Old 10-27-2014, 03:17 PM   #101
RockinKees
RockinKees's Avatar
Re: "Project Orangepeel" 52 A.D
Nice, very nice!!
Are you keeping it all steel?
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 10-28-2014, 09:19 AM   #102
reaper71
reaper71's Avatar
Thanks Kees.. To answer your ? No.. the wheel,pedals,shifter arm and interior panels will be painted wrinkle black..the theme I'm going with will tie them together,(more on that later)
Originally Posted by RockinKees View Post
Nice, very nice!!
reaper71 is offline   Reply With Quote
Old 10-28-2014, 09:21 AM   #103
reaper71
reaper71's Avatar
This is the plate i made to take up the gap between the rods..
Old 10-28-2014, 09:25 AM   #104
reaper71
reaper71's Avatar
These are a side view and fitting the plate and adapter..
Old 10-28-2014, 09:33 AM   #105
reaper71
reaper71's Avatar
These are of spacing the plate/adp. to wheel and final weld of the pieces..
Mark...
Old 10-29-2014, 10:05 AM   #106
reaper71
reaper71's Avatar
As you can see from this pic I have button head cap screws installed (i drilled all holes and tapped them) this will give a little grip
to the wheel..
Old 10-29-2014, 10:07 AM   #107
reaper71
reaper71's Avatar
Here it shows the wheel after it was blasted and final welding. will start to smooth it out next..
Old 10-29-2014, 10:10 AM   #108
reaper71
reaper71's Avatar
wheel all smoothed out
Old 10-29-2014, 09:47 PM   #109
Advanced Design
Advanced Design's Avatar
Very cool Mark. Really like the button heads. The remaining holes are for looks / grip too?
Advanced Design is offline   Reply With Quote
Old 10-30-2014, 09:39 AM   #110
reaper71
reaper71's Avatar
Thanks A.D. and yes they are once it is all painted with wrinkle black the holes will be re worked to show the metal then clear over them to prevent rust.
Old 10-30-2014, 09:43 AM   #111
reaper71
reaper71's Avatar
This is going to be the idea I had for the center cap I'm using a cone for a wheel so here go's
the first pic is of the mounting spots i drilled and tapped holes and trimmed washers..
Old 10-30-2014, 09:46 AM   #112
reaper71
reaper71's Avatar
This is the "U" I made this will be welded to the washers so it can be removed. The screw coming up is for the cone..
Old 10-30-2014, 09:47 AM   #113
reaper71
reaper71's Avatar
"U plate " and cap
Old 10-30-2014, 09:52 AM   #114
reaper71
reaper71's Avatar
The final product..
so how it works is the U plate is bolted to the wheel then the cone gets screwed on and that's it..
next up I will be working on my door latch Idea..
Mark
Old 11-03-2014, 10:14 AM   #115
reaper71
reaper71's Avatar
Ok, those of you that have seen these latches from
trique mfg. know they are pretty salty in price so..I have decided to make my own..
Mark...
Old 11-03-2014, 10:23 AM   #116
reaper71
reaper71's Avatar
So after some study of pics and trial and error I finally came up with the final design. using poster board for my templates I got them mostly figured out of how they need to work and transferred them to steel. the latches I'm using are a single catch style (it seems they don't need as much adjusting as dual) and are quieter as well. one company is (Rocky hinge) mine are U.S. made and are very well made. (do not use autoloc hinges they are junk) I paid 50.00 for them at a street rod nats in springfield.
Old 11-03-2014, 10:25 AM   #117
reaper71
reaper71's Avatar
This is what the arm looks like after drilling and bending into shape..
Old 11-03-2014, 10:27 AM   #118
reaper71
reaper71's Avatar
O.E. hole for handle
Old 11-03-2014, 10:30 AM   #119
reaper71
reaper71's Avatar
These are the plate I made of the O.E. hole before they were welded in and final look after metal finish..
Mark...
Old 11-03-2014, 11:18 AM   #120
69CST-V
69CST-V's Avatar
Nice work.....Like your do it yourself attitude. Keep up the good work.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 11-03-2014, 04:13 PM   #121
reaper71
reaper71's Avatar
Thanks Bryce!! I try and make most things if I can I enjoy the fabrication challenge..
Old 11-03-2014, 05:44 PM   #122
Green Valley Lawn
Thumbs up Re: "Project Orangepeel" 52 A.D
Bad ass wheel nice work!metal:
Green Valley Lawn is offline   Reply With Quote
Old 11-03-2014, 06:34 PM   #123
Advanced Design
Nice work! What thickness is the steel? 1/8"?
Old 11-04-2014, 10:13 AM   #124
reaper71
reaper71's Avatar
Thank You!
Old 11-04-2014, 10:14 AM   #125
reaper71
reaper71's Avatar
Yes it is 1/8" I didn't want it flimsy..
