01-27-2016, 01:41 AM | #801 |
Re: 1958 Apache 38 Dually Dump Project
Thanks L50!
Fully welded...
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
01-27-2016, 09:35 AM | #802 |
Looking good.
Kim |
01-27-2016, 10:22 AM | #803 |
Nice! What about the seams in the door openings? Weld them up and then filler of some sort to smooth them out?
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
01-27-2016, 12:30 PM | #804 |
Looks like you guys were having a great time. Good progress!
01-27-2016, 12:55 PM | #805 | |
Appreciate that Kim!
Too much fun is had by all
01-27-2016, 02:23 PM | #806 |
So that is going to be a "One-Piece" complete cab and front clip when you are all done. The only remove-able sheetmetal will be doors and hood pretty much?
I guess with all the welded joints you wont have to worry too much about bondo breakout with potholes and bumps and such.... Lookin great.... Lot-O-work!
My Build: 57 Chevy Pro-Street |
01-27-2016, 07:52 PM | #807 |
Yep, pretty much a 4 piece cab and front clip!
The entire assembly is fairly rigid...tying in the inner fenders to the firewall stiffened it up quite a bit, triangulation of sorts. The frame is fairly rigid also, crossmembers, steps, and plating add to that. All in all, I hope that there won't be much difference between chassis flex and body flex...and we're trying to minimize the amount of bondo also. But, time will tell!
04-02-2016, 10:05 AM | #808 |
Any updates on this one ? Just abt to go back and look up you gin pole lift . I seem to think I need one around the farm .
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
04-04-2016, 01:00 AM | #809 |
Not much to report...still trying to work through the smoothing/shaping stage.
Our buddy Scott has been busy with his life and we only have a few moments here and there to work on the 58. I wish we were more experienced with this stage of the build and could move forward on our own, but we need his help. These pics look a lot like the older pics, but we are making some progress...doors are very close to where they need to be, body lines are being massaged together, and low spots and seams are disappearing.
04-04-2016, 01:19 AM | #810 |
Morning Phil
Progress is progress. My motor is back together now...... So bodywork etc can start soon too.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
04-04-2016, 08:35 AM | #811 |
Every little bit helps.
Kim |
07-11-2016, 12:08 AM | #812 |
How's things going in your neck of the woods ? Making much headway ?
07-11-2016, 07:34 AM | #813 |
Logging in the manhours. Looks great. dug
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
07-12-2016, 12:37 AM | #814 | |
Thanks Dug! Progress has slowed a bit, but we'll get there eventually.
08-28-2016, 12:31 AM | #815 |
Just read through your build, awesome work! Love the detail going to be 1 sweet "tonner"!
08-31-2016, 12:42 AM | #816 | |
The cab is still at Scott's place. I spoke to him last week and he is trying to light a fire under it...we would like to have it back before the end of the year. I'm anxious to get back on it!!
01-19-2017, 10:18 PM | #817 |
The cab's getting a little closer to being ready for primer. The doors and hood are locked down and the gaps are looking really good.
We're in final sanding with just a bit more glaze here and there...mainly in the engine bay and interior. There will be more smoothing/sanding after primer, but it will be a huge step for me to have it one color.
01-20-2017, 10:06 AM | #818 |
Looks good.
Love the holes in the hood. Kim |
01-20-2017, 10:05 PM | #819 |
Good to see the update...truck is getting better and better.
01-21-2017, 12:23 AM | #820 |
Thanks Kim! I've been trying to keep tabs on your project...good to see ya back on it and moving forward. It's good to see the stage your at with the body (you and the truck )...the cab really looks good!!
Hey AD, thank ya!
01-23-2017, 03:21 AM | #821 |
We've had a couple decent days of weather, so decided to get back on finishing the bedsides. I've been putting this off because I wasn't looking forward to all the sanding.
Anyway, spent half the weekend and got about a third of the bedsides done. We are fine sanding the old sides back to fresh wood, floating some black paint onto them, sanding them back down to expose some grain, and then treating them with a Thompson water seal/stain.
01-23-2017, 01:00 PM | #822 |
Wood looks real nice.
Kim |
01-23-2017, 03:17 PM | #823 |
6>8 Plugless........
That looks awesome! I really like the touch on the wood work.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-24-2017, 01:30 AM | #824 |
Thanks y'all...it's nice to just get out and work on it a bit again.
01-26-2017, 02:02 AM | #825 |
Passenger side bed wood done...
