Old 10-03-2015, 03:52 PM   #76
Tropical Snowstorm
Lurky lurky
Tropical Snowstorm's Avatar
Re: 1967 Custom Sport Truck
Don't feel too bad, I started a drop, disc swap, and front end rebuild for my 65 Impala Christmas of 2013... Three states later I'm still not done :/
Keep chipping away at it, it'll get there. The truck is coming together quite well!
Tropical Snowstorm is offline   Reply With Quote
Old 10-07-2015, 02:42 PM   #77
67ChevyRedneck
67ChevyRedneck's Avatar
I've had my 67 firebird since 2010. I spent a weekend stripping the interior out of it... nada since...
After some back and forth with my truck club and guys that have done it on this forum... I reluctantly cut up my control arms. I flat out don't have the time or $ to do the 5 lug swap like I want to right now (20" wheels/tires, 5 lug rear end rebuild, rotor swap).
I tried to make 'em look pretty too.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-07-2015, 03:09 PM   #78
67ChevyRedneck
Cleaned back up & painted and clearance... the wheels were at their worst when at a full lock turn, so 1/16"+ of clearance should be sufficient.
My tires are from 2006 but 15" tires are pretty cheap, so I think I will be getting new tires. I'm also looking at a set of 7" rally wheels for the front to match the back (replacing the 8" rallys in the front), the combination of drop and disc spindles pushes the track width out 3/4" on each side on 67-70 trucks, so I think I'd like to tuck the front wheels back in. The 7" rally wheels have the same BS as the 8's so I'd be tucking the fronts in an inch.
In all likelihood, it will be 2+ years now before the 5 lug swap now that the front suspension is rebuilt and the rear is still good, so the tires need to be replaced out of safety, I've pushed them too long. 9+ years in the Carolina sun 24/7 isn't good for rubber.
The last pic is an optical illusion, the wheel is at full lock and there is at least 1/2"+ of clearance from the tire.
Jesse James
Project "On a Dime"
Old 10-10-2015, 12:26 AM   #79
67ChevyRedneck
Progress. PS done.
Jesse James
Project "On a Dime"
Old 10-10-2015, 12:28 AM   #80
67ChevyRedneck
I also bought two new matching 15x7 wheels. Even though they're supposed to have the same 4" BS as the 8" wheels, they have a tad bit more clearance around the control arm than the 8" wheels, so that's a plus. I didn't like how far the 8" wheels stuck out into the fender well.
Jesse James
Project "On a Dime"
Old 10-10-2015, 11:56 AM   #81
67ChevyRedneck
Found out that I actually ordered a 4/6 and not a 3.5/5 drop... oops...
Jesse James
Project "On a Dime"
Old 10-12-2015, 08:23 AM   #82
MalibuVLX
Looks great. I dig the lower stance. Not too much but aggressive. Keep up the pics.
MalibuVLX is offline   Reply With Quote
Old 10-12-2015, 10:26 PM   #83
67ChevyRedneck
Thanks!
After literally weeks of rain, I was finally able to get back to repairing the back window!
Jesse James
Project "On a Dime"
Old 10-12-2015, 10:29 PM   #84
67ChevyRedneck
I found WAY more holes than I thought there was initially. I had to repair a 3" section along the side on the PS side and about a 2 inch section on the top near the DS. I thought all those areas were good until I stripped them. I also drilled out any pitting and filled it back in. That was a long day.
Jesse James
Project "On a Dime"
Old 10-12-2015, 10:32 PM   #85
67ChevyRedneck
Found a few spots of surface rust under the primer when I was sanding, so I decided to strip the whole roof and epoxy it this time around. Ran out of daylight, so just around the window got done for now.
Jesse James
Project "On a Dime"
Old 10-12-2015, 10:38 PM   #86
67ChevyRedneck
I also almost finished the repair to the hood. The trim just barely covers the repaired area.
Jesse James
Project "On a Dime"
Old 10-19-2015, 01:05 PM   #87
67ChevyRedneck
I'm in awe of you guys that can do a suspension drop in a weekend...
I had a hell of a time getting the old U bolts out. Again, the threads were literally rusted shut. So strange for a Texas, then SC truck, especially when everything else is so clean on it. It did spend 6 years in NY with me, but it was never once driven in winter.
Anyway, they had to get cut and beat out.
And of course I couldn't install my new track bar because it would have hit the exhaust....
Jesse James
Project "On a Dime"
Old 10-19-2015, 01:07 PM   #88
67ChevyRedneck
I found a good replacement for my bump stops!
I also hauled a small load of 20 cases of coke, a couple tables and a couple coolers. I ran her for 20+ miles over a couple rough roads and I never felt the back bottom out.
Jesse James
Project "On a Dime"
Old 10-19-2015, 01:08 PM   #89
67ChevyRedneck
The new "big n littles."
15x8 rear, 15x7 front. 235/70/15 rear, 215/75/15 fronts.
Jesse James
Project "On a Dime"
Old 10-25-2015, 05:21 PM   #90
67ChevyRedneck
I screwed up the stencil the first time I tried this, but the lettering is all on the truck now.
Jesse James
Project "On a Dime"
Old 10-25-2015, 05:27 PM   #91
67ChevyRedneck
I also wanted a different look for the nose and CST trim and white should do it...
It also drove me nuts that I could see my A/C lines shining through the grille!
Jesse James
Project "On a Dime"
Old 10-25-2015, 05:34 PM   #92
67ChevyRedneck
Some sanding, tape work, primer... COLOR!
Jesse James
Project "On a Dime"
Old 10-25-2015, 05:47 PM   #93
67ChevyRedneck
Put one of the back wheels together.
Jesse James
Project "On a Dime"
Old 10-25-2015, 05:48 PM   #94
67ChevyRedneck
Tape pulled, bumper off...
Bumper polished and back on the truck...
and finally one piece of trim installed!
Jesse James
Project "On a Dime"
Old 10-25-2015, 06:49 PM   #95
nlped
nlped's Avatar
Nice
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-25-2015, 09:02 PM   #96
mooseknuckles
mooseknuckles's Avatar
lookin good!
mooseknuckles is offline   Reply With Quote
Old 10-26-2015, 05:42 AM   #97
71veronica
71veronica's Avatar
Awesome work.
71veronica is offline   Reply With Quote
Old 10-31-2015, 12:13 AM   #98
67ChevyRedneck
Re: 1967 Custom Sport Shop Truck
Thanks Guys!
Slowly plugging away at it.
The trim completely hid the hood rust repair.
I repainted my inserts flat black and I repainted my grille badge red to match the wheels.
Jesse James
Project "On a Dime"
Old 10-31-2015, 09:06 AM   #99
Advanced Design
Advanced Design's Avatar
Your truck is looking really good!
Advanced Design is offline   Reply With Quote
Old 11-03-2015, 05:40 PM   #100
rondog4416
rondog4416's Avatar
great looking truck !im planning to do my 68 Burb in the shop truck look also ! I have new nose trim that I want to put on my hood but don't know where to drill the holes, how did you do yours ? thanks for any help
rondog4416 is offline   Reply With Quote
