Old 01-20-2018, 09:09 PM   #51
Jferrante
Jferrante's Avatar
Re: The Family Truckster- 66 Suburban Build
looks great not to far from you either. We dont get many 60-66 popping up on CL that are worth looking at, nice score
Jferrante is offline   Reply With Quote
Old 01-23-2018, 09:16 AM   #52
Bennett68C10
Bennett68C10's Avatar
Yeah I was pretty shocked when I cam across it locally, once I looked at it I knew I had to have it.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 02-19-2018, 10:59 PM   #53
Bennett68C10
Haven’t updated in a while but I have been busy the last couple of weekends working on the Burb. Got the rear suspension all buttoned up. I added some Ridetech HQ shocks and changed direction on the rear brakes. I initially was going with the Captain Fab brackets and some Wilwood D52 calipers but I decided that I really should run a emergency brake so I sent the Wilwood calipers back and picked up a Wilwood Dynalite Rear Disc Conversion Kit with the internal parking brake. This kit also makes it easier to get the rear wheels on and off as the caliper mounts in the middle of the rotor instead of towards the top like the D52’s did. I’ll be listing the captain fab brackets and rotors in the for sale section. I also made a decision to not run the rear wheels with a spacer or adapter so I called up Travis at Pro Performance and ordered 2 new custom built polished TTII’s with the exact backspacing I needed. This was really the best option I had! I really like the way the TTII’s look on my burb and didn’t want to spend a ton of money at this time on a expensive set of billets that would only look marginally better! Just waiting for the wheels to show up now.
I also picked up a rear seat for the Burb from member richard2717. It’s a pretty nice seat out of a squarebody K5. It’s got the right brackets to easily mount it to the burb rear floor. It’ll eventually get recovered along with the original front seat.
Keith
66 Suburban
IG: bennett68c10
Old 02-19-2018, 11:04 PM   #54
Jferrante
Jferrante's Avatar
nice! sent you a message on the rear discs
Old 02-20-2018, 12:44 AM   #55
Captainfab
60-66 Nut
FYI to have an e-brake with the D52 brackets all you need are the '76-'78 Eldorado calipers.
Old 02-20-2018, 01:03 AM   #56
mongocanfly
Post Whore
mongocanfly's Avatar
WOW...what a improvement a elevation change and wheels makes....looks great
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-20-2018, 09:16 AM   #57
Bennett68C10
Thanks, I'll send you over the info you need.
No big deal, I already knew that but they are hard to find without having to buy new ones and I prefer the internal parking brake that Wilwood has better.
Thanks, its crazy the difference in how it looks now.
Keith
66 Suburban
IG: bennett68c10
Old 02-20-2018, 09:56 AM   #58
The Rocknrod
Moderator
The Rocknrod's Avatar
Do you have a picture of the new rear calipers now?
Old 02-21-2018, 12:43 PM   #59
Bennett68C10
Forgot to take one with the wheel off but this gives you an idea!
Keith
66 Suburban
IG: bennett68c10
Old 02-21-2018, 03:49 PM   #60
The Rocknrod
Moderator
Interested in the parking brake info - Which Kit did you buy?
Old 02-21-2018, 07:42 PM   #61
Bennett68C10
Here is the kit I have. You can run it with 15” steelies which is a nice option. I plan on running a 15” steel wheel for my spare so it works out nicely for me. The internal parking brake is similar to what they run on Corvettes.
http://www.wilwood.com/BrakeKits/Bra...%2c+5+Lug+only
Keith
66 Suburban
IG: bennett68c10
Old 02-21-2018, 11:37 PM   #62
Vic1947
Vic1947's Avatar
Just keeps looking better and better, Keith. Reckon it stops a lot better now too.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 02-22-2018, 11:38 AM   #63
Bennett68C10
Thanks Vic, hopefully it stops better than the 4 wheel drum manual brakes it had before
Keith
66 Suburban
IG: bennett68c10
Old 02-22-2018, 12:20 PM   #64
olrosa
olrosa's Avatar
Great looking rig!
olrosa is offline   Reply With Quote
Old 02-26-2018, 09:19 AM   #65
Bennett68C10
Originally Posted by olrosa View Post
Great looking rig!
Thanks Seth, can't wait to see how yours turns out after the suspension overhaul.
Keith
66 Suburban
IG: bennett68c10
Old 02-26-2018, 06:31 PM   #66
shearjs
shearjs's Avatar
Looking good! What's next on the list? Almost time for a test drive?
shearjs is offline   Reply With Quote
Old 02-27-2018, 09:08 AM   #67
Bennett68C10
No test drive until the LS is in and running. I pulled the front clip off on Sunday in preparation for the LS swap. I need to pull that old greasy straight 6 out so I can clean and paint the frame rails and front suspension before stuffing the LS in. The 4L80e has been dropped off to be rebuilt as well.
Keith
66 Suburban
IG: bennett68c10
Old 02-27-2018, 05:08 PM   #68
Bennett68C10
Current pic of how the Burb looks. Still have to pull the steering shaft so I can get the driver side inner fender out of the way. Ran out of gas on Sunday and didn’t finish it
Keith
66 Suburban
IG: bennett68c10
Old 02-27-2018, 05:12 PM   #69
Bennett68C10
Oh and these showed up today! Really like the way they look and the extra backspacing makes for a nice looking lip! Went with a 20x10 with 4.5” BS, going to trim the fender lip about a half inch to give me some clearance on the outside of the wheel well. Definitely won’t rub on the inside anymore!
Keith
66 Suburban
IG: bennett68c10
Old 02-27-2018, 05:17 PM   #70
shearjs
shearjs's Avatar
Oh yea! What are the specs on the LS you're throwing in? I can't recall what all you had planned for your truck. I really need to chase this lead on a 6.0/4l80e that I have before it gets away. Those wheels look great!
Old 02-27-2018, 06:20 PM   #71
aggie91
I'm just glad to be here!
aggie91's Avatar
You should not need to pull the steering shaft to remove the inner fender panel. There is a small panel bolted to the inner fender where the shaft goes thru the panel. That small on can be in-bolted and removed, it leaves an opening in the rear edge of the inner panel and can then be removed from the truck with the column and shaft in place.
The blue arrow in the picture shows the slot left from removing the smaller panel that covers the steering shaft as it passes thru the panel.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-27-2018, 09:00 PM   #72
Bennett68C10
The motor is a stock LQ9 that currently has a Tick Motorsport SNS Torquemax Stage 2 LS2 cam in it with .660 lift BTR double springs and titanium retainers, hardened pushrods and BTR roller trunion upgrade. Also running a LS6 intake and ported throttle body! Thinking about going to a little milder cam as this one was purchased for a lighter 68 Shortbed and not the family truckster and requires at least a 3600 converter.
Boy now I feel like an idiot, shows it’s my first time working on a 60-66 and how tired I was on Sunday. Can’t believe I didn’t realize that! I even looked at it and told myself that it should be able to be unbolted! Oh well the shaft has to come out anyways but would be easier with the inner fender out of the way!
Keith
66 Suburban
IG: bennett68c10
Old 02-28-2018, 10:26 AM   #73
aggie91
aggie91's Avatar
Did not intend to make you feel like an idiot, not my intention, Being tired you can miss stuff and make your work harder, hopefully it I did save you some work and ease your frustration level...I have been building the 60-66 trucks since I was 16, so I know a think or two because I have seen a thing or two...
Karl
The LST Challenge:
Old 02-28-2018, 01:09 PM   #74
shearjs
shearjs's Avatar
Sounds like a runner! That's going to be fun! My GMC had similar specs to your LS and it would move! Can't wait to see it.
Old 02-28-2018, 09:48 PM   #75
Jferrante
Jferrante's Avatar
nice!
