02-16-2017, 09:03 PM | #1126 |
Re: Nik's 62 build
That motor mount certainly is an improvement. Keep checking things off the to do list and you'll be driving soon.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
02-18-2017, 01:35 PM | #1127 | |
Re: Nik's 62 build
Over the past couple days I've been getting the firewall finished up, putting in grommets and clips, organizing wiring etc. And just last night I had two buddy's over to give me a hand getting the motor in, as you can see below we had success! |
02-18-2017, 01:38 PM | #1128 |
Re: Nik's 62 build
All I needed to do to get the motor in was attach my front motor mount perch to the crossmember, to my surprise when I mocked it up it lined up perfectly! So all I needed to do was weld it up. I also plan to drill holes through the crossmember and install some grade 8 bolts just to be safe.
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
02-18-2017, 02:04 PM | #1129 |
Re: Nik's 62 build
02-18-2017, 07:34 PM | #1130 |
Post Whore
Re: Nik's 62 build
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
02-18-2017, 08:25 PM | #1131 |
Re: Nik's 62 build
Looks really good Nick. Nice work!
02-18-2017, 11:07 PM | #1132 |
Re: Nik's 62 build
Looks good!!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
02-19-2017, 02:47 AM | #1133 |
Re: Nik's 62 build
Impressed and pleased as always.
Looking good.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
02-19-2017, 08:22 PM | #1134 |
Re: Nik's 62 build
Thanks Doug! Thanks! Thanks rian! Yesterday I went on a parts hunt again and came back with a few neat items I got from a 61 one ton cab, one of them was a choke cable assembly, here it is. |
02-19-2017, 08:23 PM | #1135 |
Re: Nik's 62 build
Here is the old one that needed replacing badly, some kind of aftermarket cable and knob that didn't fit correctly and was also broken
02-19-2017, 08:26 PM | #1136 |
Re: Nik's 62 build
I installed it in the dash and ran the cable through a grommet in the firewall and hooked it up to the carb. Now all the dash knobs match. The yellow one below will not be staying.
02-19-2017, 08:31 PM | #1137 |
Re: Nik's 62 build
And the other item I got from the 61 cab was this neat pair of chrome coat hooks that were attached to the upper corners of the cab behind the seat, not sure if they were an option or not but I thought they would look good in my truck. Chrome is pretty pitted so I'll probably just sand and paint them.
02-19-2017, 08:34 PM | #1138 |
Re: Nik's 62 build
And this afternoon I spent a few hours bodyworking one of the inner fenders and got it sanded with 60 grit then 120, then 220 and sprayed one coat of rustoleum, sometime within the next week I'll put another coat on and get the other inner fender finished. This will allow me to start bolting all the front sheet metal on.
02-20-2017, 02:16 AM | #1139 |
Post Whore
Re: Nik's 62 build
Liking the progress man. Wish the weather was better for mine.
02-20-2017, 02:46 AM | #1140 |
Re: Nik's 62 build
Thanks tj, unfortunately weather isn't good at all here, about 40 degrees and lots of rain. Still lots of snow on the ground as well. I just put on a jacket and a hat and I'm good to go
02-22-2017, 09:44 PM | #1141 |
Re: Nik's 62 build
Didn't have too much time today but I got started on the dash extension project. I made a template from construction paper planning out where the four gauges will be located and decided how I wanted it to be shaped. Here it is taped up to the dash.
02-22-2017, 09:56 PM | #1142 |
Re: Nik's 62 build
I cut a couple of pieces out and that's all I got done so far. I'll be continuing progress on this tomorrow
02-23-2017, 01:17 AM | #1143 |
Re: Nik's 62 build
Hey Nik, man your really knocking it out of the park! Your making me feel lazy, working dispite the weather hahaha. That engine is sure looking good back where it belongs
02-23-2017, 06:21 AM | #1144 |
Re: Nik's 62 build
02-23-2017, 11:41 AM | #1145 |
Re: Nik's 62 build
Looking really great! I've never seen a engine perch like that before, my V6 has the horseshoe mount but it bolted directly to the crossmember. I think it's amazing that you are making such good progress and spending very little money along the way. Keep it up! Can't wait to see you driving her down the road.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881 1972 C-10 SWB 1962 3/4 ton LWB 2011 GMC Sierra LML Z71 crewcab shortbed |
02-23-2017, 12:17 PM | #1146 | ||
Re: Nik's 62 build
02-23-2017, 01:01 PM | #1147 |
Re: Nik's 62 build
I know I've said this before but the your attention to detail and the quality of the build is awesome! I wish I had half the skills you did when I was your age, you're going to have one sweet little head turner of a pickup soon
02-23-2017, 11:06 PM | #1148 | |
Re: Nik's 62 build
Here is the gauge cluster almost finished up, I really took care keeping the gaps tight, the welds good and smoothing it out to a finish that is so good it won't even need a spot of filler. It's all made from just plain old flat 20 gauge sheet metal. I used a hole saw to make the holes for the gauges. Here is a front view of it. |
02-23-2017, 11:08 PM | #1149 |
Re: Nik's 62 build
Here's a good picture of the bottom, the weld seam is literally invisible.
02-23-2017, 11:09 PM | #1150 |
Re: Nik's 62 build
Another shot of the bottom side
