#126 |
![]() Join Date: Feb 2007
Re: Slowly I build a truck
Well I've been working right along, but I got busy and quit posting pictures, so let me try to catch up.
Cut to fit Spark Plug wires: |
#127 |
Probably should have left a little more length for timing adjustment, but I think it's OK.
#128 |
Found the spring and clip I needed for the Jack at the junk yard. I still need to find a bag for the tools.
#129 |
Running fuel line from pump to carburetor:
#130 |
7 blade clutch fan thanks to PICKMUP:
#131 |
wow that thing is looking nice
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
#132 |
Brakes took a while. Bleeding was a hassle.
#133 |
I wound up going with a 3/4 ton setup:
#134 |
Thanks JRANGER!
Radio Shack one-way diode at the alternator as recommended by Painless wiring: |
#135 |
![]() Join Date: Jan 2012
Nice build. Subscribed so I can mimic your work!
#136 |
Nice work so far, amazing how a little project turns into a full blown big one! but it is worth it!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#137 |
Thanks guys! I really had never even changed my own oil before I started this. I'm just taking it a step at a time and walk away and call my friends for help when I get over-whelmed.
Polished up the old fan Shroud and installed the radiator support: |
#138 |
I went with a 4-core radiator so I had to notch the support for brackets to fit:
#139 |
Radiator and support :
#140 |
Battery Tray and new AC Delco Battery:
#141 |
67cheby
![]() Join Date: Sep 2008
Looks great
Posted via Mobile Device |
#142 |
Thank you 67Cheby. I appreciate it.
Insulation and sound deadener from LMC, carpet from Stock Interiors: |
#143 |
I used a pencil type sautering iron along with a razor knife to burn through the carpet as needed for bolts and dimmer switch.
#144 |
67cheby
Good thinking on the soldering iron/hole punch !!
#145 |
Painting the base of the seatbelts:
#146 |
Weatherstripping - I used clips, painters tape, and black 3M gasket adhesive:
#147 |
I'm starting to feel like it's coming together!
#148 |
Label for the Jack:
That's speaker wire hanging by the gas tank just in case I figure out how to add speakers back there. Last edited by FLcustom10; 02-23-2012 at 03:40 PM. |
#149 |
![]() Join Date: Mar 2011
Looking really good....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#150 |
In the same bed as you man, never done any of this before. Me and My son are getting it done together. Keep it up!
