Old 05-28-2009, 09:22 PM   #176
Twisted Minis
Twisted Minis's Avatar
Re: Not so budget 3-link build
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 05-28-2009, 09:45 PM   #177
GRIMSS
GRIMSS's Avatar
Nice job. I would like to see pics of this one when finished.
VW's are my other passion.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 05-28-2009, 09:53 PM   #178
Twisted Minis
It's leaving tomorrow morning, so I will take pictures of it when it comes off the lift. It doesn't sound like it's coming back for a while to get the rest done, as he has more parts collecting, planning, and saving to do.
Old 05-30-2009, 01:52 AM   #179
Twisted Minis
Pictures of it outside. The rear wheels are on the front, because the Porsche axle is a bit wider than stock, and they didn't clear. He said he can get some more rear wheels with another +10mm offset to suck them in enough to clear.
Old 05-30-2009, 01:55 AM   #180
Twisted Minis
And I started one of the control arms for my project. Pretty different than the norm.
Old 05-30-2009, 08:02 AM   #181
GRIMSS
GRIMSS's Avatar
Nice work on the double cab. Man that thing is clean looking.
Good looking start on those control arms also.
2001 GMC SIERRA
1968 Camaro
Jared
Old 06-03-2009, 10:41 PM   #182
Twisted Minis
Upper arms are done, lower arms are about 70% done (should be 100% tomorrow) and I started building the LCA mounts. I boxed the front side, and above the bushing, I need to weld it to the frame on all sides of the tabs, and then put the boxing plates on the back.
Old 06-04-2009, 01:59 AM   #183
AceX
>130dB Moderator
AceX's Avatar
Seth, your project is looking to be one bad ass piece of equipment...
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 06-05-2009, 01:17 AM   #184
Twisted Minis
I didn't finish the arms, but I finished the LCA mounts. I realized that they needed to be done before I could finish the bag mounts on the lower arm.
I just got the steering rack too, so I might get that mounted next week.
Old 06-06-2009, 07:16 PM   #185
Twisted Minis
Control arms are finished at this point, until I add shocks mounts and some other things in the future.
Old 06-07-2009, 12:18 PM   #186
scotts62
One day...
scotts62's Avatar
Those look good! Nice work!
Scott
93 crew cab build
Project 62
Old 06-09-2009, 12:05 AM   #187
Twisted Minis
Here's a teaser of the front end.
Old 06-09-2009, 12:08 AM   #188
p8ntballer1911
Bodydropped71
p8ntballer1911's Avatar
very unique... love your work!
p8ntballer1911 is offline   Reply With Quote
Old 06-09-2009, 07:27 AM   #189
scotts62
One day...
scotts62's Avatar
That's going to look awesome when its put together!
Scott
93 crew cab build
Project 62
Old 06-09-2009, 03:09 PM   #190
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
that is pretty crazy dude. Wish I had the tools I would try something like that just for fun!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 06-10-2009, 03:01 AM   #191
Twisted Minis
I had an idea late last night, to build a boxed style gusset with a hole (tube) welded in the center of it. So today I cut out enough pieces to build 4, and got one welded together. It's way overkill, but I think it matches the arms well and I like it. Also you may notice in the last picture, the laser cut piece I got for the spindle with my crown logo on it.
Old 06-10-2009, 08:26 AM   #192
aggie91
I'm just glad to be here!
aggie91's Avatar
Seth
Your work gets better every time I see you do something new. In post 187, you say its a teaser shot of the front end. I'm I missing something, it does not look like that spindle will rotate enough to turn the vehicle, or I am I just not seeing it? Even it that last picture, it just does not look like it will turn...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-10-2009, 08:42 AM   #193
ruffrida2005
It will spin the Hub isn't welded to it, just the spindle!
Paul
Old 06-10-2009, 08:44 AM   #194
aggie91
aggie91's Avatar
NO, not spin, turn the vehicle left or right...
Karl
The LST Challenge:
Old 06-10-2009, 08:55 AM   #195
ruffrida2005
yeah he's got a super pivot joint on the bottom and a heim joint up top. Not sure how much angle he will get out of it but it will turn.
Paul
Old 06-10-2009, 08:59 AM   #196
ruffrida2005
Think of it as side to side motion on a 4 link, These are the same parts!
Paul
Old 06-10-2009, 10:33 AM   #197
ShowSS12
ShowSS12's Avatar
I keep wondering what is this for? I have never seen any thing like this before..
Adam M
STX Designs
Motorcycles | Choppers | Hotrods
ShowSS12 is offline   Reply With Quote
Old 06-10-2009, 12:17 PM   #198
bmfpeterson
bmfpeterson's Avatar
You see more of those setups on the off road trucks....Personally its my favorite setup! you can get a lot of travel out of a vertical uni ball setup... plus it looks *****en!!!!!
bmfpeterson is offline   Reply With Quote
Old 06-10-2009, 01:34 PM   #199
Twisted Minis
Originally Posted by aggie91 View Post
Seth
I'm not sure what doesn't 'look' like it will not allow turning? I will take a stab at it.
It's got a vertical mounted Uniball on the bottom, and a vertical rod end on the top. There is no limitation to up and down travel, only to turning. But it still turns about 38 degrees in each direction, which is close to what a stock vehicle can do. It will limit me in tight U-turns a bit, but that's not a big deal. I am building it to have a narrow track width, so I will be able to make those wide U-turns without lifting the truck up.
The rod ends also act as a steering stop. Instead of having something on the spindle and arm that hit eachother. I originally had the upper set up as a 3/4" rod end with 1/2" misalignments, but it was turning too far, so I stepped up to 9/16" on the top. Now it limits the steering just before the tire hits the frame, which is perfect for me.
If I get the upper arm tacked on, I will throw the wheel on, turn it and take a picture.
Old 06-10-2009, 01:52 PM   #200
SCOTI
SCOTI's Avatar
I was curious about this when I first saw the pics but figured in time more info (& pics) would come forth. I assumed the uniballs limits would be the 'steering' stops. Cool, cutting-edge stuff for sure!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
