08-03-2009, 06:06 PM | #126 | |
67-72 parts collector,…
Re: Project: Blank Slate
http://www.jalopyjournal.com/forum/s...d.php?t=182382. This thread spans 2 years about bad service, lies, etc. with Stockton Wheel Co. I have actually had wheel work done by them over 10 years ago. But I guess the service has changed since then. (I had two 15x8 5-lug ralleys changed to a 5" back space. That cost about $100 per wheel, buy the time I got them shipped to me. Ouch!) Also,... Nate has a pair of 15x7, 6-lug ralleys he can "borrow" forever,... but he's trying to find a set of his own.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-03-2009 at 06:09 PM. |
08-03-2009, 08:29 PM | #127 |
Tot Roddin'
Keith is right... I do have a set of 15x7 6-lug rallys sitting in my garage, but I just hate running borrowed rims. I guess I will just have to.... not that I'm complaining!
I'd still like to locate a set, but until then I'm in debt to another buddy. If I can't locate an original set then I will just keep looking, as I think at this time before I spend some decent funds on a set of rallys, the money will go in another direction for the truck. Thanks for the info Charlie!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 08-03-2009 at 08:30 PM. |
08-04-2009, 10:14 AM | #128 |
Blaze-Air
I did not know that about Stockton.
Get those rallys on there, then go find a replacement set. OR, dip into the cookie jar for that set of Vintecs. If I go to Carlisle this weekend, I'm looking for some, for you, or just to have for later use for the project I don't have yet. |
08-04-2009, 10:24 PM | #129 |
Tot Roddin'
Thanks Charlie!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
08-04-2009, 10:30 PM | #130 |
Tot Roddin'
Now to put an end to the never ending saga of determining which KYB shocks to use on a lowered vehicle. According to the boxes shipped by ECE, and after confirming the number with the shock themselves, here's the numbers you need to correspond with your local KYB dealer:
02-7002 Front KYB GR-2 Drop Shock (344068) 02-7510 Rear KYB GR-2 Drop Shock (344055) The numbers 344055 and 344068 are stamped into the shock, and is also part of the UPC printed from KYB.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 08-04-2009 at 10:30 PM. |
08-05-2009, 08:05 AM | #131 |
Restoration Virgin!
Very good info there Nate!!!...Now get those things on!!!LOL
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
08-05-2009, 05:46 PM | #132 |
Champagne Taste on Beer Budget
So Nate what is your total drop on the Front and Back now?
Sorry I didn't read the whole thread so not sure, but did you use drop spindles or drop springs only? Also you are not running a power booster on your master cylinder is that correct? Where did you get your Prop Valve? Thanks, and sorry if this has been mentioned before as I just skipped to the last page. -Scott-
Coming Soon: Project 1970 Country Truck |
08-05-2009, 06:21 PM | #133 |
4.5/6 drop. All ECE stuff. 2.5" drop spindles, 2/6 drop springs, Super Track Bar, KYB shocks, ECE shock relocators, with a manual disc/drum Master Cylinder. (No booster)
ECE 6-lug rotors, calipers, etc. One stop shopping for a complete 4.5/6 lowering kit.
08-05-2009, 06:55 PM | #134 | |
Do you think one of you guys could get me the dimensions on those shocks (fully compressed; fully extended). N2Billet & I are trying to determine how well they'll work on a bagged ride.
08-05-2009, 07:32 PM | #135 |
SCOTI,...
I tried to go to KYB's website and find some info,... but no luck with my slow dial up. I have ECE's KYB rear shocks on my blazer with bags. (different shock set up on the front with my SD tubular a-arms) Nates are on his truck already. I'll keep looking,...
08-05-2009, 08:00 PM | #136 |
Tot Roddin'
Keith/SCOTI, I just tried to cross reference the part numbers with KYB's website, but they don't have the dimensions of the shocks.
I'm not sure if a call to KYB would benefit things or not.
08-05-2009, 08:01 PM | #137 | ||
Tot Roddin'
The parts went together rather well; I just can't wait to do it again.
08-05-2009, 08:31 PM | #138 |
Blaze-Air
I'm running these on my bagged Blazer. If you use your stock mount they will just barely hit bottom. I went with a raised upper mount. Gave about an 1-1.25in before bottom. Plenty of travel at ride.
08-05-2009, 08:45 PM | #139 |
Okay so I have a question for you then. Since I only have 3" drop springs for the rear I bought from GMCPauls do you think he would exchange them for 5-6" drop springs?
I know you got your parts from ECE but wondering if anyone has any dealing with GMCPauls on returns or exchanges? And btw how come you didn't use a power booster with your setup? I bought mine (chrome) off ebay and plan on using it with my 4 barrel intake and Holley 390-cfm carb. Are you staying stock on your 250? And how does your truck ride since the lowering process? Thanks for all the answers as all I can do is dream about mine since it's still in the body shop.
08-05-2009, 09:36 PM | #140 |
Tot Roddin'
Scott,
I decided not to run a booster because I wanted to keep it looking as stock as possible under the hood. Yeah I know the M/C and proportioning valve aren't original but to most people they don't have a clue. I am going to stick with the 250, much to the demise of several people. For some reason I live the motor and you just don't see them. After I lowered the truck it rides like a dream. I was actually a little concerned the ride would be to harsh, but it's like floating on a cloud, no joke! Keep the questions coming...
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 08-05-2009 at 09:37 PM. |
08-05-2009, 09:48 PM | #141 | |
Are you keeping your engine stock for now? I like performance so I really want to wake up this engine and have it really breath better! Thanks for answering all my newbie questions!
08-05-2009, 09:49 PM | #142 | |
1969 Short Stepside 1969 4 WD Suburban 1970 1 Ton Dually....Misfit oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door |
08-05-2009, 09:52 PM | #143 |
I think a small turbo charger might do the trick?
08-05-2009, 09:57 PM | #144 |
Blaze-Air
6 banger talk...In the olden days a 4dr chevll use to prowl the streets of Northern Va. with 250 3deuce with silly spray. We all new not to mess with him. We just had factory cars.
08-05-2009, 10:00 PM | #145 | ||
Tot Roddin'
08-05-2009, 10:01 PM | #146 |
Tot Roddin'
Gotta love a sleeper...
08-06-2009, 04:59 PM | #147 |
Anyone have ECE website?
Can't seem to find it anyplace. Thanks in advance. Looks like GMCPauls only have 5" rear drop springs so I need to sell my 3" drop springs because drop blocks change the pinion angle.
08-06-2009, 05:24 PM | #148 |
Under Construction
http://www.earlyclassic.com/Home.asp...uest+A+Catalog
Scoti/Keith, I bet if you called Mark or Stan @ ECE they would be happy to give you the measurements.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
08-06-2009, 06:03 PM | #149 | |
08-06-2009, 06:36 PM | #150 | |
Blaze-Air
