Old 04-06-2015, 09:19 AM   #76
SSABMUD
SSABMUD's Avatar
Re: '53 duramax
Originally Posted by SSABMUD View Post
Block first, heads last.
Is the traditional way, reverse flow is heads first and block last.
Wade
SSABMUD is offline   Reply With Quote
Old 04-06-2015, 11:42 PM   #77
lower50's
lower50's's Avatar
Re: '53 duramax
It's coming together real nice. The stance looks great. I'm mounting my IC just behind the grill, not sure what the space difference is between ours and mine. Tight either way. Good luck
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 04-07-2015, 08:57 PM   #78
fisherman420
Re: '53 duramax
looking good, keep it up!
fisherman420 is offline   Reply With Quote
Old 04-14-2015, 02:23 PM   #79
Firstgenfan
Re: '53 duramax
[IMG][/IMG]
Can anyone point me in the direction of where these go? They're front fender braces. I got the truck in pieces so I'm learning as I go lol. Pics would be great if you could get some. Thanks!!!!
Firstgenfan is offline   Reply With Quote
Old 04-14-2015, 04:51 PM   #80
Advanced Design
Advanced Design's Avatar
Re: '53 duramax
Thinking frame to rear fender just behind the tire.
Advanced Design is offline   Reply With Quote
Old 04-14-2015, 05:09 PM   #81
Firstgenfan
Re: '53 duramax
Those are different I have them too, just cant figure out where the heck these go lol. The tag on them said 47-55 front fender brace?
Old 04-14-2015, 05:16 PM   #82
lower50's
lower50's's Avatar
Re: '53 duramax
looks like inside engine compartment
1951 MG TD
Old 04-14-2015, 05:53 PM   #83
Coach529
Coach529's Avatar
Re: '53 duramax
The ones in your picture look like rear fender braces. The front fender braces are longer.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 04-14-2015, 07:05 PM   #84
Firstgenfan
Re: '53 duramax
I'll get a pic of the tag and of the rear braces tomorrow
Old 04-14-2015, 07:12 PM   #85
Advanced Design
Re: '53 duramax
There is also a brace in the corner of the front fenders. Thought these looked too long? The image lower50's put up shows a brace behind front wheel too.
Old 04-14-2015, 07:29 PM   #86
Firstgenfan
Re: '53 duramax
It's definitely not the engine compartment ones, these are too short and I'm not using them. Looks likes it's the ones behind the front wheel, just have to figure out how in the hell they go now, thanks!!!
Old 04-14-2015, 07:31 PM   #87
Firstgenfan
Re: '53 duramax
I'm not running factory floors so it's possible I'm missing holes that these would mount to as well. I'll have to dig up the ebrake brace and see if there's anything on that it'd bolt to
Old 04-14-2015, 09:17 PM   #88
lower50's
lower50's's Avatar
Re: '53 duramax
That's funny the pic shows 2 different rods but only one #. I think the lower rod is still attached to that part of the fender I cut off, ill check tomorrow and take pic for you.
1951 MG TD
Old 04-14-2015, 09:52 PM   #89
Firstgenfan
Re: '53 duramax
Thanks man! I'm not too incredibly worried about putting them on. The fenders are pretty damn solid without them!
Old 04-14-2015, 10:48 PM   #90
solidaxel
solidaxel's Avatar
Re: '53 duramax
If I remember one end of the rod bolts to the lower inner fender to firewall bolt and the other end over to the fender, there should be a hole there where it bolts to.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-15-2015, 11:56 AM   #91
99 to Life
99 to Life's Avatar
Re: '53 duramax
I run a bolt through my lower front fender into the running board, to add another bit of support.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-15-2015, 04:15 PM   #92
lower50's
lower50's's Avatar
Re: '53 duramax
Sorry I could not find the pieces. I must have chucked them last time I scrapped some metal. I was going to do what 99 said.
1951 MG TD
Old 04-15-2015, 04:34 PM   #93
Firstgenfan
Re: '53 duramax
No problem bud, thanks for your help. I didn't mess with them at all today. Did get the the front end put back together and the cab bolted back down after we pulled everything off to pull the motor back out. I can't bolt my front fenders to the running board because there's about a 3/4" gap on both pass and driver sides. I'm not sure if it's supposed to fit tight or not but the gap is the same so it does bother me. Does anyone have any advice on how to adjust the middle section of the fenders? I'm not running the support bars because of my aftermarket firewall and the turbo on the duramax would be in the way.
Old 04-15-2015, 04:55 PM   #94
Firstgenfan
Re: '53 duramax
it's not horrible but the hood isn't sitting on the rubber pads anywhere along the fender and if I put the 4 rubber pads on the hood latch panel it's even worse. [/IMG]
Old 04-15-2015, 04:57 PM   #95
Firstgenfan
Re: '53 duramax
[IMG]
[IMG][/IMG]
Old 06-12-2015, 03:13 PM   #96
eagleuh1
eagleuh1's Avatar
Re: '53 duramax
Looking good.
eagleuh1 is offline   Reply With Quote
Old 10-14-2015, 02:29 PM   #97
Firstgenfan
Re: '53 duramax
Haven't updated in forever. Finally got it back from paint and started reassembly.
Old 10-14-2015, 02:30 PM   #98
Firstgenfan
Re: '53 duramax
Old 10-14-2015, 02:33 PM   #99
Firstgenfan
Re: '53 duramax
Thanks to my awesome wife!
Old 10-14-2015, 02:34 PM   #100
99 to Life
99 to Life's Avatar
Re: '53 duramax
like the color, congrats
