Old 09-26-2007, 06:15 PM   #76
jb4short
Damn Yankee
jb4short's Avatar
Re: Porterbuilt 69
I don't want to make work for Carter but put the exhaust back through the rear panel Nate
jb4short is offline   Reply With Quote
Old 09-26-2007, 06:19 PM   #77
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Porterbuilt 69
Drooling with Anticipation
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-28-2007, 12:54 AM   #78
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
Finally made some time to get a little metal-work done on the truck...
Started cleaning up the firewall. I decided to keep it's factory look, but clean it up a bit. I will finish off the pass. side to match the driver's side.
Also went ahead and welded up the factory seam on the rear portion of the roof.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-28-2007, 12:55 AM   #79
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
some more...
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-28-2007, 01:02 AM   #80
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: Porterbuilt 69
great work as usual.
question on the rear seam weld. what did you need to do to prep that? I've never sanded the paint down on one yet, but what's in that seam from the factory? will i need to clean it out before welding that seam up?
IvelDesigns is offline   Reply With Quote
Old 10-28-2007, 01:11 AM   #81
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
It's full of some type of seam-sealer. I took my cut-off wheel ground it out, then actually cut completely through so I could close the gap up and make it a tighter fit.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-28-2007, 01:42 AM   #82
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Porterbuilt 69
Nice metal finish work. Are you gonna shave the drip rails?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-28-2007, 10:12 AM   #83
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
The drip rail will stay. I am partial to the way these trucks look with the drip rail.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-28-2007, 12:33 PM   #84
Frizzle Fry
Frizzle Fry's Avatar
Re: Porterbuilt 69
Much less work than the one you rolled but still a big improvement! Firewall looks great too.
Frizzle Fry is offline   Reply With Quote
Old 10-28-2007, 02:14 PM   #85
ColoradoK5
ColoradoK5's Avatar
Re: Porterbuilt 69
ColoradoK5 is offline   Reply With Quote
Old 01-18-2008, 01:44 PM   #86
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
OK... FINALLY had, I mean MADE some time to work on the 69. I have had a pile of parts setting around for too long! I have been working my butt off on Dropmembers and tying up customer projects and just needed some time for me! So, about 4 hours worth of work today and here we are... removed the factory front suspension (thanks N2Billet and SCOTI for the frame) and installed the DropmemberC4. (When I blow the truck apart for powdercoat I will flush-out the rack notches). Also got the LS1 and six-speed in place. Went to install the headers I had on the shelf... they don't fit. Looks like I will be fabricating custom headers and installing the twin turboes I picked up for the build last year... can't wait for that part! Things I am hoping to get done over the next few weeks: Finish fire-wall; install core support and front sheetmetal; hang doors; fabricate new trans tunnel; start the dash mods and hang the turbos!
In all reality, it will take longer... but it felt so good to work on it today!!!!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-18-2008, 01:45 PM   #87
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
a few more...
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-18-2008, 01:46 PM   #88
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
and more...
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-18-2008, 02:10 PM   #89
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Re: Porterbuilt 69
Amazing
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 01-18-2008, 02:19 PM   #90
Rokcrln
Rokcrln's Avatar
Re: Porterbuilt 69
Well it is about time! I was starting to think someone might have dropped another trany on you So what are your plans for the rear Yes it sure does feel good to make progress on your own rig for a change. I am 3/4 thru mine and now I wil need to put it aside to finish up a customers rig then back to mine for a few weeks before the next one comes in.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-18-2008, 02:24 PM   #91
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
Kevin
LFD Inc.
I still can't feel the tip of my left ring finger!
The plans for the rear.... I will definitely be posting up progress pics. It will be using a Dropmember Rear Kit for the 63-72 C-10s. It will utilize trailing arms (factory or tubular) and the kit will include a new trailing arm crossmember; bolt-in notch (different notch depths will be available to go LOW or REALLY LOW); and panhard bar. Coming soon...
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-18-2008, 02:34 PM   #92
jasonb72
PorterBuilt Man Crush
Re: Porterbuilt 69
Darn you and those welds, AND YOU let the cat out of the bag, I think I will have to rename my project to Built By DropMember, cause it seems that is all I will have on the thing when it is done. Now you need to stop making kits so I can at least get it done once!! Great job, and all that in 4 hours.
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 01-18-2008, 02:35 PM   #93
RunninLo
RunninLo's Avatar
Re: Porterbuilt 69
What's this could my dream of actually driving my 'burb be materializing??!!
Hurry and bring this to market before I blow all my dough on the new race bike, PLEASE?
Josh
88 4x4 crew DD
Old 01-18-2008, 04:15 PM   #94
abadsvt
abadsvt's Avatar
Re: Porterbuilt 69
Looks Sweet Nathan. So you not going to run the c4 rear end also? Is there a reason? Anyways keep up great work.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 01-18-2008, 08:41 PM   #95
Rokcrln
Rokcrln's Avatar
Re: Porterbuilt 69
Josh
Josh I am sure he will take an early payment just to keep you off that bike! Nate is just that kind of a stand up guy
Kevin
LFD Inc.
Old 01-18-2008, 09:33 PM   #96
jb4short
Damn Yankee
jb4short's Avatar
Re: Porterbuilt 69
Nice work, as always, Nate! What are all those "Popping" sounds when I weld?
Old 01-18-2008, 11:10 PM   #97
Alvin
Never Done?
Alvin's Avatar
Re: Porterbuilt 69
Well I'm glad I have another frame to build up! I can't wait to see this kit!
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 01-19-2008, 06:27 AM   #98
kyull67
kyull67's Avatar
Re: Porterbuilt 69
Wow! This truck is going to be awesome!
Your welds look like they were performed by a robot.
kyull67 is offline   Reply With Quote
Old 01-19-2008, 09:43 AM   #99
SCOTI
SCOTI's Avatar
Re: Porterbuilt 69
..... So, about 4 hours worth of work today and here we are... removed the factory front suspension (thanks N2Billet and SCOTI for the frame) and installed the DropmemberC4.
Hhmm . . ..... Hardly recognized the frame w/o a trailer underneath it . I have that radiator core-support mount in my stash too. Sorry about that.... it was supposed to be replaced before going to you.
Where's my PB rear-suspension kit?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-19-2008, 09:51 AM   #100
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt 69
Maybe I will have to hold onto the suspension until I recieve the rest of the frame parts!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
