Old 04-09-2013, 09:51 PM   #151
77ChevySharkBite
77ChevySharkBite's Avatar
Re: 1967 Mustang Coupe Build (Electra)
I think you should do it yourself!! You did your trucks you can do the stang!! we believe in you Jeff!!
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 04-09-2013, 11:48 PM   #152
JRANGER
JRANGER's Avatar
lol, Gotta check all the stuff before going cut crazy!! In time my friend
JRANGER is offline   Reply With Quote
Old 04-10-2013, 09:31 AM   #153
77ChevySharkBite
This is a true statement, also probably why I'm not big into electrical items because I would just start cutting stuff, but I do need to learn some soldering, so I'm sure soon I'll find an excuse to do some electrical stuff!
Korwin
Old 04-10-2013, 10:13 AM   #154
JRANGER
JRANGER's Avatar
Plus now i have an extra gauge si u can just do some wiring direct to the sending unit and test it without cutting anything So ill test direct before going crazy, trace some wires etc etc
Old 04-10-2013, 07:50 PM   #155
JRANGER
JRANGER's Avatar
Well now im really confused because either i have a bad sending unit (Which i replaced) or im not getting oil pressure.......I wired a gauge directly too the sending unit and too the ground and got nothing with the car running...Im lost ugh
Old 04-10-2013, 07:56 PM   #156
JRANGER
JRANGER's Avatar
took my volt meter to the sending unit and its getting no voltage...So im not sure whats going on weather the unit it bad or im not getting oil pressure
Old 04-12-2013, 09:31 PM   #157
JRANGER
JRANGER's Avatar
And im all like BOOM!!!! lol So I got home today and my Voltage Regulator for the car and for the cluster finally showed up. I quickly installed them and then started to think. On the ride home the oil blew out the dipstick so I know i have oil pressure. So I checked the oil and ill be damned if their is barely any oil in there. Well go to Advanced and realize adding oil is just as expensive as their $19.99 special. So I get oil and a filter. Well god knows when the last oil changed was as it was nasty black and their was surface rust on the filter. It was damned hard to even get the filter off!! Either way i got the oil changed and it takes awhile but eventually it starts showing oil pressure on the gauge. So all my gauges now work!!!!!! Woohoo Can you tell im in a good mood? Prob will have to do another oil change pretty quick because im pretty sure the old filter was clogged up thus why the oil blew out the dipstick on the ride back from ATL...
Old 04-13-2013, 06:46 AM   #158
Rusbuilt
Rusbuilt's Avatar
Awesome Jeff!
Rusbuilt is offline   Reply With Quote
Old 04-13-2013, 04:41 PM   #159
67ChevyRedneck
67ChevyRedneck's Avatar
EEEK! Hopefully it didn't do any damage! You may want to drop the pan and replace the oil pump if it was that bad! It's probably covered in sludge. The pan is probably pretty dirty still too.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-13-2013, 08:55 PM   #160
JRANGER
JRANGER's Avatar
yeah...back to no oil pressure today so its concerning..
Old 04-16-2013, 11:25 AM   #161
77ChevySharkBite
ouch! I hope you figure it out Jeff, I know with a little bit of trouble shooting you can get it done!!!
Korwin
Old 04-17-2013, 09:42 AM   #162
JRANGER
JRANGER's Avatar
Im thinking their is just a clog in the extension because the engine sounds great when running. No ticks, knocks, or anything... So im going to try to pull the extension off a clean it up a bit
Old 04-21-2013, 01:53 PM   #163
JRANGER
JRANGER's Avatar
Well it has been confirmed! I have oil pressure...Manual Guage shows a strong 50PSI so its more likely i just have crap gauges...BLAH lol....
Old 04-21-2013, 11:33 PM   #164
67ChevyRedneck
I figured it couldn't have been anything too catastrophic... I mean, you did drive it from Ga to Tn.
Jesse James
Project "On a Dime"
Old 04-28-2013, 02:46 PM   #165
JRANGER
JRANGER's Avatar
Well the weekend has been interesting. Got to go down to AL with Rusbuilt and pick him up a nice toy. Then had to attend a party so I didnt do anything saturday but today I managed to do a little work on the floor panel. Lots more to cut out still but got it cut out above the support and jsut need to cut it out next to the door. Plus some other little spots
Old 04-28-2013, 06:54 PM   #166
Denee007
Denee007's Avatar
Hi, I've been following you~ Are you going to cut the piece in question out? I remember taking this piece out~ I took my torch and lightly applied O2 to blow it away. It has spot rivets, but was easier just to do what I did. The channel or rocker is galvanized I think~ or had some kind of coating on it. I had to grind it down to metal to weld my new floor pan in/ stitch welded it into place. Are you going to replace that entire floor pan or just what you need?
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 04-28-2013, 07:16 PM   #167
JRANGER
JRANGER's Avatar
My plan is to cut the rest out towards the door but thats really it. Im going to coat the support with weld through primer and drill some holes in the panel to sport weld it down. Im only planning to replace what is needed. The metal to the left is pretty solid except where it angles up. So im going to cut that little section out and weld in a patch there too.
Also i cut out the big section next to the support then in the middle of the support and used a claw hammer to pop the weld/rivets off. It was fairly easy
Old 04-28-2013, 07:22 PM   #168
Denee007
Denee007's Avatar
Good plan~ I remember it was pretty horrible replacing my floor pans, plus never having done floor pans,eek! that was about
'09, seems like I have more aches and pains since then! lol No more floor pans! I think these old cars are taking a toll on my body!
Old 04-28-2013, 07:25 PM   #169
JRANGER
JRANGER's Avatar
LOL... I had to do the floor pans on the truck so i have a little experience. Just making sure I dont cut anything as I do it. The truck was easier though as I can just crawl under it.. Im hoping maybe i can cut the panel up next weekend and start fitting it but i still have a bunch to do so we will see
Old 04-28-2013, 08:49 PM   #170
thelonerife
thelonerife's Avatar
good job Jeff
thelonerife is offline   Reply With Quote
Old 04-28-2013, 10:05 PM   #171
JRANGER
JRANGER's Avatar
Originally Posted by thelonerife View Post
good job Jeff
Thanks Chuck!
Old 04-29-2013, 09:28 AM   #172
Rusbuilt
Rusbuilt's Avatar
Hey Jeff! Check this out! Cheaper wheel solution and a little inspiration!
http://nashville.craigslist.org/pts/3772557852.html
Old 04-29-2013, 09:46 AM   #173
77ChevySharkBite
Your getting work done man! Looking really really good bro!! Keep it up.
how's you knee doing? haven't heard an update lately on it.
Korwin
Old 04-29-2013, 09:46 AM   #174
77ChevySharkBite
Hey Rus, those rims are from like the 06 style mustangs huh?
Korwin
Old 04-29-2013, 09:47 AM   #175
JRANGER
JRANGER's Avatar
Wow that looks awesome...but as usual I dont have the money...lol o well
Thanks for the inspiration
