Old 04-24-2009, 01:37 AM   #101
Frizzle Fry
Frizzle Fry's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Slowed over the past month or so due to a demanding class and lots of OT at work. I managed to get out there twice in that time including a few hours today. I'll be back out there tomorrow and my next post will include an update/pics.
Frizzle Fry is offline   Reply With Quote
Old 04-25-2009, 10:34 AM   #102
Jvsapp
Jvsapp's Avatar
i know the feeling. been slow on my projects too. work changed up my schedule. but if i had the opportunity to get OT i would be all over that as well. especially in this time of economic hardship you have to take what ever is offered to you. i've only been able to swing 3-4 hrs here and there on my swap. should be updating that tomorrow hopefully.
Keep us posted FF.
Jvsapp is offline   Reply With Quote
Old 04-26-2009, 09:47 AM   #103
68C15
blood type; Retumbo
68C15's Avatar
subscribing to this unbelievable awesomerrific project.
one thing I would do differently though is the wheels. I would go with some plain steelies to thwart off suspicion at stop lights.
68C15 is offline   Reply With Quote
Old 04-26-2009, 11:09 AM   #104
Frizzle Fry
Eventually I'll get some 16-17" Steelies and run the OG hubcaps with WWW's as my street shoes.
Here's what I've been up to. With three of the four brackets tacked to the rear end as mocked up in the car I chose to do the fourth one out on the stands due to the more difficult fitting required by the overlap onto the diff housing. Here's that tacked in place:
Rear back in place and "frame" marked for C-Notches:
Old 04-26-2009, 11:29 AM   #105
Frizzle Fry
Then, since my degree finder was loaned out, I moved back to the front.
This is a template of the S2000 frame rail with wheel center and rack center positions marked. The rack center is pretty far back and requires the engine to set back further than I had initially expected:
This gave me a good excuse to get the engine set back as far as possible. I had a couple inches left at the firewall but the intake was the limiter:
Intake plenum cleaned up a bit (unused mounting bossed removed):
Spacial conflict resolved. You can see that the throttle pedal arm shape works out perfectly for this:
The engine went in and back out again and more material was freed:
Old 04-26-2009, 11:37 AM   #106
Frizzle Fry
As much as I like footbox cooling air I decided to put some metal back:
There's a little more clean-up to do on that piece and then I'll fill in the section below it.
Old 04-26-2009, 01:20 PM   #107
msgross
msgross's Avatar
so I doubt they have pre made C-notches for that car right???
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-26-2009, 02:12 PM   #108
tdave00
Restoring a 68 SWB
tdave00's Avatar
Cool. Looks like progress.
tdave00 is offline   Reply With Quote
Old 04-26-2009, 03:20 PM   #109
dammitmitchell
the pollock
dammitmitchell's Avatar
wow......
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 04-26-2009, 07:58 PM   #110
Ironclad454
Registered loser
Ironclad454's Avatar
This is one of my favorite builds. I am in awe, very cool.
-Nate-
There is no replacement for displacement
1996 Buick Riviera 3.8L S/C V6- DD
1973 Chevrolet Cheyenne Super C/10 LWB 454/TH350
Ironclad454 is offline   Reply With Quote
Old 04-27-2009, 01:00 AM   #111
Sub-versive
Boss Hogg
Sub-versive's Avatar
Thanks for the updates!
You are awe inspiring!
Can't wait to see the finished car!
Sub-versive is offline   Reply With Quote
Old 04-27-2009, 02:05 AM   #112
Jvsapp
Jvsapp's Avatar
i have seen some newer dodge rentals running 17" steelies. i think it was a nitro or something of that nature. 5X125 bolt pattern i think. that got my mind turning about being able to cloak some performance rubber under something with steel wheels. total sleeper. AWESOME work FF. can't wait to see more progress.
Old 04-27-2009, 02:14 AM   #113
Jvsapp
Jvsapp's Avatar
i wish i could edit my last post. but here's what it is. it's a dodge caliber. one on ebay for the look. 17x 6.5 wheels.
http://cgi.ebay.com/ebaymotors/2007-...3A1|240%3A1318
also there are durango wheels same size, but wider at 7.5
http://cgi.ebay.com/ebaymotors/17-DO...3A1|240%3A1318
some of the 1500 trucks are 7" so if your bolt pattern are the same then that might be up your alley. a good score would be craigslist or local wrecking yard.
Old 04-27-2009, 11:19 AM   #114
Frizzle Fry
Yes, it's called DOM tubing
Originally Posted by dammitmitchell View Post
wow......
Thanks guys!
Thanks for the info. My current wheels are 8" wide with a 5x114.3mm pattern. I'll keep an eye out for some.
Old 04-27-2009, 01:35 PM   #115
Jvsapp
Jvsapp's Avatar
hey FF,
here's one in your neck of the woods
http://portland.craigslist.org/clc/pts/1136154529.html
sorry i have a habit of checking out craigslist in areas i have friends living in. i saw a nice plasma cutter in portland that i had my friend go check out for me.
Old 04-30-2009, 02:51 PM   #116
Frizzle Fry
Test fit With about 3/8" clearance I will definitely need poly mounts:
Old 04-30-2009, 02:58 PM   #117
6772owner
Gearhead
6772owner's Avatar
FF the fabrication skills you have just amazes me. I wish I was half that good, you are truly an artist with metal.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 04-30-2009, 02:58 PM   #118
Frizzle Fry
Got the rear links done (shown tacked but they are final welded):
I also discovered that the pumpkin was hitting the body at the same time as the axle tubes were hitting the pinch welds. So I chose to simply shave the pinch welds for now, which gave me about +3/4" clearance. Later, if I need more room I can C-Notch it and add a dome over the pumpkin.
Old 04-30-2009, 03:27 PM   #119
Jvsapp
Jvsapp's Avatar
coming along awesome FF. i would figure you would go with solid mounts for the engine? do they make poly mounts or are you going to fab some up?
also your SIG needs updating... shows updated 3/26 on the sunbeam
Old 04-30-2009, 04:41 PM   #120
Frizzle Fry
Poly bushings. Funny thing about the sig; when I try to update it it wants me to cut it way down vbulliten...
Old 04-30-2009, 07:48 PM   #121
Skirkpat
Skirkpat's Avatar
So let me get this straight, all of the engine (except acc.) will sit behind the front wheels centerline? That will be a freaking riot to drive...
Skirkpat is offline   Reply With Quote
Old 04-30-2009, 10:06 PM   #122
Jvsapp
Jvsapp's Avatar
that sucks... musta been them recent upgrades due to guys abusing the delete button...
Old 04-30-2009, 11:16 PM   #123
Frizzle Fry
Thanks!
Pretty close, ya. Should be fun.
Old 04-30-2009, 11:36 PM   #124
Jvsapp
Jvsapp's Avatar
FF looking back through your thread, i just noticed that you have the master cylinder on it's side. are you planning to run a remote tank? and how did you calculate the brake pedal pin location? without the booster so that the brakes won't be too hard to use?
Old 05-01-2009, 12:48 AM   #125
neto
neto's Avatar
Amazing build! That thing is going to fly. I have an S2000 stock and it moves like you wouldn't believe. WOW.
neto is offline   Reply With Quote
