Old 12-30-2017, 04:27 PM   #76
Scottish58chev
Re: 58 Apache short bed rebuild
Originally Posted by dsraven View Post
a steel wheel barrow tub makes a great bump for the firewall, unless you have other plans.
That’s a brilliant idea, wish I’d have know about it earlier lol, I may still go that route if what I’m doing doesn’t go as planned.
Scottish58chev is offline   Reply With Quote
Old 12-30-2017, 04:31 PM   #77
murd969
Your build looks great. Awesome work.
1956 Chevy 3100 C4 Suspension Build
Instagram: murd969
murd969 is offline   Reply With Quote
Old 12-30-2017, 05:06 PM   #78
Joe Pass
Joe Pass's Avatar
I did my 56 in 1992....Its like im looking at my own build seeing the fab work...nice work
Name:  01-06-2013 07;59;48PM.JPG
Name:  01-06-2013 08;18;35PM.JPG
Joe Pass is offline   Reply With Quote
Old 12-30-2017, 06:55 PM   #79
Scottish58chev
Thanks, slowly making my way through your build, some nice work.
Old 12-30-2017, 06:56 PM   #80
Scottish58chev
Attachment 1722621
Attachment 1722622
Nice looking truck, I hope mine turns out as nice.
Old 01-08-2018, 04:53 PM   #81
Scottish58chev
Managed to get the firewall done and a test fit of the engine, just need to trim behind the intake for clearance but other than that everything looks good.
Old 01-08-2018, 07:13 PM   #82
Joe Pass
Joe Pass's Avatar
Damm,,,that looks great
Old 01-09-2018, 09:37 AM   #83
Kim57
Kim57's Avatar
Looks very cool.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-09-2018, 11:07 AM   #84
dsraven
that looks awesome. intimidating for others at the traffic lights I bet when cruising starts.
how does the steering,oil pan etc fit? everything have enough clearance? I like the firewall. will you be able to fit a wiper motor in there somewhere?
keep posting pics, they're great motivators for the rest of us slow pokes.
Old 01-11-2018, 05:43 PM   #85
Scottish58chev
Thanks for the comments guys, everything seems to fit nice, hoods going to be close but there's a 1 inch spacer on the carb i can take out if i have to, steering is a flaming river unit that bolts on and seems to fit nice, the steering will no doubt need adjustment but i think it should clear the headers ok. I'll get into that once im happy with the tin work which is still a long way off as the gaps are really bad but nothing time and the welder wont fix (I hope) Test fitted the dash and wiper motor and there is loads of room. I'll post up more once i get something to report.
Old 01-11-2018, 09:08 PM   #86
_Ogre
_Ogre's Avatar
needs more motor
shop air compressor timer
Old 01-17-2018, 05:14 PM   #87
Scottish58chev
It’s as much motor as I could get
Old 01-17-2018, 05:22 PM   #88
Scottish58chev
New dash is in and decided to sort the front of the frame to enable me to fit the radiator support.
Old 01-17-2018, 05:40 PM   #89
Scottish58chev
Started to address the door gaps after I got it as square as I could. I also repaired both lower hinge mounts on the doors, they were badly cracked so I drilled them all to allow the weld to penetrate. Both doors were pretty much the same.
Old 01-17-2018, 05:49 PM   #90
Scottish58chev
I radiused the front of the cab door and I’m happy with the results.
Old 01-17-2018, 08:59 PM   #91
Joe Pass
Joe Pass's Avatar
Cool ...gaps are a lot of work....I added 1/8" wire to the door edges to mine to even them out....all in the details,,,,,
Great work
Old 01-17-2018, 11:56 PM   #92
duramax55
hi nice work will be a nice ride once done. I would like to know where you got your end for your triangulated bars on your rear end? I am sure they are cheaper than good Heim joints. Keep up the great work.
duramax55 is offline   Reply With Quote
Old 01-26-2018, 04:59 PM   #93
Scottish58chev
The mount is made using the 2 outer mounts that normally get welded to the frame legs that came with the kit that i bought from ridetech
Old 02-24-2018, 11:18 AM   #94
55 Chevy Dave
55 Chevy Dave's Avatar
Very cool build. It's going to be a great looking truck when it's done!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=654899
55 Chevy Dave is offline   Reply With Quote
Old 02-24-2018, 11:40 AM   #95
Scottish58chev
Thanks, it’s a labour of love and hate at times lol slowly seeing progress and every bit done adds to the finished truck. I had a rendering done and that’s on the garage roof and it keeps me motivated 😃
Old 03-19-2018, 11:42 PM   #96
Rods57
Rods57's Avatar
Hows the build coming?
Rods57 is offline   Reply With Quote
Old 03-21-2018, 02:33 AM   #97
Scottish58chev
Build is moving slow but steady.
I'm bad for forgetting to take pictures as i go and only remember after the fact. I've rebuilt the th400 trans and the back axle so they are good to go.
I borrowed a friends engine stand and combined with my own i made brackets to fit the front and back of the chassis and will use them as a rotisserie when the time comes blast and paint it, i'll take pictures and update whether it works or not lol.
Engine is back in place for the 4th or 5th and definitely not the last time, to make sure i had good clearance with everything now the cab is all welded up and bolted down. The steering column was fitted and i found the subframe had to be cut for clearance due to using a flaming river power steering kit, so it will need welded once its all stripped again.
Repaired the trans cover as it had been butchered and I started building my fuel tank but my tig broke down and is away getting repaired.
I'm now back at sea for 5 weeks so things are at a standstill until i get back in April.
Old 03-21-2018, 02:41 AM   #98
Scottish58chev
These last few pictures are as it sits right now. Trying to get as much done as i can with regards brackets and where everything will be placed that way i can strip it down and get the chassis blasted and painted.
Old 04-24-2018, 04:31 PM   #99
Scottish58chev
Continued work on the fuel tank after getting my welder back
Old 04-24-2018, 04:35 PM   #100
Scottish58chev
Fitted drain and made sender flange
