Old 04-03-2017, 11:03 PM   #1251
62stepside longbox
62stepside longbox's Avatar
Re: Nik's 62 build
Not a great pic but here it is with the nuts tightened down. All I need to do is bend and flare 3 short pieces of brake line and the brake system will be complete other than calipers and rubber brake hoses.
62stepside longbox is offline   Reply With Quote
Old 04-03-2017, 11:11 PM   #1252
62stepside longbox
Re: Nik's 62 build
Also made the clutch pedal stops. One for setting the return height, and one for preventing the master cylinder from bottoming out. They are both adjustable in both directions.
Old 04-03-2017, 11:13 PM   #1253
62stepside longbox
Re: Nik's 62 build
Here is the clutch pedal set to the same height as the brake pedal.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
Old 04-03-2017, 11:27 PM   #1254
Classic v6 GMC's
Classic v6 GMC's's Avatar
Re: Nik's 62 build
Nice job on the power steering lines! Sure is nice when you can make the stuff you already have work.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 04-04-2017, 10:42 PM   #1255
62stepside longbox
Re: Nik's 62 build
Thanks, and yes I am a big believer in building instead of buying things
Old 04-07-2017, 01:02 AM   #1256
62stepside longbox
Re: Nik's 62 build
Got a little time today to mount those hooks I got from the blue 61 one ton cab, I mounted them in the same location they were on the 61, not sure if they're gm or not, but they're certainly era correct.
Old 04-07-2017, 01:03 AM   #1257
62stepside longbox
Re: Nik's 62 build
A close up
Old 04-07-2017, 01:06 AM   #1258
Ronzo
Ronzo's Avatar
Re: Nik's 62 build
Tool cool for school...
Ronzo is offline   Reply With Quote
Old 04-07-2017, 01:07 AM   #1259
62stepside longbox
Re: Nik's 62 build
Also made some more progress on my dads burb, since we could not find a suburban door he bought these pickup doors a while back and I already repaired the lower rust. As you can see the window frame is a completely different shape, the burb is square and the pickup is rounded.
Old 04-07-2017, 01:10 AM   #1260
62stepside longbox
Re: Nik's 62 build
Since the old rusted out suburban doors still had good window frames and glass I cut the window frames off and removed the glass. The suburban frames were welded into the pickup door, quite simple actually. My uncle (an ex bodyman) assisted with fitting the glass and lining everything up so the door gaps are equal everywhere.
Old 04-07-2017, 09:21 AM   #1261
Advanced Design
Advanced Design's Avatar
Re: Nik's 62 build
Nice work on those doors!
Advanced Design is offline   Reply With Quote
Old 04-08-2017, 01:10 AM   #1262
62stepside longbox
Re: Nik's 62 build
Thanks Ron
Thanks Doug, they came out pretty nice!
Old 04-08-2017, 09:22 AM   #1263
Re: Nik's 62 build
Real nice work Nick.It has been a while since I seen someone convert a truck door to a burb door (or vice versa).
Old 04-08-2017, 10:10 PM   #1264
62stepside longbox
Re: Nik's 62 build
Thanks bill, with these pickup doors for such a good deal my dad couldn't pass them up.
Today I went to go treasure hunting at my favourite little junkyard again and found this 64-66 swb stepside laying way in the back on a mountain of old rims. The cab was actually completely rust free, but unfortunately the roof was screwed up terribly. I grabbed a few parts from it.
Old 04-08-2017, 10:13 PM   #1265
62stepside longbox
Re: Nik's 62 build
The main thing I got from it was this set of west coast style mirrors. They were in pretty good shape but just filthy.
Old 04-08-2017, 10:14 PM   #1266
62stepside longbox
Re: Nik's 62 build
Here they are cleaned up.
Old 04-08-2017, 10:15 PM   #1267
62stepside longbox
Re: Nik's 62 build
The backsides, the arms will still need to be stripped and painted white.
Old 04-08-2017, 10:15 PM   #1268
62stepside longbox
Re: Nik's 62 build
Here is the drivers side mocked up.
Old 04-08-2017, 10:48 PM   #1269
AJCK87
Re: Nik's 62 build
Right on Nik, mirrors look great! Man you got to take me to that yard! Every thing is beyond decayed in our years up here hahaha
AJCK87 is offline   Reply With Quote
Old 04-08-2017, 11:39 PM   #1270
namloc
namloc's Avatar
Re: Nik's 62 build
The mirror's are a cool find.Very nice.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 04-09-2017, 07:55 AM   #1271
Re: Nik's 62 build
Old 04-09-2017, 09:24 PM   #1272
Classic v6 GMC's
Re: Nik's 62 build
Mirrors look nice! I wish there were junkyards that still had old trucks here.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 04-09-2017, 11:18 PM   #1273
62stepside longbox
Re: Nik's 62 build
Thanks buddy, when you come here in the summer we'll head there to go on a little hunt. Let me know specifically some of the things you might need and I'll let you know if it's there.
Thanks fellas, and yes they are!
Thanks and yes this is the only one around here that I know of. This one has some especially neat stuff, such as this original 4x4 gmc cab.
Old 04-10-2017, 02:43 AM   #1274
Grizz1963
Grizz1963's Avatar
Re: Nik's 62 build
Nick, I love the way you just quietly get on with stuff.
Changing the rounded door frames to square is really genius, and you guys did well there.
West coast mirrors, I love them. Not right for my trucks style, but they always look great.
Glad you found a good set, for presumably sensible money.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 04-10-2017, 01:56 PM   #1275
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: Nik's 62 build
Nice find on the mirrors man. I'm gonna be keeping mine for when my 66 is done.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
