Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 08-07-2008, 09:41 PM   #76
Musclerodz
Re: New Project at Musclerodz - '68 K20
Cab now in primer and ready for blocking.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 08-07-2008, 09:43 PM   #77
Musclerodz
Last piece of the suspension puzzle finally here. D44 from 73 K20. I am going to hate cleaning this thing up.
Mike Redpath
Old 08-08-2008, 12:38 PM   #78
steelhorse
steelhorse's Avatar
Dont you have a sandblaster?
steelhorse is offline   Reply With Quote
Old 08-08-2008, 07:53 PM   #79
Musclerodz
We have cabinets for small stuff but I send the big stuff out. I will power wash it, the mess that is left is what I really hate.
Mike Redpath
Old 08-08-2008, 11:31 PM   #80
msgross
msgross's Avatar
I had mine blasted... just take the brake parts off and put a rag where the axle shafts go in the tube....
Is that a white sealer over the bare metal?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-09-2008, 11:02 AM   #81
Musclerodz
It will be 100% disassembled, blasted, painted and rebuilt.
It is a direct to metal epoxy primer/sealer. I use white as it shows cracks in metal that gray won't show.
Mike Redpath
Old 08-09-2008, 08:38 PM   #82
msgross
msgross's Avatar
good to know about the white vs gray...im not a paint guybut want tostart learning as my truck gets closer....
The Garage:
Old 08-21-2008, 03:01 PM   #83
Musclerodz
Cab and bed are blocked for the last time before final 2 coats of primer for wet sanding right before color. Also at this time truck was seam sealed. How do you get perfect gutter seams? $60 for 2 tubes of seam sealer. Heavy body for the vertical spots and self leveling for the top that leaves a perfect gutter.
Mike Redpath
Old 08-21-2008, 03:04 PM   #84
Musclerodz
Cab has been final primed, so we rolled it up to finish the bottom of the floor. Scraped clean, seam sealed, epoxy primed, and Raptor lined. We are working on the bed right now as I post this.
Mike Redpath
Old 08-21-2008, 03:27 PM   #85
msgross
msgross's Avatar
oh, I like how that floor looks...
any info on this "raptor lining"?
also, I just noticed that your floor doesn't have the cross support just behind the high hump that my 68 does???
The Garage:
Old 08-22-2008, 09:09 AM   #86
Musclerodz
It is a truck bed coating by U-pol. Don't know about the cross brace difference.
Mike Redpath
Old 08-22-2008, 10:10 AM   #87
msgross
msgross's Avatar
thanks for the info... Few more questions..
1.How well do you think that Raptor stuff would stick to the metal strips for a wood bed? My concern is that it would flake off the edges.
2. how much of the kit was used on the floor? I want to do the floor, bed strips, underside of inner fenders and wheel wells. I assume that I would need a second kit to to the inner bedsides, tailgate, full wheel well and innerfenders.
I think that cross brace had something to do with the extra factory seat holes that my floor had. Don't know why since regular buckets weren't available in 68.
good looking work...
The Garage:
Old 08-22-2008, 02:57 PM   #88
Musclerodz
You would need 2 kits. Kit includes 4 quarts of liner and 1 qt of catalyst. I ended up using 5 qts under the bed. Lots of nooks and crannies to use material up on. It will stick just fine as long as the surface is prepped properly.
Truck has buddy buckets in it.
Mike Redpath
Old 08-22-2008, 07:32 PM   #89
Musclerodz
Pic of the bed bottom lined and the firewall and upper dash painted
Mike Redpath
Old 08-23-2008, 03:55 PM   #90
Musclerodz
Website has been brought up to date with all the build pics up to current. Enjoy... www.musclerodz.com/gallery
Mike Redpath
Old 08-24-2008, 10:45 PM   #91
ksbeatty
ksbeatty's Avatar
I started watching this thread a while back ago and I am glad to see someone is doing a 4x4. I would love to drive mine down sometime and see the build. it looks great. Mine is intended to be a nice Resto-Mod and I think we have done it. Keep us posted.
1969 GMC 3/4 Ton 4x4
2" Lift, A/C, PS, PB
383 Stroker, 700R4, 205, 4.10 GM
Medium Bronze (Copper Poly)
no new nick name yet. She is to pretty to be the Beater.
http://67-72chevytrucks.com/vboard/s...d.php?t=241855
ksbeatty is offline   Reply With Quote
Old 08-24-2008, 11:18 PM   #92
Musclerodz
You better hurry, this truck should be done in the next 60-90 days.
Mike Redpath
Old 08-26-2008, 01:33 AM   #93
Musclerodz
7 months after the truck was fully disassembled, we have color. Interior is semi gloss to keep the glare down. Looks just like it left the factory.
Mike Redpath
Old 08-26-2008, 02:23 AM   #94
nuke1
nuke1's Avatar
that is looking great, keep it up.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 08-27-2008, 01:09 AM   #95
Musclerodz
Speaker, radio, and wiper motor installed. Also the hydraulic clutch master cylinder has been mocked up. A longer rod will be required to hook it up properly.
Mike Redpath
Old 09-24-2008, 09:16 PM   #96
Musclerodz
Been sandbagging on posting pics lately. ANyways here is a start. We decided to upgrade to a hydroboost setup on this truck. Got a 1 ton unit from a 75 Chevy, had the 3/16" plate cut on a plasma cam so the firewall was not carrying the weight. Also new matching master cylinder mocked up as well. Not pictured, I am reusing the booster support rod to further help stabilize in install. Pic was taken before I opened up the firewall to allow the hydro attach nut to pass thru the firewall during intial mock up.
Mike Redpath
Old 10-14-2008, 11:33 PM   #97
Musclerodz
Last pieces of the puzzle before the orange starts to fly in the next 7-10 days. New Tri-Plus hood to replace the original that was rotted out behind the trim. Worst piece I have got from Tri-Plus. Looked very nice until we started blocking it. I have been happy with all the other Tri-Plus parts used and sold to date.
As soon as I upload the pics to the computer, I have some of the frame going together.
Mike Redpath
Old 10-22-2008, 04:33 PM   #98
Musclerodz
Hood is finally straight, only 30 or more hours in it so far.....
Also a pic of the restored steering wheel. Many hours there as well to get all the cracks out of it. Frame is being mocked up for motor relocation, clearances, etc. Pic is a few weeks old, should have new frame pics to post after the weekend when I hope to finalize everything.
Mike Redpath
Old 10-22-2008, 04:53 PM   #99
68,69 K20
They call me the Breeze...
68,69 K20's Avatar
Man, that is really starting to look sweet...Can't wait to see it finished. Diggin that hydro clutch too.
Mike
69 K20
"Beer is proof God loves us and wants us to be happy"....Ben Franklin
68,69 K20 is offline   Reply With Quote
Old 10-29-2008, 06:28 PM   #100
Musclerodz
Trick or treat!!!!!
I could not have picked a better week to start putting the color on this truck. Here is a treat for the owner Richard. The bed has turned out very nice so far. It will be sick once we get it cut and buffed next week.
Mike Redpath
