Old 05-04-2014, 11:27 PM   #826
jtp67-72
jtp67-72's Avatar
Re: 68 aka "Chained in Porterbuilt Prison"
Originally Posted by FOSTER21 View Post
I may have missed it but can u give more details on the front brakes?
Zo6 ....bought calipers,rotors,spindles,hubs and brackets from Boris (way2lo) .....good guy...also can get from Tobin at Kore 3.....rotors are 14" with 6 piston calipers...Tell u how anal Boris is about these...He insists on assembling the spindles and hubs himself before shipping...so never to have someone install bearings improperly..........jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 05-05-2014, 08:13 AM   #827
mcbassin
Still Learning
mcbassin's Avatar
Looks like a work of art. Too nice to cover with a body....
mcbassin is offline   Reply With Quote
Old 05-05-2014, 12:40 PM   #828
mikeleeshields
mikeleeshields's Avatar
The more parts you put on the better and better it looks. Keep it up.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme
Mike
mikeleeshields is offline   Reply With Quote
Old 05-06-2014, 01:50 PM   #829
superflysteiny
superflysteiny's Avatar
Nice looks great
superflysteiny is offline   Reply With Quote
Old 05-06-2014, 07:20 PM   #830
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Your chassis looks super nice! Great work!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-06-2014, 09:59 PM   #831
jlaird
jlaird's Avatar
Originally Posted by jtp67-72 View Post
I don't know about that but i would vote those mirrors as masterpieces..I may be your 1st customer for this truck....the stems may be a little tricky but we will see hopefully soon...I'm watchin!! jim
Thanks Jim! I would be honored!
jlaird is offline   Reply With Quote
Old 05-08-2014, 09:22 PM   #832
jtp67-72
jtp67-72's Avatar
Got the stainless brake lines installed...in front was able to install "thru the frame" ...line works great in any position of spindle and whether slammed or in full up mode...(and it's not that close to shock as it looks..bends nicely on turns)...rears may surprise some but works like front ....any position of rear end they clear..still waiting on mastercool flaring tool for hardlines....and last if you haven't seen this 7 conducter wire for rear section here it is....has 6 14 gauge wires and 1 12 gauge wire (fuel pump)...No harness wrap needed...more on this in couple of days...jim
Old 05-08-2014, 09:25 PM   #833
Bennett68C10
Bennett68C10's Avatar
Looks great, what length brake lines did you go with front and rear.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-08-2014, 09:27 PM   #834
jtp67-72
jtp67-72's Avatar
It's the ones Boris sent...all 4 are the same..will measure in am.....jim
Old 05-09-2014, 04:16 PM   #835
Dieselwrencher
Brake lines look great. Is your rear wiring for a trailer application? That's what I usually get too.
Ryan
Old 05-09-2014, 11:29 PM   #836
jtp67-72
jtp67-72's Avatar
Yes and it works great AND I was able to run both it and 2 gauge battery cable down drivers side THRU THE EXTREME C-NOTCH....lot's of work with a helper but it is INSIDE the frame rail completely.....think i will start a thread on what needs to be done before final assembly of notch to make this easier for those who follow!!....pics tomorrow...running another 2 gauge down pass. side straight to starter...dr. side will run rest of truck....Batteries are common grounded to frame and positives will be tied together....second set of leads to go to charging posts at pass. rear taillight (which opens to reveal) to make that chore easier if u ever need a jump.....jim
Old 05-09-2014, 11:30 PM   #837
jtp67-72
jtp67-72's Avatar
All are 16".........jim
Old 05-09-2014, 11:46 PM   #838
mcbassin
Still Learning
mcbassin's Avatar
I wish I had known about that wire. That is slick, I just ran the original wire and a seperate wires for fuel pump and sender. Thanks for sharing
Old 05-10-2014, 12:04 AM   #839
jtp67-72
jtp67-72's Avatar
And they make a heavier duty one.....
http://www.ebay.com/itm/7-Conductor-...50ed13&vxp=mtr
Did you ground one side of that sender at rear?? I've got to look up the wiring diagram for that...been to long!!.....jim
Old 05-10-2014, 06:16 PM   #840
Bennett68C10
Thanks for the info Jim
Keith
66 Suburban
IG: bennett68c10
Old 05-11-2014, 09:48 PM   #841
jtp67-72
jtp67-72's Avatar
Few more pics after today's work...wires pulled thru frame and ready to terminate at batteries..that ugly (right now at least) 1" tube will carry crossover battery lead and wires to pump and sending unit will grommet out of tube (no holes done for that yet)....anyone guess what grommet that is bringing up positive cables??.........pcv valve cover grommet...works perfect...........strung cables down frame rail...pass side is straight to starter lug....dr. side powers powers rest of truck....black cable is 7 conductor for rear lights..pump...sending unit...................jim
Old 05-11-2014, 09:56 PM   #842
jtp67-72
jtp67-72's Avatar
This is how i hid wires in notch......
Old 05-11-2014, 09:58 PM   #843
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Looking good!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 05-11-2014, 11:19 PM   #844
oldman3
oldman3's Avatar
Jim, that looks great...Jim
oldman3 is offline   Reply With Quote
Old 05-12-2014, 08:32 AM   #845
mcbassin
Still Learning
mcbassin's Avatar
I did ground one lead from the tank sender to the frame. I did the same for the fuel pump. I hope I did it right. The stock lead for the sender was only about 12" long so it made sense to ground it by the tank.
Frame looks great BTW.
Old 05-18-2014, 02:23 PM   #846
jtp67-72
jtp67-72's Avatar
Finally got rear wired....here's a few pics...loose wires at back are for lights...#6 red and black by pass. battery will loop over behind marker light to jump terminals....open marker light ..u can charge or jump start.....well back to painting engine and trans and wiring accuair and plumbing rear....oh boy!!!!!
Old 05-18-2014, 03:54 PM   #847
Rusbuilt
Rusbuilt's Avatar
Lookin good sir!
Rusbuilt is offline   Reply With Quote
Old 05-18-2014, 07:08 PM   #848
oldman3
oldman3's Avatar
That looks sweeeeeet...Jim
Old 05-18-2014, 08:26 PM   #849
mikeleeshields
Jim all the rear portion work is looking really really good. What is the major reason for running dual batteries Jim?
Mike
Old 05-18-2014, 10:25 PM   #850
jtp67-72
jtp67-72's Avatar
Just me...they are tied together...the pass. will run straight to starter lug..dr.side runs rest of truck..notice the box at rear of driv. batt...that's the autowire 175 amp mega fuse..made it where it's easy to get to if needed....notice those grommets in end of 1" crossover tubing..they are valvecover pvc grommets....worked perfect for that..........jim
