Old 11-13-2014, 04:22 AM   #101
RockinKees
RockinKees's Avatar
Re: Dutch '59 Fleetside Longbed
Thanks Kim and OrrieG!!
Gary, it's not only that a bunch of us couldn't effort the classic cars they like, but also the government brings down a whole industrial branch!!
I think the half of parts suppliers for Classic is gone broke by the new rules.
BIG mistake!! Hope they learn from it.
Oh, you also see it on the meetings we have here, much less American cars from the 70's and 80's, there goes the historical inheritage....
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 11-14-2014, 06:22 PM   #102
Katrina/10
Katrina/10's Avatar
That's too bad for the people who have lost business, at least it seems the older trucks like yours are safe for now. Good fix on the dash!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 11-14-2014, 06:51 PM   #103
RockinKees
RockinKees's Avatar
Thanks Gary!
Tomorrow a big meet/swapmeet, let's see what amount of crowd it pulls...
Cheers!! Kees.
Kool Guyz CC
Old 11-14-2014, 06:54 PM   #104
Katrina/10
Katrina/10's Avatar
Have fun and take some pics!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 11-17-2014, 12:38 PM   #105
RockinKees
RockinKees's Avatar
Meeting was fun!
Only the pics I took are too dark, so it's difficult to see the nice things.
Tried to get a speedocable, didn't get it
So, I made my own from the original and a Chevy Van cable. Hope it works...
I only got the outer cable of the truck and a complete one from the Van.
You can turn the white drive square of off the cable, thus you can make the innercable at the right length.
Plan was to grind the nut or swivel of off the original cable and connect it to the one from the Van. I connect the two to push a 8mm rubber hose over the two parts and set them with hose clamps.
I did it so that I could slide the original nut to the desired length of the inner cable. Not too tight or too loose.
Next to the truck it works okay
So it looks like this:
Screwed into the speedometer:
The speedometer was turning a bit heavy, so I used WD40 to get it loose.
Don't know if it can hurt the speedo, but it went into the drive unit where the cable connects...
Did not test it yet, we will see if it works.
Cheers!! Kees.
Kool Guyz CC
Old 11-17-2014, 01:30 PM   #106
RockinKees
RockinKees's Avatar
Question for you all:
I'm going to run 15 inch steelies, front are 6 inch wide, rear are 7 inch wide.
What is the most common tiresize you would use?
I was thinking, front 205/70-15 and rear 235/70-15.
Does that make sense?
Cheers!! Kees.
Kool Guyz CC
Old 11-19-2014, 02:21 PM   #107
RockinKees
RockinKees's Avatar
Today at home working on the heaterbox.
The heater core seems to leak, pipes are not what they used to be, so decided to buy a new one, only this one is from a European car. If it can heat up a four door sedan, then it can heat up a small pick up too
That's why I had to change the heater box to get the core fit into it.
Also the connection of the hoses of the blower are somewhat crispy...
From this pile of parts I have to make a working heater again:
I first welded a small piece of the box together, so that the mounting bolts for the heater stay at same place. The I grinded the box loose from the mounting bolt
Next I drilled the underside of the box loose and made steel plates to make the box longer
One side of the new heater core is held by two aluminium pieces that I riveted inside the box
The other side is bolted to an aluminium angle piece, that bolts into the original holes of the box
Of course I ran out of weldinggas, so I finish this tommorow.
To get the window defrost hoses connected again to the box I used PVC pipe, that we normally use for plumbing in the kitchen, bathroom etc.
I took two end stops and drilled and turned the nuts on the lathe to get a hole for the much needed air:
To get the hoses connected I had to make a new, metal plate for the box, the old plastic one is broke into many pieces...and I don't know how it originally looked like, so I must engineer something, that I think will work
After filing the two holes from 30mm to 40mm, the PVC end stops finally fitted into the plate.
Time to stop here, because my body hurt so much I can't do no more.
Hope it's get better in the morning so we can build further with a new, fresh sense
I will take the whole bunch to the truck tommorow and will make it all fit and working.
To be continued....
Cheers!! Kees.
Kool Guyz CC
Old 11-19-2014, 05:02 PM   #108
Kim57
Kim57's Avatar
That's a heck of a lot of fab work. Nice job.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 11-21-2014, 04:24 PM   #109
RockinKees
RockinKees's Avatar
After a short brake I went full on it again
A bit of Japanese Metal Origami and you have a working heater again.
The PVC pieces are fitting like a glove!!
After test fitting I sprayed the heater black, don't know what to do with it yet.
To bolt the heater into the truck I had made a template, because the heaterpipes are in a different place:
As you all know: measure twice drill once...it works
When I went to a friends place to get his '46 Chevy dash that has to be pinstriped, I said I wanted a "new" old bench and get rid of that pimpseat that I have now...My friends buddy said "I have one for you, a 1955 original, take it, don't use it anymore!"
Well, you understand, I am as happy as a little kid!!
Pimpseat finally out!!
Original '55 benchseat in!!
Much better!!
Maybe a new seatcover in the future, but for now, it's just right
And that happend in Holland, just 14 miles away from my house...miracles happen!!
Cheers!! Kees.
Kool Guyz CC
Old 11-21-2014, 05:29 PM   #110
Katrina/10
Katrina/10's Avatar
you really got lucky finding that seat!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 11-21-2014, 06:26 PM   #111
Kim57
Kim57's Avatar
Nice job.
Kim
My build thread
Old 11-21-2014, 07:40 PM   #112
oldman3
oldman3's Avatar
Great score on the seat, nice job on the heater...Jim
oldman3 is offline   Reply With Quote
Old 11-22-2014, 08:08 AM   #113
RockinKees
RockinKees's Avatar
Thanks guys!!
You must have a little luck sometimes
Did you all see my question about tiresizes in post #106?
I am about ordering some tires but want to know what looks good on these lowered trucks...
Thanks in advance!!
Cheers!! Kees.
Kool Guyz CC
Old 11-24-2014, 04:18 PM   #114
RockinKees
RockinKees's Avatar
Today I had a little fine tune on the engine, set the timing right, tried to tune the carb, but I need a digital tachometer to do it right.
But then again, I'm going with LPG instead of petrol, so then I will be doing it again....
It's running fine now, hope it stays that way to the inspection next week
Before you forget. I'm working on this thing
At home I started with the Jag hubs, machined them down to take a Chevy rim. The center hole of a Chevy is 2,4 mm smaller then the one from the Jag.
I set the hub in the lathe and fixed it, I had 0,1 mm swinging at last. Couldn't get it better.
Thats fine by me
Finished it looks like this:
That's all
Tomorrow we go testdrive the truck, check the steering, brakes, e-brakes and what else we come along.
Then it's waiting for the inspection.....fingers crossed....you'll never know how they look at old cars
Cheers!! Kees.
Kool Guyz CC
Old 11-24-2014, 04:48 PM   #115
Kim57
Kim57's Avatar
That's pretty slick.
Must be nice to have a lathe.
Kim
My build thread
Old 11-24-2014, 04:52 PM   #116
RockinKees
RockinKees's Avatar
Thanks Kim!
Yes I'm very happy with the old lathe!!
Cheers!! Kees.
Kool Guyz CC
Old 11-24-2014, 05:59 PM   #117
Katrina/10
Katrina/10's Avatar
Originally Posted by RockinKees View Post
Thanks guys!!
Thanks in advance!!
The tire sizes you mentioned should work fine, but I think a 7 inch wheel is a little narrow on the back. I have 15x8 wheels and 235/70-15 all around on my 55, and think it looks good.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 11-24-2014, 06:22 PM   #118
RockinKees
RockinKees's Avatar
I now have 6-lug 8 inch in the back with 255/60-15.
I think that's too wide for a Jag IRS setup.
It just fits right now...
If it's too narrow, I always can widen the rims later, but now I have to work with the ones I have. That's why the question...
Cheers!! Kees.
Kool Guyz CC
Old 11-24-2014, 08:03 PM   #119
oldman3
oldman3's Avatar
Kees, if I read that correct, then the Jag has the same bolt pattern as Chevy, except center section in different?...Jim
Old 11-25-2014, 03:59 AM   #120
RockinKees
RockinKees's Avatar
Yes Jim, that's correct.
Jag has the small Chevy bolt pattern, 5 x 4,75.
Only the Jag center is 74mm, my Chevy rims are 71mm, so I machined them down with 3mm.
All fits good now
Cheers!! Kees.
Kool Guyz CC
Old 11-26-2014, 11:22 AM   #121
reaper71
reaper71's Avatar
Nice job on the heater!! seat looks very nice in her new home...
Mark..
reaper71 is offline   Reply With Quote
Old 11-29-2014, 05:20 PM   #122
RockinKees
RockinKees's Avatar
Thanks Mark!!
Not much to report today.
Went on a little testdrive around the block and everything goes well.
We're ready for inspection next tuesday.
While driving I had a feeling the rearwing doesn't help much
So took it off...
And modified it a little:
No way back now
Nice picture of the '59 next to his big sister the '58 Panelvan:
Without that rearwing I have less downforce, I noticed it at once
Or..... is it my rightfoot.....
I'll be back on tuesday, hopefully with good news...
Cheers!! Kees.
Kool Guyz CC
Old 12-04-2014, 01:04 PM   #123
RockinKees
RockinKees's Avatar
Well, I got my Dutch title
I had to go twice because the first time it was no good....
I had orange parkinglight up front which are not allowed in Holland (must be white, I didn't know that), dimlights had not the right image/pattern and one rearbraken didn't do it's job.
New headlights with internal parkinglights mounted and fixed the rearbrakes, and off we went again!
Now it was good
Just had to wait a few minutes....
First time in, here I'm happy!!
Finally inside, VIN check, is okay!
Measuring wheelbase
Well, here it went wrong.... The second inspection was good!
My buddy Niels was with me, he had a great view with me behind him!
Nice pic!
At the second inspection, this was waiting also:
With my title on hand, I can help my other buddy. He has the '58 Panelvan with broken leafs all around, so he gets mine. I don't need them anymore
So now the fun begins!!
We are building a little shop where I can work on the truck. As soon as it's ready, I'm going to change axles and do all the other stuff that I need to do!
At least no more stress to get a title....I'm happy!!
Cheers!! Kees.
Kool Guyz CC
Old 12-04-2014, 03:17 PM   #124
Kim57
Kim57's Avatar
Congrats on the title.
Kim
My build thread
Old 12-04-2014, 04:45 PM   #125
oldman3
oldman3's Avatar
Congrats, that has to be a big relief, knowing it is now OK...Jim
