12-19-2018, 05:01 AM | #1626 |
Re: 48 Burb, bagged, 5.3, 20 year wait
Doug, you’ll be ready before the Wire and Fire
Then you’ll have a party with the boys.....
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
12-19-2018, 08:58 PM | #1627 | |
12-19-2018, 09:00 PM | #1628 | |
Non FB live right now on some prep work...if I get off the seat. |
12-20-2018, 09:37 AM | #1629 |
A few posts ago we were looking at accessory drive dimensions with concern to radiator clearance. Moving the engine back solved that more than likely. Image on the left is before and image on right is after moving it back, noticeable comparing balancer to crossmember.
And I likely gave myself another clearance issue with the intake. Adding the throttle body and intake tube shows contact with radiator, fan, shroud likely. Will know more when more pieces are put in place...again. Have three ideas to resolve that potential issue. |
12-20-2018, 09:51 AM | #1630 |
The wiring is coming along neatly.
12-20-2018, 05:00 PM | #1631 |
Wiring looks nice!
You gained an inch or so with putting the engine back?
12-20-2018, 10:44 PM | #1632 |
Thanks, he does nice work. Yes I gained about an inch or so moving the engine back so water pump tip to radiator fan clearance should be good. Going to put front end together, probably at our Wire and Fire, to check spacing.
12-20-2018, 11:08 PM | #1633 |
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
12-20-2018, 11:45 PM | #1634 |
I love nice, neat wiring. Looks good.
I wish I could make the wire & fire, maybe you could stream a live broadcast for those of us that can't make it.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
12-21-2018, 09:29 PM | #1635 | |
Thanks Scott!
Brake plumbing parts and some other stuff showed up. |
12-22-2018, 10:20 AM | #1636 |
Um Doug....How many wheels you running on this thing?
I see 12 braided lines to go from calipers/wheel cylinders to hard line.
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
12-22-2018, 11:37 PM | #1637 | |
T shirts are done and I will pick them up next week. Be cool if you and Jim could make it Mark. |
12-22-2018, 11:40 PM | #1638 |
Post Whore
Doug ...you must have been a boy scout...always prepared...do you have a flare tool for your hard brake lines?...I've got a Eastwood one if you have a need for it
12-22-2018, 11:50 PM | #1639 | |
I think it’ll be a great event! And t-shirts!
12-23-2018, 12:00 AM | #1640 | |
If you are able to make it up, please bring your Eastwood one along. It would be interesting to compare it to the Mastercool hydraulic flaring tool I have. We are in good shape with benders too. We all dislike crappy benders and we loaded up with each size of a high quality bender from Gulley performance. For fuel lines we have the design pencilled out, Nathan bought a big quantity of fittings from Jegs, we have the flexible line, and will have straight tube to give us options too. My Christmas present to myself a couple years ago was the Cool Tools fitting press so we have that. And we will also have the homemade one Nathan put together for comparison purposes. This is going to be fun. |
12-23-2018, 12:07 AM | #1641 |
Post Whore
This is the one I have...a hotrod buddy talked me into it...it works great....
12-23-2018, 12:13 AM | #1642 | |
Guys, out of great respect for those that are investing their money, time and effort to be here and to honor my wife, please know my family, friends and I are doing all we can to make sure we have a fun, safe, productive and really enjoyable event. Some of the hospice folks will be here too. Now if the weather will cooperate... |
12-23-2018, 12:16 AM | #1643 |
Those look pretty slick! They weren’t out when I bought the Mastercool.
12-23-2018, 03:09 AM | #1644 | |
hahaha holy shoot. I have no idea why this struck me as funny, probably because I have MADE three trips for the same parts in the past I have been thinking about it the wrong way! why fight? make one trip and buy three times as much, no matter how you slice it, its more efficient!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
12-24-2018, 06:12 AM | #1645 |
It’s going to be an awesome event, too bad I can’t be there...
It’s like living on an island I have worked on Curacao for several years, there did we have the same problems with parts, everything had to flown in or make it yourself if possible. But you tackled these problems I’m in for a livestream, I always watch Dragracing on livestream, works perfect!! You can do a livestream on FB or YouTube maybe? If you do, please let me know? Merry Christmas everybody!!
12-24-2018, 05:50 PM | #1646 | |
Roughing in the LS wires and mounting components under the seat. Using the stripped down original harness and modifying to fit rather than buying a new one due to the placement of the PCM, TAC module and harness fuse box here. |
12-24-2018, 07:20 PM | #1647 |
No problem at all Doug, but it would have been nice ;-)
Wish I could be there with you and meet all of you, but as always, money is in the way... I know you have a good time, I see the pics afterwards and have a laugh with you!! Merry Christmas!!
12-24-2018, 08:58 PM | #1648 |
Post Whore
Doug...if you keep up this pace there won't be anything left to do at the Jan 19 wire/fire except give people joy rides in the burb..
12-24-2018, 11:48 PM | #1649 | ||
And I might have to rethink the line connection to the caliper. It looks like this will put too much stress on the aluminum. |
12-25-2018, 09:14 AM | #1650 |
Banjo bolt style Doug.
