Old 11-28-2014, 11:32 PM   #1
ccrane0044
ccrane0044's Avatar
Project PRPLHAIZ
Hey guys, things are starting to come together for my (semi-budget build) '80 C15 build so figured I could start a thread to help out along the way and get some input.
Here's a few pictures during mock up to give you guys an idea of what its going to look like. In the end will be a deep purple, not multiple colors.
Here's the start of the mock up...
After all the welding was done i got it blasted and threw some paint at the frame.
Here's my 383 Stroker rated for 405 hp and 450 ft-lbs, nothing crazy but should be enough to get her moving. as for the trans its a 770R4 build by performance automatic.
As for the body I picked up a rust free box and cab from Georgia.
Also picked out some 22"s, got an amazing deal on wheels and rubber while in Carlisle, PA at one of the swap meets.
That's where I'm at for now, I will keep pictures coming while I make more progress. Feel free to leave feed back, this is my first build and this sort of thing is only a hobby so can always use help.
'80 GMC C15, still in progress... http://67-72chevytrucks.com/vboard/s...d.php?t=651276
ccrane0044 is offline   Reply With Quote
Old 11-29-2014, 10:35 PM   #2
CDNchevydude
CDNchevydude's Avatar
Re: Project PRPLHAIZ
Suscribed! Love the wheels!
87 R-10 SWB
CDNchevydude is offline   Reply With Quote
Old 11-29-2014, 11:40 PM   #3
ccrane0044
ccrane0044's Avatar
Thanks Chevydude, they weren't what I was looking for at first, but got an amazing deal on them and now have no regrets. I wish the rear tires had more rubber, but tires don't last forever so my next set will have a little more meet on them.
Old 11-30-2014, 04:31 AM   #4
tinydb84
tinydb84's Avatar
I have always loved bright green on trucks
David
Instagram: myfabguy
Old 11-30-2014, 05:29 AM   #5
ccrane0044
ccrane0044's Avatar
Thanks Tinydb, I find the green accent will go good with the deep purple in the end. Just checked out your build thread, truly amazing, wish I had more money to do a few things that you did. Also, Loving the skulls on your welds.
Old 11-30-2014, 10:09 PM   #6
ccrane0044
ccrane0044's Avatar
I've been looking at a few builds and I'm wondering... will have have to step my steering linkage or is that only necessary when you start doing body drops and what not?
Old 12-01-2014, 12:37 AM   #7
tinydb84
tinydb84's Avatar
You'll probably need one. The upper control arm gets in the way when airing out.
David
Instagram: myfabguy
Old 12-01-2014, 12:54 AM   #8
ccrane0044
ccrane0044's Avatar
Any good places to buy a kit that's not to pricey? I looked at Borgeson but I'm hoping they are on the expensive side since I'm running out of money. Also all the shafts I'm seeing are rectangular and the supports are circular, are the edges on the shafts beveled enough to slide through the support?
Old 12-01-2014, 01:22 AM   #9
slimneverdies
slimneverdies's Avatar
What brand control arms are those up front? Looks like the give you some extra drop with way those bend upward like they are...
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 12-01-2014, 01:44 AM   #10
ccrane0044
ccrane0044's Avatar
The control arms are from Airbagit. I don't believe they provide any extra drop since I don't remember reading anything about that when I bought the parts but I may be wrong.
Old 12-01-2014, 01:50 AM   #11
tinydb84
tinydb84's Avatar
The astro van steering is what most people do. I couldnt do that because I have a C20 which doesnt have the same sized fittings.
David
Instagram: myfabguy
Old 12-01-2014, 02:38 AM   #12
ccrane0044
ccrane0044's Avatar
ok thanks, I will look into that. Thanks
Old 12-01-2014, 05:32 AM   #13
franky69c10
chevy runs deep
franky69c10's Avatar
Looking good bro
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 12-01-2014, 05:36 AM   #14
ccrane0044
ccrane0044's Avatar
Thanks Franky. It's been a long journey and still a long way to go but she's coming along.
Old 12-03-2014, 08:09 PM   #15
ccrane0044
ccrane0044's Avatar
Not to much to add today but there's a bit of progress. Mounted the engine and trans, along with front wheel bearings and brakes. Also got the steering set up. After all that I started on the rebuild for the rear axle. Got the carrier bearings, rear wheel bearings and seals all on but was having trouble getting the pinnion race in place so might just end up getting someone to do the rest for me since I'm not to familiar with rebuilding differentials. Rather spend some money now than a lot later if i do something wrong. Other than that, I just painted a few other small parts and called it a day.
As for good news, I think I will have enough clearance on my upper control arm to run the stock steering shaft, the way upper control arms dips down allows a lot of room for everything to work out so not having to worry about that is a relief.
Old 12-04-2014, 06:05 PM   #16
mooseknuckles
mooseknuckles's Avatar
cool!
mooseknuckles is offline   Reply With Quote
Old 12-07-2014, 11:10 PM   #17
txlowtrucks
What brand are the wheels? I have been looking for quite a while. It seems like everything I like is out of budget.
txlowtrucks is offline   Reply With Quote
Old 12-07-2014, 11:55 PM   #18
bbbc10
Diggin The SquareLife
they are mht wheels pricey forsure
bbbc10 is offline   Reply With Quote
Old 12-08-2014, 10:52 PM   #19
ccrane0044
ccrane0044's Avatar
They are MHT wheels, usually they are pricey but I got a wicked deal a couple years ago in Carlisle. Rims and tires for $1000. made the whole trip worth it. The tires are Nitto NT 555. Not a scratch on the wheels and tires are practically brand new.
Old 02-03-2015, 06:24 PM   #20
ccrane0044
ccrane0044's Avatar
Not to much progress since I last posted, its been slow going this winter since I was waiting on my diff. to get rebuilt for a few weeks. Also I don't have heat in the shop I'm in so that brings down the motivation. Anyways, here are a few shots with the Rear end in place and a few other loose ends.
Old 03-11-2015, 06:14 PM   #21
ccrane0044
ccrane0044's Avatar
Here are a few more updated pics, Its slow going but starting to come together.
So far I have the cab in place and I am currently working on tubing the transmission tunnel. The bed is already cut as you can see and good to go on, still thinking of what I want to do to cover the cut out. I originally wanted to raise the bed but ended up being to much work for me at the moment. All air bags, valves and most of the plumbing is installed as well.
Old 03-12-2015, 03:33 PM   #22
NewType72
NewType72's Avatar
Coming together quite well, looking forward to more progress brother!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 03-12-2015, 05:09 PM   #23
ccrane0044
ccrane0044's Avatar
Thanks NewType72, I like how its coming together, there are a few flaws here and there but I'm pretty happy with it considering it's my first build and most of it has been done with hand tools and an angle grinder... also the fact that this is just a hobby and that I am mostly self taught makes me feel pretty accomplished.
Old 03-12-2015, 09:30 PM   #24
NewType72
NewType72's Avatar
Gotta love being able to learn on your own projects at your own pace. I've enjoyed it many years already and im still young. Thanks for sharing!
- Dylan
(209)-985-7721
Old 03-16-2015, 04:55 PM   #25
ccrane0044
ccrane0044's Avatar
Finally built up the courage to cut up my cab on Friday when I had a chance to do a bit of work. Here are the results...
Still need to fill in where I had to clear the drive shaft, hoping to pick up a bit of 4" tubing Wednesday and get that done.
