but we'll see what else once I get into it. Might do floors, or partial floors as well, but we will see!
A more detailed look at how I did what I did (the grinding, welding, cutting, and painting is up on my website).
Old 11-30-2017, 12:00 AM   #54
lower50's
lower50's's Avatar
Great job Dave!! You are going to be so happy with your truck when it is done.
1951 MG TD
Old 12-05-2017, 03:32 PM   #55
MNchevy
Dave- Awesome build! Is the front clip of your frame S-10? Do you have a motor trans yet? Your pictures are very nice!
MNchevy is offline   Reply With Quote
Old 12-05-2017, 03:41 PM   #56
Dave_The_BMXER
Thanks Bob!
A MNChevy it's G body, which is basically the same thing just set apart further. I do have a motor and trans.
A friend of mine is rebuilding it.
It's a 4.8 LS, getting a cam, heads, new intake manifold, and holley cast iron manifolds along with the refresh.
Old 12-05-2017, 04:03 PM   #57
RockinKees
RockinKees's Avatar
Dave, I just came across your build and read it all.
Looks very good!!
I like what you are building, great pics also!!
If you're building it the way the drawing is....AWESOME!!!
Thanks!
Subscribed
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-06-2017, 10:03 AM   #58
Dave_The_BMXER
Thanks! That drawing is what I'm hoping for. Eyes on the prize as they say.
Old 12-06-2017, 09:08 PM   #59
joedoh
joedoh's Avatar
super clean!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 01-26-2018, 08:33 PM   #60
rusty76
rusty76's Avatar
I don’t know how this build got by me but I’m in. I’ve followed the build on stanceiseverything.com but didn’t realize you were over here. Lol. Too cool.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-27-2018, 01:03 AM   #61
Dave_The_BMXER
Ha thanks, yeah I've always wanted a build thread so here we are. Update soon been working on a few different things.
Old 01-31-2018, 12:02 PM   #62
Dave_The_BMXER
I'm a bit out of date here (lots of pics to come) but with the chassis getting nearer and nearer to completion I've started to look to the cab and my firewall fillers arrived!
They are from Lange's Shop real affordable for Canadians and really really affordable for those of you state side.
I should be zapping these in next month or so...
Old 02-01-2018, 01:54 AM   #63
GreasyLikeaBurger
GreasyLikeaBurger's Avatar
Looking to see these installed. Are you planning to keep the entire firewall clean of wires and lines? You going to run them(wires and hard lines) down and under the cab?
GreasyLikeaBurger is offline   Reply With Quote
Old 02-01-2018, 07:35 AM   #64
Dave_The_BMXER
Yes my plan is to run as many wired and lines under the cab or through the toe board where they are less visible.
Basically de clutter as much as possible.
Old 02-01-2018, 09:01 AM   #65
lower50's
lower50's's Avatar
That will look really good.
1951 MG TD
Old 02-01-2018, 10:28 AM   #66
oldman3
oldman3's Avatar
Nice looking panels...Jim
oldman3 is offline   Reply With Quote
Old 02-01-2018, 08:23 PM   #67
rusty76
rusty76's Avatar
Very nice.
My build thread
Crossmembers CC
Old 02-05-2018, 04:35 PM   #68
Dave_The_BMXER
Closer look at the panels with my SLR, a very good deal for 160US. And they are made IN CANANDA which is practically unheard of for Advanced Design parts.
@langesshop on instagram can get you more information. Or here on facebook They are doing toe boards, and kick panels and door cards as well.
And so I don't screw up
He likes to come look at it every now and again. Hope to let him sit in it again soon.
I just need to get my cab moved a little bit and put it on stands.
It's nearly blended into garage clutter currently
Also not sure if I shared this photo:
Old 02-06-2018, 11:36 AM   #69
gigamanx
The last photo is great. My daughter came out the other day when I was pulling the truck out and said "that is sooooo cool." Made my day
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 02-06-2018, 02:52 PM   #70
ptc
ptc's Avatar
This looks like ----- "OH BOY! what have I gotten myself into!!!!"
It'll be a great teaching project, he'll never forget!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 02-06-2018, 06:31 PM   #71
lower50's
lower50's's Avatar
Ash is really going to love it when you drop him off at school in it.
1951 MG TD
Old 02-06-2018, 09:22 PM   #72
Dave_The_BMXER
My wife took that soon after I got the cab home his initial reaction was "its huge" which is funny because he's quite a bit bigger than the last time he say it.
Anytime he breaks his toys he brings them to me "fix it like you're fixing your truck"
I can't wait, he starts JK in Sept, it's not far from here so no promises but we'll see lol
Old 04-08-2018, 12:23 AM   #73
Dave_The_BMXER
Alright guys I made it through the firewall install. It actually wasn't too bad of an installation for a noob like myself and the included instructions where a big, big help. Shout out to Lange's Shop (now LS Fabrication for the filler line) for taking the time ti bang those out.
Lots of mud work left to do of course, but I will do that after I get my floors in and it's a little bit warmer in the garage.
Can anyone tell me what the remaining holes closer to the cowl are for? Basically all the ones that are empty now.
Old 04-08-2018, 02:59 AM   #74
GreasyLikeaBurger
I like the look of your filler panels. Nice to see them installed. The center top hole is the drain hole for your fresh air vent(usually a long rubber hose comes out of the hole), the other I think is for the wiring harness and usually a grommet is there to seal the hole.
Old 04-08-2018, 08:55 AM   #75
Dave_The_BMXER
Thanks! Yeah they cleaned up the firewall nicely very happy with them. They also now offer a design your own option.
For the drain hole in could re routed it through the cab and down out lower in the firewall I guess? Don't really want the old elephant trunk in the center. The rest I don't mind really.
I assume the four bolts hold something up? (sorry can't actually get in my cab easily the way it's shoved in there) I'll know these answers if spring arrives and I can reshuffle the garage.
