Old 04-08-2017, 07:56 AM   #1026
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 85 GMC Sierra "Scarlett"
When I posted this on Instagram I was asked why I didn't re-use the www.73-87.com 6x9 mounting plates.
To clarify, I must say that Jeff has an excellent designed product that was simple to install, and offers fantastic form and function for a small price.
They worked perfectly with the storage tray Chris and I had built. With Kicker Audio getting involved on this build I wanted an opportunity to improve my design skills and create an enclosure that combined storage as well as house the Hideaway sub and 6x9 coaxial speakers.
To maximize the storage space, the angle of the 6x9s needed to be changed or they would be firing toward the side of the enclosure. I chose to create new mounts for the 6x9s rather than modify the design that Jeff created.
I am still very much a fan of the www.73-87.com plates. Any time I want a quick and effective install they will be my choice.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
"Refining Sierra"
Old 04-08-2017, 11:33 AM   #1027
rustytruck50
rustytruck50's Avatar
If you haven't done it yet, you need one of those build books that guys display at the shows...these pictures are invaluable.
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 04-09-2017, 08:18 AM   #1028
N2TRUX
Happy to be here
N2TRUX's Avatar
I wouldn'tknow where to begin. I have over 1000 pics on this build saved.
Articles-
"Refining Sierra"
Old 04-09-2017, 08:28 AM   #1029
N2TRUX
Happy to be here
N2TRUX's Avatar
Yesterday I worked on the Hideaway sub enclosure again. I started off using measurements from the old storage tray. I finally decided it was hurting rather than helping so the process requires a lot of fitment time to ensure each step of the design fits.
You may find this shocking but these old trucks are not square.
Combine that with sound deader, wires and various humps and bumps that throw your measurements off and getting to things square becomes a challenge.
With that said I am a few steps closer to having the center section of the enclosure complete.
Articles-
"Refining Sierra"
Old 04-10-2017, 08:03 AM   #1030
N2TRUX
Happy to be here
N2TRUX's Avatar
Yesterday I worked on the @kickeraudio #hideaway enclosure. The center structure is complete so it's time to dress it up.
I cut strips of lauan board and glued them in place. This will work as support for the bezel surrounding the Hideaway sub enclosure. Once these are set I can build mounts for the sub.
Articles-
"Refining Sierra"
Old 04-10-2017, 10:17 AM   #1031
blazer2007
how do you secure the box to the cab ?
blazer2007 is offline   Reply With Quote
Old 04-11-2017, 11:40 AM   #1032
N2TRUX
Happy to be here
N2TRUX's Avatar
I havent decided whats going to work best yet. With the additional weight of the Kicker hideaway sub i will probably consider bolting it down through the floor.
Articles-
"Refining Sierra"
Old 04-12-2017, 10:12 AM   #1033
N2TRUX
Happy to be here
N2TRUX's Avatar
I have been slowly working on the Kicker Hideaway sub box a little each evening. I decided to change the design of this box from the past two I have built. This version has a back panel thats removable. Hopefully this design will allow easier access when I wrap it in vinyl. Consequently it has created another challenge to overcome.
Since the back is built from 1/4" lauan board, I dont feel it would be a proper attachment point for the Hideaway sub. My thoughts are the weight might be an issue, and the sub needs a solid mounting to prevent unwanted vibration.
This all equates to a more complicated mounting procedure that I think I may have resolved. I tested my theory with some scrap aluminum channel last night. The channel is to tall for the top end and pushes the sub enclosure farther out than I want it to protrude. I plan to replace it with aluminum angle that will be mounted to the side divider brace rather than the back.
Note.-
1. The pieces of MDF you see under the sub are temporary. I cut wedge shaped pieces to slide up or down to allow me to set the height of the sub. Once the sub is mounted they will be removed.
2. I choose to use the minimum amount of screws to hold everything together and keep it square. More screws and wood dowels will be added on final assembly.
3. The top of the box appears to sag in the middle. Its just an illusion that does not exist. I have laid a straight edge on it several times to ensure it is square.
Articles-
"Refining Sierra"
Old 04-16-2017, 08:24 AM   #1034
N2TRUX
Happy to be here
N2TRUX's Avatar
Scarlett gets her groove on! Easter Edition.
I spent some time at my buddy's shop yesterday using his professional grade tools. His company builds oil and gas displays and models so he has a wood shop filled with top of the line tools.
We decided with the ability to make extremely precise cuts we would make a new lid.
I located the threaded inserts to attach the aluminum angle I used as mounting brackets to hold the @kickeraudio #hideaway powered sub properly in place. These inserts allow secure mounting without running a bolt through which would be exposed.
I replaced a couple of other pieces that I wasn't happy with, and put it all back together once more. Now I can do another test fit in the cab before gluing and screwing all the pieces together.
Articles-
"Refining Sierra"
Old 04-16-2017, 08:32 AM   #1035
N2TRUX
Happy to be here
N2TRUX's Avatar
I was looking for router table ideas and came across several audio builders videos. I noticed in one he had set a piece of wood on a trash can to use as a drilling station. This gave me an idea.
I used scrap from a an attic storage project to make a work table. I cut strips to mount underneath to lock it in place.
It's simple to build and I can roll it wherever I'm working. I think I will cut a hole in the middle so I don't have to remove it to clean shaving off.
Articles-
"Refining Sierra"
Old 04-18-2017, 08:40 AM   #1036
N2TRUX
Happy to be here
N2TRUX's Avatar
Last night I made a little progress. I spent time designing mounting points for the Kicker Hideaway cover. I decided to use Velcro strips so I made blocks to place the hook and loop pads on. Each one had to be sanded to fit before gluing in and clamped in place.
While the glue was drying I fine tuned the fit and finish section at a time. Each screw hole was counter sunk and a piece of a wooden toothpick was dropped in with a dab of wood glue. This gives the screw a lot more bite and allows you to get a tighter fit.
Articles-
"Refining Sierra"
Old 04-18-2017, 08:56 AM   #1037
mcbassin
Still Learning
mcbassin's Avatar
Very nice clean work on the enclosure Ken! I'd like to get a pair of small ones for my truck when you're done
mcbassin is offline   Reply With Quote
Old 04-19-2017, 12:47 PM   #1038
N2TRUX
Happy to be here
N2TRUX's Avatar
Mike what are you looking for exactly?
Articles-
"Refining Sierra"
Old 04-19-2017, 12:53 PM   #1039
N2TRUX
Happy to be here
N2TRUX's Avatar
Since my plans for adding lighted acrylic on the perimeter didnt work out, I opted to go with direct LED lighting. I plan to run it around the Hideaway sub and inside the storage trays for ambience lighting. It will be hidden so the light will be a soft red glow.
Articles-
"Refining Sierra"
Old 04-19-2017, 01:41 PM   #1040
mcbassin
Still Learning
mcbassin's Avatar
I'd like to have some slim enclosures to slip behind my buckets. I'm not huge on premium audio at all but right now all I have is my kick panel speakers.
Old 04-20-2017, 08:17 AM   #1041
N2TRUX
Happy to be here
N2TRUX's Avatar
Message me your number so we can share some pics. I have a couple of options you might like.
Articles-
"Refining Sierra"
Old 04-24-2017, 08:00 AM   #1042
N2TRUX
Happy to be here
N2TRUX's Avatar
I decided to bolt it down through the bottom of the storage box. We measured and marked in the center of each side. I drilled and tapped the floor of the cab. I plan to add sealer when we secure it on the final install
Articles-
"Refining Sierra"
Old 04-24-2017, 08:08 AM   #1043
N2TRUX
Happy to be here
N2TRUX's Avatar
Chris and did the final fitment on the storage box. We mocked up the LED light strips and assembled once again. .
We installed the @kickeraudio
#hideaway sub back in the cab and bolted it in place. I built a raised platform that was bolted through the floor. These bolts extended through the box where the #kmc20 processor is stored. We used the mounting stud as a ground point.
All the system wires are routed around the perimeter and along the trans tunnel. They are held in place and protected by duct tape.
It's slowly going back together. I can't wait to test fire the system.
Articles-
"Refining Sierra"
Old 04-25-2017, 01:50 PM   #1044
carboncrew
carboncrew's Avatar
Looks great though! That box is perfect
________________
My very own build
My tailgating ambulance
carboncrew is offline   Reply With Quote
Old 04-27-2017, 11:18 AM   #1045
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks buddy, its finally taking shape.
Articles-
"Refining Sierra"
Old 04-27-2017, 11:26 AM   #1046
N2TRUX
Happy to be here
N2TRUX's Avatar
You would think since I mock things up in cardboard and assemble, then reassemble multiple times I wouldnt have to make serious adjustments late in the game. Unfortunately all my planning for the 6x9 boxes was off by an inch. The original design that I mocked up in cardboard was going to be very difficult to wrap and secure properly so I redesigned it a bit.
Unfortunately the new design requires me to add another inch to the box, which means subtracting an inch from each end of the Kicker Hideaway storage box. Once again, I disassembled the main box and made the necessary modifications. Now I can move forward with the Kicker 6x9 coaxial boxes.
Heres my progress from this weeks shop sessions.
Articles-
"Refining Sierra"
Old 04-27-2017, 11:37 AM   #1047
Precision Parts
Tech Help
Precision Parts's Avatar
Looking great Ken!!
Did you ever get those vent assemblies re-seated?
- Derek
PRECISION
Updates
Subscribe --->Installation Videos
Follow ------->Instagram
Like---------->Facebook
Precision Parts is offline   Reply With Quote
Old 04-27-2017, 12:43 PM   #1048
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Precision Parts View Post
Looking great Ken!!
- Derek
Derek I have not made it to the doors yet. I have an issue with one of the rods jumping off the clip that I need to address as well. I will do a full photo coverage when I install the seals correctly.
Articles-
"Refining Sierra"
Old 05-01-2017, 08:01 AM   #1049
N2TRUX
Happy to be here
N2TRUX's Avatar
Saturday was another day of design changes. From my previous build, I knew the corners were difficult due to the angles and curves. I tried my best to simplify this design but it was a battle.
I ended up with a better design only to discover the trim ring and grill stuck out to far and hit the seat back. I left the shop feeling defeated.
Chris came over Sunday and finished wiring the system. I made another new front for the 6x9 enclosure. With version 4.0 I found a way to lower the speaker and recess it in the enclosure. These mods allowed the seat to clear.
Chris triple checked his work and we reconnected the battery. No sign of smoke and the #kmc20 display came to life. Even though the rear speakers arent in place Chris started the tuning process.
Big smiles and fist bumps were abundant. The Kicker Audio install was finally live and sounded fantastic already.
Articles-
"Refining Sierra"
Old 05-01-2017, 10:31 AM   #1050
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks good!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
