Old 05-28-2009, 11:48 AM   #1226
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: My 1965 build thread
Originally Posted by jonzcustomshop View Post
post # 1205 that is a hood to cowl seal. it screws to the cowl.
That's correct, goes on under the cowl panel and is held in place by those screws that attach it to the body.
Still looking good...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-28-2009, 06:36 PM   #1227
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Thanks Jon!!
Originally Posted by scotts62 View Post
Looks good Alan, glad you figured it out
Thanks, but I haven't figured it out yet.
Originally Posted by blue64 View Post
where did you get your m/c bracket?
It came with the truck
Originally Posted by ruffrida2005 View Post
Alan do our trucks really have to have the bracket, I ordered my BB/MC from brotheres trucks and they didn't say anything about the braket!
I doubt it. If I remvoved the bracket (wedge on firewall) it would help in alot of ways. It would bring the angle down and my rod would be long enough to hook up the way I think it should. But that means drilling more holes in the firewall that already looks like swiss cheese. I might be able to line one hole maybe 2 holes up.
Thanks Aggie
Alan's Classic is offline   Reply With Quote
Old 05-28-2009, 11:32 PM   #1228
Alan's Classic
Sat around the shop tonight depressed and unmotivated. I finally got off my arse and did something. The booster will work out great (unless I'm missing something) with the wedge removed. It leveled it out and I can hook up the brake pedal rod. In the meantime I wanted to share this little trick, most of ya'll probably already know. It's basically the old way of making gaskets out of rolled gasket material. One of many things I learned from my Dad.
I wanted to make a template of the boosters bracket holes. So I wouldn't risk scratching the firewall.
First lay a piece of paper over the part you want to template
Once you locate and tap with a ball peen hammer lightly (the hammer cuts the hole out) install a bolt to lock the paper in place and repeat for the rest of the holes.
Then use it for whatever you need it for. This is what I used it for. It not only locates my holes, but protects the firewall.
Here is the booster angle now.
Pedal rod adjusted to a drop fit with the brake pedal against the rubber bumper.
Pedal rod is almost center of the hole.
Also tweaked the right door at the top corner. I couldn't do it while fitting cause I would have pushed the cab off of the stand. So this is how I did it.
Use a clean rubber hammer (no metal shavings) and use care doing this until you get a feel for it. Don't freak if you hear a little popping and cracking. Don't get mad at me if you screw something up. It's best to see it done first, but most don't have that luxury. Just take your time. When you push find a strong part of the door like the edge and use the palm of your hands to push. I've messed things up over my years, but I chalk it up to a learning experience and repair the damage done.
After shot, it's better.
Old 05-28-2009, 11:42 PM   #1229
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Looking good Alan, How did you paint your booster. I've heard it's really easy to screw them up with paint.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 05-28-2009, 11:42 PM   #1230
joe231
joe231's Avatar
Alan, I'm just curious why you don't want to run the wedge and bracket horizontal like they came from the factory?
CHEVY ONLY
Old 05-28-2009, 11:46 PM   #1231
jason65
Registerd User
jason65's Avatar
Good job Alan. They used a peice of 4x4 and a big hammer to get mine to fit.
jason65 is offline   Reply With Quote
Old 05-28-2009, 11:59 PM   #1232
Alan's Classic
Thanks, I taped up the holes and painted like everything else. What have you heard?
I tried mounting it that way and it looks weird IMHO. I'm after a clean look and that too me would grab everyone's attention. Plus eliminating the wedge fixed my problem with the pedal rod. So far it looks like there won't be any clearance problems.
That works great as long as it's not painted.
Old 05-29-2009, 12:04 AM   #1233
joe231
joe231's Avatar
got ya
CHEVY ONLY
Old 05-29-2009, 07:23 AM   #1234
4dranch
Shloooooong bed member #2
4dranch's Avatar
Alan, by looking at your pictures I have figured out two things for you.
1-I know why your door won't line up.
2-I know where your missing rubber mallet is.
See attached picture.
Really nice work Alan, Thanks for sharing your secrets.
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 05-29-2009, 07:29 AM   #1235
TimE
Hey Y'all!!
TimE's Avatar
Nice work Alan!
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 05-29-2009, 12:33 PM   #1236
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Does IMHO mean in my honest opinion??
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 05-29-2009, 01:00 PM   #1237
1964C10
1964C10's Avatar
In My Humble Opinion from what I understand but honest is good too
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 05-29-2009, 01:25 PM   #1238
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
thanks
Gage
Old 05-30-2009, 09:50 AM   #1239
198plus
198plus's Avatar
Nice work.......Alan
198plus is offline   Reply With Quote
Old 05-30-2009, 10:13 AM   #1240
Alan's Classic
Originally Posted by TimE View Post
Nice work Alan!
Thanks Tim
Thanks, glad you found it. I love this place. Stop by sometime.
Old 05-31-2009, 04:05 PM   #1241
Alan's Classic
Happy birthday to me, Happy birthday to me, Happy Crapday dear Alan Happy Crap day too me........
I had all intentions of getting some crap done today, but the crap got me instead.
I was on here this morning waiting for the wife to get out of the shower and I heard the down stairs toilet bubbling............What the heck (I new what it was, but didn't want to admit it on my day.) I grew up on a septic tank and never had it pumped. This new one lasted 8 years. I found out these new divided tanks need to be pumped every 3-5 years. It was packed full on the inlet side. The guy said you could probably walk on it. Nah that's alright. Normally they charge $350 but add $100 for a sunday call. He worked at it for 2-3 hours and did a fantastic job.
That's gonna set back my parts buying even more.
I removed all the rock I just put down cause I knew they wouldn't take their time with it. The tank had 2 about 18"x18" concrete plugs for access. It has been years since I had seen a septic tank. The last one I saw had 3 sections that made up a lid. And the new one even had a filter on the exit end. I couldn't believe it.
The man at work
All finished
Old 05-31-2009, 04:08 PM   #1242
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Happy Birthday Alan its my little bros also
Gage
Old 05-31-2009, 04:40 PM   #1243
drogers
drogers's Avatar
Happy Birthday Alan and sorry to hear about your septic system.
I had the same problem with the door seals on my '63. After I glued the seal into place, the door would not close. I basically just pushed the seal on, no tension, when I got to the end I had about 6” inches left that I cut off. I let it sit for about a week also thinking the compression of the door would fix it. It didn't. I finally pulled the seal off and then put it back on with a little tension. When I got it glued back in place I had another 4-6” of slack.
I think it's got to be put on somewhat tight, just not sure how tight.
I know that's not a lot of info but hope it helps.
Great progress!!
Don
My Build "63 Stepside"
Major Components
71 350 stock
86' 700R4
My Front Disc Conversion
drogers is offline   Reply With Quote
Old 05-31-2009, 05:03 PM   #1244
Strodder
Daring to be Different
Strodder's Avatar
HAPPY BIRTHDAY ALLAN. It sucks to have that happen on your B-Day.
I just had the Metzler rear tire on my bike grow a bubble the size of a hand ball. It happened in Palm Springs, and had to have the bike towed home. There goes some of my parts money too.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 05-31-2009, 06:14 PM   #1245
joe231
joe231's Avatar
Happy B-Day to you......
Talk about a S***y party!!!
CHEVY ONLY
Old 05-31-2009, 07:19 PM   #1246
greg65
greg65's Avatar
You was not kidding yesterday when you told me to stick around and I could help do some digging. Hope everything come out alright. Happy birthday Alan.
greg65 is offline   Reply With Quote
Old 05-31-2009, 07:20 PM   #1247
shortbed70
shortbed70's Avatar
Happy birthday septics suck sometimes..
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-31-2009, 07:28 PM   #1248
Strodder
Strodder's Avatar
And stink.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 05-31-2009, 08:06 PM   #1249
scotts62
One day...
scotts62's Avatar
Happy Birthday man!
Scott
93 crew cab build
Project 62
Old 05-31-2009, 08:07 PM   #1250
1964C10
1964C10's Avatar
Happy Birthday Alan!! Great looking truck btw!
1964 Fleetside LWB
1996 Camaro Z28
My build thread
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
