Old 03-15-2009, 11:29 AM   #76
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: PROJECT "Z069" - LS7 powered '69 Stingray....
I dropped the rear portion of the exhaust...fully welded it, and reinstalled it. Once the car in painted and the bumper is on, if need be I will cut the chrome tips shorter:
The entire exhaust system is a clamped slip fit design. This way, I can have the entire exhaust jet-coated !! To hang the mufflers, I cut half circle of pipe, then clamped it to the muffler then welded the hanger to the cut pipe. Worked out good.
Just for fun, I added an additional hanger to an existing threaded hole on the diff x-member:
Enough of the exhaust for a minute....here's a shot of the regulator mounting location...made a simple extention bracket and mounted it to the coil pack mount.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-15-2009, 11:30 AM   #77
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I set the body back on the cart, and bolted it down. It's now going to the body shop to have the engine compartment, cowl area, and the front nose area painted.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-15-2009, 11:31 AM   #78
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I ran the mufflers at a more level, less visible position (compared to a stock hang):
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-20-2009, 04:50 PM   #79
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
She looks nice .... Keep up the good work..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-23-2009, 01:25 PM   #80
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Some time around SEP 3rd.....Oooohhh, Fo SHO !!!
Well Guys....It has been a while since I've been here last....Last I heard the body was at a body shop somewhere.....Well it came back today, and the engine compartment came out JUST BEAUTIFUL !!!
Here are some shots of it when it was in primer/blocking stage a couple of weeks ago:
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-23-2009, 01:27 PM   #81
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Now check out it out in PPG Ultra Pure Super Duper BLACK !!!!
We are finally putting my custom trailer (I build years ago) to some use:
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-23-2009, 01:28 PM   #82
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Few more for tonight:
These Cell pics don't do it justice...this engine bay is CLEAN !!!!
Monday I will be starting the re-assembly....bolting the body down, FINALLY, then move on to a complete NEW harness, test fire, TEST DRIVE !!!!( :biggrin: :biggrin: :biggrin: :biggrin: ), then back to the body-shop to paint the outside !!!
STAY TUNED !!!!
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-23-2009, 01:30 PM   #83
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
PICS FROM JAN 10ish THIS YEAR !!
Just in case you all were missing me, here I am.
I have been busy trying to keep a float....but today I got some things done.
When we last left off, the engine compartment had been painted....so today I reinstalled the body...
Started off by welding up a new cross tube for my lift (cut up the last one for material)
Wiped the dust off the engine bay and the chassis:
Chased all the threads to make sure they were clean:
Blasted the body mounts and fasteners:
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-23-2009, 01:36 PM   #84
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Few last things to the rear of the engine..ground the harness, install bung for oil-pressure and 90 for vacuum feed:
After dropping the body on the frame......
Dumb-a$$ forgot these:
So I just lift the very front, and snuck them in:
Once the body was bolted tight...I moved to stripping the interior to prep the surface for some paint, sound deadener and the new wiring harness:
Tape deck anyone ?
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-23-2009, 01:41 PM   #85
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-23-2009, 01:44 PM   #86
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
One last one for tonight...What the heck is this for ?
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-23-2009, 01:49 PM   #87
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
JAN 17ish....
I'm back with a few more pics....A few days ago...I pulled the rear wheels off to tighten the rear body mounts, and finally hook up the rear spring...
Hmm....mabey the raised letter looks better on the outside
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-23-2009, 01:51 PM   #88
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Moved to the interior for more scrape'n and clean'm....
Couple shots thru the heater opening...
After pulling the carpet, I found the dimmer switch and pedal....Cool, never knew that about the vettes.
Next it was time to remove the column mounts and the pedal assembly...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-23-2009, 01:54 PM   #89
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Once on bench...I disassembled it for clean up and rebuild...The bracing will all be blasted and painted, while the three pedal arms will be powder-coated black...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-24-2009, 08:57 PM   #90
msgross
msgross's Avatar
Is that something for the radio (with the heat sinks?)
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-27-2009, 09:04 AM   #91
byrd
Union Electrician
byrd's Avatar
I am thinking the same thing, it is that or for FM radio stations. I know our trucks have the same looking part mounted to the side of the am/fm radio.
BTW I just found this thread, WHAT A BAD A$$ VETTE!!!
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 05-02-2009, 11:34 AM   #92
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
So does it breathe fire yet ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 05-02-2009, 01:03 PM   #93
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
That was a mini amp for the factory AM/FM
Not yet
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-02-2009, 01:08 PM   #94
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
(more from Jan 17ish)I found the clutch pedal pin slightly worn...so before coating, I cut it loose and welded a new one in...
Yesterday, I pushed her outside in the nice California weather we are having right now....to do a final wire-wheel cleaning of the inside, before some paint and the DynaMat goes in...
Here I'm using my old "I don't care if it burns out" wire wheel drill...
That's it for now.....Monday or Tuesday should be starting the DynaMat....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-02-2009, 01:10 PM   #95
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Jan 29 ish
Moved on to the interior with the "FAT-MAT" install. Comporable to Dyna, but a helluva lot cheaper !!!!
The mat comes in two large rolls with a blade and roller....I found out later the roller cannot stand up to the abuse of an picky installer....
I took some exhaust tubing and some angle and made myself a quick dispenser....This made it so much easier....
Let the fun begin. As I went along, I found my self wire-wheel'n a little more, spots that I had missed....just to make sure it stays down. This stuff is really sticky though.
Touched up the exposed bracing with some primer...
Templates for days....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-02-2009, 01:11 PM   #96
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Even thought it's not necessary , I use a heat gun to slightly soften and push the matting into all the nooks and cranny's and imporfections in the fiberglass...
Coming along...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-02-2009, 01:13 PM   #97
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-02-2009, 01:14 PM   #98
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Floor almost done....
Moved on to rear panel...This one took some time. I used a socket to smooth out the edges..worked out good.
I use large pieces mostly, but when possible, I use up all the cutoffs and use them up to minimize waste.
More pics soon. Need to finish tunnel, foot area and under dash. Then I will be doing the storage/battery areas and rear portion....that'll be fun !!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-02-2009, 01:20 PM   #99
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Just a few more from last Friday....Don't know about you guys, but I've had ENOUGH of this darn sticky S#IT !
I had a little help from a fellow named Mr. White...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-02-2009, 01:21 PM   #100
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Since these pics were taken, I finished the under the dash area. I am currently working on the area dirrectly under the windshield, then will move on to the back....the most important area I think for sound control.
I think this thing might be a little LOUD !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
