Old 05-23-2012, 09:53 PM   #151
grayharville
^^who I am^^ what I say>
grayharville's Avatar
Re: Project 78 High Sierra
I love the look of semigloss stuff.. you might have a wire pinched in the door where they run from the door to cab.
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 05-23-2012, 09:55 PM   #152
JRANGER
JRANGER's Avatar
thanks man im looking into it....ive removed the old one and it doesnt look that way but im going to dig in tomorrow for sure when i have light left
JRANGER is offline   Reply With Quote
Old 05-24-2012, 09:13 AM   #153
JRANGER
JRANGER's Avatar
So even though it looks pretty rough since i did no prep work basically...I think the semi gloss black i put on the grill will look nice on the truck
Old 05-24-2012, 09:34 AM   #154
motornut
78K & 79C Jimmys
motornut's Avatar
looks real nice with the white faces
they realy pop
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-24-2012, 09:36 AM   #155
JRANGER
JRANGER's Avatar
Thanks!! The white faces are awesome especially with a brand new lens on
Old 05-24-2012, 01:07 PM   #156
pugraham
pugraham's Avatar
You did some awesome work on that dash, Im getting ready to clean up and rebuild my dash and def going to take some pointers from you
1978 Chevy K20 3/4 Ton 5.7L 350 Auto
1993 Chevy S10sb 2.8L V6 5 Speed
Photobucket with all pictures of builds and trucks
http://s1256.photobucket.com/albums/ii483/pugraham/
pugraham is offline   Reply With Quote
Old 05-24-2012, 01:15 PM   #157
JRANGER
JRANGER's Avatar
Thanks, let me know if you need any tips and ill be happy to provide any helping tips i can
Old 05-24-2012, 07:06 PM   #158
JRANGER
JRANGER's Avatar
Well the white wire seems fine but I found 3 cut wires near the duct in the console...A yellow, Black, and gray wire....I assume these are accessory wires and may be the reason the stereo is run all to itself...
Any ideas?
Old 05-24-2012, 09:10 PM   #159
JRANGER
JRANGER's Avatar
OK so I have the dome working except for the fact that its only if the key is in the car....If i wire it direct to the battery it will work like it is suppose to but thats a lot of work for something i prob dont need.... Either way the ACC fuse spot is still jacked and I dont know why.....I assume the power wire to it is ground out...Anyone know what wire in the engine bay goes to it??? Or how i can trace it? I sure dont want to remove that fuse thing and look at the back of it
Also the new door jamb switch are ghetto!!! The screw doesnt go the whole distance so after putting them on they were loose! I had to remove them and add a washer and of course in doing so i lost the wire in the hole and had to play fish a wire.... Needless to say after putting them back together i added electrical tape to keep it all together..
Old 05-24-2012, 10:11 PM   #160
x ReAcT x
Does that duplicolor work good? I bought that $100 kit they sell at AutoZone and was thinking about putting in the bed. Did you just scuff up the area and roll it on? It looks great so im hoping mine turns out this good.
1986 GMC K15 4.3V6/SM465/NP205
will be converting to
5.3LS E-ROD/AA adapter/SM465/NP205
10 Bolt Axle Rebuild Tutorial:
http://67-72chevytrucks.com/vboard/s...d.php?t=536415
x ReAcT x is offline   Reply With Quote
Old 05-24-2012, 10:14 PM   #161
JRANGER
JRANGER's Avatar
I used spray cans of it but I wire wheeled it down and then took some sand paper over it... Used soap and water on it and then used alcohol all over it... Its pretty smooth but i really like it....
Old 05-24-2012, 11:35 PM   #162
motornut
78K & 79C Jimmys
motornut's Avatar
Any ideas?
yellow-radio- ign power
black -radio-grnd
grey - cluster /dash lights
can I ask how the radio is wired
got pics?
John
Old 05-25-2012, 09:14 AM   #163
JRANGER
JRANGER's Avatar
Hmmm....That makes me wonder about the grey wire since all my cluster and dash lights work....
The radio is powered by a Red fused wire going to the fuse block and smashed in with a fuse, I ran a direct wire from the battery for the memory wire, and its gorunded out to the frame from a wire i ran after finding a crap ground on it.
So my assumption is the guy didnt feel like finding out why the ACC fuse wouldnt stop blowing and just wired it in like it is.... I figure there is a power wire grounding out somewhere going into the ACC just have no clue where
Old 05-27-2012, 08:40 PM   #164
JRANGER
JRANGER's Avatar
Patch the fender..nothing perfect..Just needs some bondo and smoothing
Old 05-30-2012, 10:45 AM   #165
Chevylongbed
ohh nice work man i liked it
1987 Chevy C20 LWB Stepside
2009 Mercedes-Benz C63 ///AMG
2013 Lexus LX570
Chevylongbed is offline   Reply With Quote
Old 05-30-2012, 05:03 PM   #166
Rusbuilt
Rusbuilt's Avatar
So you're gonna flat black it??
Rusbuilt is offline   Reply With Quote
Old 05-30-2012, 05:11 PM   #167
JRANGER
JRANGER's Avatar
I'm actually going Semi Gloss Black...So it will be a bit more shiny then a satin finish but not a much as a gloss
Old 05-30-2012, 09:10 PM   #168
JRANGER
JRANGER's Avatar
Ok I couldn't resist....With over half a can of Aerosol Rust-Oleum Professional Semi-Glosss Enamel left after my Grille test. So....I covered my hood with a sheet and hit the fender with 2 coats...
Cant wait to see it dry
Old 05-31-2012, 12:20 AM   #169
Rusbuilt
Rusbuilt's Avatar
Sweet dude. I like it!
Old 05-31-2012, 08:48 PM   #170
JRANGER
JRANGER's Avatar
2 Pics of the first 2 coats dry
and
2 pics of after 600 sand and 2 more coats
Old 06-01-2012, 04:45 PM   #171
JRANGER
JRANGER's Avatar
So I love the color but I realize with the gloss that I failed to see a lot of dents and dings...Damn...O well...Its a truck lol
Old 06-01-2012, 09:24 PM   #172
JRANGER
JRANGER's Avatar
sanded with 600 grit again and hit with 3 more coats...Its orange peeling bad though damnit
Old 06-02-2012, 10:55 PM   #173
JRANGER
JRANGER's Avatar
Went to pull a part today and bought a glove box that had a piano hinge riveted it
A gauge Cluster (Worthless)
A Couple Extra Gauges
A tail light (Wrong side damnit)
A side marker light (opps thought i needed it)
A pristine dash bezel (Just because)
A cut up engine wiring harness plate
Then I tested out the gauge bezel and the speedo was shot.... didnt work at all
Then I tested the speedo that i got separate...Just put it in with no bezel direct to the cable and wahhhhlaaaa!!! The speedo doesn't float or do anything weird anymore...
Realized my gas Gauge is off as it is reading funny and when i put the other gauges in it said it was empty...Added gas and it went up...Guess I really messed up when I removed needles..
Took apart the gauge bezel and painted the inside white
Painted the black metal piece white on the back and hit the front with flat black primer
Ordered new white faces offline
Installed new strikers
and Got my Bench Console made by a member on here.
Old 06-03-2012, 06:36 PM   #174
JRANGER
JRANGER's Avatar
Didnt get much done today but hit the glove box plastic with some fresh paint
Old 06-03-2012, 07:01 PM   #175
Rusbuilt
Rusbuilt's Avatar
progress!
