Old 02-19-2023, 03:30 PM   #126
hardwaa
hardwaa's Avatar
Installed.
hardwaa is offline   Reply With Quote
Old 02-19-2023, 03:31 PM   #127
hardwaa
hardwaa's Avatar
Originally Posted by hardwaa View Post
Installed.
Old 02-19-2023, 04:55 PM   #128
hardwaa
hardwaa's Avatar
Measured and drilled.
Old 02-19-2023, 07:41 PM   #129
hardwaa
hardwaa's Avatar
Yes!!! Templates are getting scrapped!!! Tubing cross members are over kill prob gonna “K” the front one. Now I can start on the notches!!!
Old 02-19-2023, 08:14 PM   #130
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: My new Beater 1959 GMC
Looking good!
Big step notch next?
Keith
Convert to disc brakes.
Old 02-20-2023, 12:27 AM   #131
hardwaa
hardwaa's Avatar
Looking good!
Yes, kind of Guessing on notch height. Rather have more room than needed vs not enuff.
Old 02-25-2023, 10:31 PM   #132
hardwaa
hardwaa's Avatar
Notch design.
Old 02-25-2023, 10:41 PM   #133
hardwaa
hardwaa's Avatar
A local dude Cade cut the notches for me on his plasma plasma cut table.
Today I got to lay the notches out on the truck. I am totally guessing on the notch size. I would rather the notch be a little bigger than not enuff. The top of the axle tube should be close to the top of the original frame when it’s all seats and Done. That will allow close to 5 inches of rear suspension “crush” more than I should need but I want to be able to carry parts and not worry about bottoming out.
Based on my math if the rear was to bottom out on the notch the rear of cab would be about 3 inches off the ground. (Not figuring tire sidewall flex) I always like to think if I sell the truck and the. Next guy wants to “bag” it the truck will can go lower than I ever expected.
Old 02-25-2023, 11:43 PM   #134
lolife99
lolife99's Avatar
Very cool.
Love the simplicity of this truck.
Stance is going to be perfect!
Keith
Old 02-27-2023, 02:54 PM   #135
6DoF
6DoF's Avatar
you going static drop that low?!? cuz that's LOW
6DoF is offline   Reply With Quote
Old 02-28-2023, 07:59 PM   #136
daveshilling
daveshilling's Avatar
That's a healthy notch!
I'd say don't worry about the next guy, but you sell pretty much all of your truck projects, so that makes sense. I'd be shocked if you don't sell this one within 60 days of finishing it and on to the next one!
daveshilling is offline   Reply With Quote
Old 03-04-2023, 07:54 PM   #137
hardwaa
hardwaa's Avatar
Learned something. I was having a hard time removing the scale of the steel. Flapper disc, cut off wheel face, finally I tried a poly carbide abrasive wheel it worked the best still a very slow process and I wore out a disc before completing 2 notch plates.
I took the plunge and soaked the pieces in white vinegar in a Tupperware container. Let it sit 48 hours wow did it work great! After the 48 hours I pulled the plates out and washed them off in another tub with water, soap, baking soda, and an sos pad.
After drying plates hit 1 with a red scotch brite pad just to see what it would do…
Very happy with results, now that I have this process it is not the fastest but there is something always to work on while plates are soaking.
I am gonna soak my 60 truck notches and see if the white vinegar still has the power to remove the scale.
Old 03-06-2023, 01:12 PM   #138
hardwaa
hardwaa's Avatar
Fun yesterday.
Old 03-06-2023, 01:14 PM   #139
hardwaa
hardwaa's Avatar
Final product
Old 03-06-2023, 02:25 PM   #140
Dan in Pasadena
Dan in Pasadena's Avatar
I must be a little low on wake up juice this morning. It took me a couple looks and re-looks to figure out the purpose of the square boat frame rails and spacers but now I've got it.
An interesting idea and one I've not seen before but then I've not see the installation of lowered rear suspension with a straight frame like yours.
Can't wait to see the further progress.
PS: PLEASE fix the rot at the bottom of your cab corners. I painted my entire truck with Rustoleum too when it was in it's shop truck iteration before I took it too far.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 03-07-2023, 07:42 PM   #141
hardwaa
hardwaa's Avatar
Top of notches done. Will finish bottom on Thursday.
Old 03-10-2023, 01:00 AM   #142
hardwaa
hardwaa's Avatar
Progress.
Old 03-12-2023, 12:26 AM   #143
hardwaa
hardwaa's Avatar
Yes!! Progress.
Old 03-12-2023, 02:10 PM   #144
hardwaa
hardwaa's Avatar
Progress!
Old 03-12-2023, 03:31 PM   #145
57FleetsideC4
Making great progress. I like the stance. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 03-12-2023, 04:35 PM   #146
lolife99
lolife99's Avatar
Love the stance!
Going to have to notch that forward crossmember for driveshaft clearance.
Keith
Old 03-12-2023, 07:10 PM   #147
youngrodder
youngrodder's Avatar
Perfect stance with the size tires/rims your going with. All of the hard work paid off to achieve the perfect stance.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-21-2023, 10:43 PM   #148
hardwaa
hardwaa's Avatar
Progress.
Fuel and brake Plumbing, and wiring next.
Old 05-22-2023, 11:30 AM   #149
6DoF
6DoF's Avatar
Old 05-22-2023, 11:44 AM   #150
youngrodder
That frame looks very nice....Well done.
Marc
