Old 10-29-2014, 09:52 PM   #951
SatisTraction
Re: LS1 into a 73 cheyenne
nice build!! want to see it finished
WTB 73-87 SWB fleetside bed!!
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
75 bronco injected 351w
SatisTraction is offline   Reply With Quote
Old 12-10-2014, 01:34 PM   #952
Mjminino
Sweet baby Jesus that is a phenomenal build!
Mjminino is offline   Reply With Quote
Old 01-20-2015, 04:33 PM   #953
kvn1011
Kvn1011
kvn1011's Avatar
im here lurking
and hoping for an update!
kvn1011 is offline   Reply With Quote
Old 01-22-2015, 07:21 PM   #954
JGood
JGood's Avatar
Now that is some engine porn if I've ever seen any!! Looks awesome!!
1986 Chevy Silverado LWB (project)
1967 Chevy SBSS (future project)
2003 Chevy Tahoe (wifes daily)
2004 GMC 2500 Duramax (company truck)
1986 GMC Wrangler LWB (newly acquired beater)
JGood is offline   Reply With Quote
Old 03-17-2015, 06:32 PM   #955
ccrane0044
ccrane0044's Avatar
Amazing build... Truly amazing.
'80 GMC C15, still in progress... http://67-72chevytrucks.com/vboard/s...d.php?t=651276
ccrane0044 is offline   Reply With Quote
Old 10-11-2015, 07:53 PM   #956
kvn1011
Kvn1011
kvn1011's Avatar
hope all is well with you Al!!!
Old 12-02-2017, 01:16 AM   #957
smokedat
smokedat's Avatar
iIt has been a minute since i posted anything so long i forgot my password but i am back on track. All is well been busy with work and family. I quit the iron work hated the traveling but i do miss lugging the suitcase and burning NR-232. Now i fabricate and weld at a shop 30 min drive building electric power plants. It seems I have less time to work on my truck now i got married have 1 boy and 1 on the way,it has been a battle between the fam the hobbies working on the square, mountain biking or landscape photo sessions. It bothers me, complete disappointment that i have not finished the truck, I am determined, I have this square to finish.
As in tradition i will post pics of the progress
Alex - Dirty AL "One Piece at a Time"
Follow me on Instagram alex.barr.ios
smokedat is offline   Reply With Quote
Old 12-02-2017, 01:25 AM   #958
smokedat
smokedat's Avatar
so i got the center section along with the essentials. With the set up i have going on i determined 4.11 gear ratio would work out for me best. Its a Moser Nodular case with 31 splines and a Detroit True Trac. Axles are 31 spline from quick performance.
Old 12-02-2017, 01:40 AM   #959
smokedat
smokedat's Avatar
that chunk of metal is heavy don't let it fool u woke up sore. So what i did to press fit the studs i inserted them then i put a gang of washers and ran the nut with an impact being extra cautious, i tried doing this by hand but it took for ever and a lot of effort. I went for a sce gasket its a layered type and in the middle it has a thin metal section. Needled to say it didn't go in without a fight. And it didn't help i did this on jack stands with the bed installed, and the studs did not align properly with the case i had to slightly enforce the rubber mallet.
I still need to fill it with gear oil. this set up takes no modifiers and non synthetic. break in period using 85W140. And the to torque this i did no thradlock at 35lbs
Old 12-02-2017, 10:47 AM   #960
smokedat
smokedat's Avatar
I started to work on the brake lines i am running 3/16 stainless tube with 3/8-24 double flares. installed the front calipers and ran my flex line and drilled and tapped the brake bracket. I didn't finish as i am waiting on parts. As for the braking power i went with a hydro booster that operates off the power steering pump. since i am running a ford rack i needed to reduce the volume so i installed a fitting from Pure Choice to solve this, other wise the steering will be super sensitive hard to keep in a straight line. this is the part if anyone encounters this issue -6 AN Low Volume Power Steering Valve P/N 11726 @ $ 22.95 . easy to install goes on the high pressure port at the pump side
Old 12-02-2017, 10:51 AM   #961
nlped
nlped's Avatar
I’ve been wondering how this beast was going.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 12-02-2017, 10:57 AM   #962
smokedat
smokedat's Avatar
I mounted the calipers and ran the front flex lines and turned the steering side to side to its max seems to work but i needed to find a way to control the flex line and came up with this Billet Brake Line Clamps, my A arm tubes are 1 1/8 the clamps are 1'' if anything i will size them up to fit
Old 12-02-2017, 11:06 AM   #963
smokedat
smokedat's Avatar
so here is my son Jacob young apprentice. Once complete this will be his Square, problem is my wife asked what am i going to do about our boy she is expecting, if im "going to cut the truck in half so they both have a share". I replied no this just means i need to build another
Old 12-02-2017, 11:54 AM   #964
mcbassin
Still Learning
mcbassin's Avatar
Great to see you back in here Alex! Great pictures too! Congratulations on the family additions
mcbassin is offline   Reply With Quote
Old 12-02-2017, 05:05 PM   #965
mud.man.rj
mud.man.rj's Avatar
Lil dude is cool, picture worth framing.
Build is looking great, nice parts and work.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 12-03-2017, 11:24 AM   #966
smokedat
smokedat's Avatar
still cookin
Old 12-03-2017, 11:25 AM   #967
smokedat
smokedat's Avatar
thanks, glad i'm back on board
Old 12-03-2017, 11:27 AM   #968
smokedat
smokedat's Avatar
thanks, i should print and frame it
Mudman.
Old 12-03-2017, 11:39 AM   #969
smokedat
smokedat's Avatar
i didn't get to far on the brakes as i am still waiting on parts, but i did install the rear flex lines and i went with these clamp style brake brackets because i wasn't to sure how the lines would end up routing since i'm building the brake system from scratch they offered more flexibility.
i also drilled and tapped a pneumatic breather vent, it also served as my fill port easier than filling it through the side.
Old 12-04-2017, 12:57 PM   #970
aggie91
I'm just glad to be here!
aggie91's Avatar
Nice up dates. Glad to see you back at it. Congrats on the family, digging your reason to build a second one...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-06-2017, 08:07 PM   #971
smokedat
smokedat's Avatar
Thanks, glad to be back at it.
Old 12-06-2017, 08:13 PM   #972
smokedat
smokedat's Avatar
so i got around running the rear lines. I moved the clamps inward and out of the way if it bottoms out. at 12 o clock i used some stainless flat bar bent it 90° and installed my T fitting routing the flex line back over to the top tube and over to the frame. Still waiting on the hydroboost so i cant wrap this up. will move on to the fuel lines after the brake lines
Old 12-09-2017, 06:42 PM   #973
smokedat
smokedat's Avatar
So the hydroboost finally arrived. I got the Universal raw base model since its hidden under the dash. I will be eliminating the T fitting on the low pressure and tap to the power steering reservoir. i'm using -6 Fuel Cell Bulkhead and on the HB i will swap out for a 5/16-24 O-Ring to AN-6. i found this diagram showing the T method and other with T eliminated. And a wilwood prop valve with the brake light pressure switch, in my application this makes it easier.
Old 12-09-2017, 06:52 PM   #974
smokedat
smokedat's Avatar
i got the brackets and they seem to work out. I just had to over size the cable hole.
Old 12-09-2017, 07:11 PM   #975
smokedat
smokedat's Avatar
the other change i did was go back to original small rectangle mirrors and original style door handles. I did get billet door handles. Back when i started this build they didnt offer billet door handles. Sux i had to invest the time in redoing all this but on the bright side i was lucky i had the truck on primer and not painted.
since then i have mowed ideas on the interior and decided i will go with the stock original look minus a few changes. post pics of the parts later.
73c10, c10, cheyenne, ls1, swap
