Old 10-09-2018, 03:20 PM   #101
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: Speed Engineering LS Swap Headers Findings
Has anyone used the f-body long tube speed engineering headers on a C10? I have an fbody oil pan and want to find longtubes that don't have below the pan much if at all.
I used the C10 long tubes and have the CTS-V pan and the headers do not hang below either the engine or transmission pan. Using POL engine stands.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 10-09-2018, 03:26 PM   #102
crakarjax
crakarjax's Avatar
Hmm ok the f-body pan is 1" shallower than the cts-v. Based on your pics it does look like they would hang below the f-body pan unfortunately.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 10-09-2018, 05:14 PM   #103
1971Stepside
Almost Satisfied
Ah, I thought both pans were the same depth but the F-body was deeper toward the front of the pan. My mistake. You are right, you would be about even to a little below the pan.
Old 10-16-2018, 07:52 AM   #104
aggie91
I'm just glad to be here!
aggie91's Avatar
Originally Posted by cornerstone View Post
They do fit quite well though.
Whose engine stands/mounts did you use? Thinking of doing the same on one I am putting together...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-27-2018, 11:56 AM   #105
rgrhoward
rgrhoward's Avatar
I had to order a set after this thread, for $300 bucks why not? The drivers side flange was just a tad warped but the gaskets should seal up just fine.
Stupid question... are they supposed to be offset like that? I find it weird that they do not meet "even" at the back.
Also a close up pic of the drivers side where the header comes REAL close to a casting on the block.
rgrhoward is offline   Reply With Quote
Old 10-28-2018, 02:19 PM   #106
gringoloco
A guy with a truck
gringoloco's Avatar
Mine are close at that protrusion on the block, too. Also pretty common for header collectors to be staggered, depending on the design. Part of it is the offset of the cylinder banks, amongst other things
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-16-2018, 12:39 PM   #107
beaterku
beaterku's Avatar
I bought a set of the shorty headers for my truck.
Here are the pictures of the passenger side. It is TIGHT! I do not have gaskets in yet as this is just mockup. The v-band cannot be removed without loosening the manifold bolts. I need to check it with gaskets. That's a bummer if not. The collector is damn near touching the block. A clearance hammer may fix this. Runners 4 and 6 are touching. A little pry may loosen up this tolerance.
Overall, for $149 bucks, I can't really complain. If I have to massage them a little, I am ok with that.
beaterku is offline   Reply With Quote
Old 11-16-2018, 12:40 PM   #108
beaterku
beaterku's Avatar
Driver side. No gaskets installed yet. #1 primary is touching the block. Again, this can be clearance easy enough. V-band clears no problem.
Old 11-16-2018, 12:47 PM   #109
Macdaddy1
I used the speed engineering ram horns and had no problems with clearance.
Macdaddy1 is offline   Reply With Quote
Old 11-17-2018, 11:56 PM   #110
Project1970
14.1 @ 96MPH
Project1970's Avatar
Yes, they hang a bit below the F-body pan, but they're still about even with the trans pan.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 11-18-2018, 05:12 PM   #111
crakarjax
crakarjax's Avatar
Thank you, super helpful info as I think they'll work for me if they are at least even with the trans pan!
Old 11-22-2018, 09:49 PM   #112
Coursey
Coursey's Avatar
I have a 1976 Blazer 2 wd. Lowered 5/7.
Installing LS3/6L80e. With Tejas mounts.
Is there a reason to go with long tubes or shortys or mid length? and why?
Coursey is offline   Reply With Quote
Old 11-23-2018, 01:27 AM   #113
gringoloco
A guy with a truck
gringoloco's Avatar
Long tubes = more power and torque. Mid length are a compromise when LTs don’t fit. Shorties are a waste of time; all of the bad (heat, potential leaks/fitment issues, etc) with no real benefit over manifolds. It’s all about your priorities: power, looks, clearance, cost, ease of install, the list goes on...
-Chris
Old 12-15-2018, 08:46 AM   #114
TA_C10
TA_C10's Avatar
Did everyone use the front holes or rear holes for your engine stands? I have the performance online tube stands with sliders and mounted in the rear frame holes. Engine slid all the way forward. The long tube 1 3/4 hit the clam shell design mount on the driver's side. Looks like I'm going to have to move my stands to the front frame holes and slide the engine back instead so they clear the driver's side...
LM7 5.3 motor
POL tubular engine stands
POL engine slider mounts(clamshell)
Speed Engineering 25-1025 long tube headers
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 12-17-2018, 11:46 AM   #115
TA_C10
TA_C10's Avatar
Bueller...
Update. I slid the engine all the way back, my block adapters have the 2" slides. This worked to get the headers to clear the clamshell motor mount on driver's side. However I'm worried I might not have the cab clearance if I don't move my engine stands to front frame holes. My new stands cause me to drill new holes in cross member if I move them to front holes. Plus my stock truck oil pan may hit I dunno, it's gonna be close...
"It's only money".
Old 12-17-2018, 12:39 PM   #116
1971Stepside
Almost Satisfied
I put my POL stands in the front holes on the frame.
Old 12-17-2018, 02:26 PM   #117
Andler2008
Has anyone used the Speed Engineering Headers with an SM465 2wd? And does the C10, C20 and C30 all have the same clearance for headers? I see a lot of C10 swap headers, but I don't see anything for C30.
1984 C30 Crew Cab/Long Bed Dually -- 5.3 LM7/SM465 Build Thread Here:http://67-72chevytrucks.com/vboard/s...d.php?t=772972
Andler2008 is offline   Reply With Quote
Old 12-18-2018, 01:38 AM   #118
62chevy302
hillbilly
62chevy302's Avatar
Wow that looks awesome
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 12-31-2018, 02:18 PM   #119
Andler2008
I can confirm the LT's will fit a C30, but not with the SM465 external push-type slave cylinder.
I just installed mine, passenger fit like a charm, no problem. Gives plenty of room for the starter too.
Driver side headers hit the slave cylinder. If the slave was 2" shorter in length, I think they'd fit. It'd be super close, but they'd bolt on.
Old 12-31-2018, 03:16 PM   #120
Macdaddy1
I had to go with the speed engineering ram horn headers for my 65 c10 as all of the others hit my external slave cylinder. The ram horn headers drop down nice and avoid everything. The exhaust guy will have to finish it off.
Old 03-01-2019, 03:25 PM   #121
TA_C10
TA_C10's Avatar
1971Stepside, can you post a picture or 2 of your drivers side? I ended up sliding the engine all the way back(engine mount sliders) and its better but still just barely is hitting the top of the clamshell mount. Problem is it touches the metal right above the bolt/nut so if I clearance the clamshell then the nylock nut I'm afraid would melt....
"It's only money".
Old 03-01-2019, 03:53 PM   #122
michael bustamante
michael bustamante's Avatar
I did the same and used an f body camaro oil pan. the pan barely clears the crossmember but it clears!! header long tubes fit well but the same closeness to the block as the rest of you. no gaskets yet though!
1967custom
michael bustamante is offline   Reply With Quote
Old 03-13-2019, 02:20 PM   #123
TA_C10
TA_C10's Avatar
Here is what I am talking about. It won't matter if my engine mounts are in the front holes or rear holes, it has to do with the sliders and the clamshell mounts and their location.
I slid my engine back in the adapters as far as it goes(2" sliders) and its just barely hitting the clamshell. I'm just holding the headers up so they aren't perfect but you get the idea. I can't modify the clamshell because the lock-nut is directly below the area the header is touching and i'm afraid the heat will melt the nylon in the nut after a good heat soak. I also want to wrap the headers in heat wrap so I need room to do that too. So I guess I am going to have to clearance the front tube a little to make this work.... I just hate doing this if I didn't have to...
"It's only money".
Old 03-13-2019, 03:19 PM   #124
crakarjax
crakarjax's Avatar
I would just clearance the clam shells, just grind slow and should be just fine. if you're worried about the nylon nuts just take them out before you do it.
Old 03-13-2019, 03:57 PM   #125
TA_C10
TA_C10's Avatar
Actually I'm worried about the header heat when engine running during driving melting the nylon nylocks rather than the grinding process. If I clearance out the clamshell top shelf the header will definitely fit, but it will be about 3/16" away from the top of that nylock nut.
Thoughts? Not sure header wrap will clear 3/16" gap, it will be touching yeah?
"It's only money".
