Old 06-27-2009, 12:20 AM   #176
joe231
joe231's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
very cool!
I believe your "vision" is better than 20/20
CHEVY ONLY
Old 06-30-2009, 12:03 AM   #177
CG
BlahBlahBlah
Maybe you should pick this up too..
http://seattle.craigslist.org/est/cto/1244837903.html
Old 06-30-2009, 01:09 AM   #178
Frizzle Fry
Frizzle Fry's Avatar
Those are cool. Even cooler (to me) are the earlier Husky's:
And the Estate Wagons:
Frizzle Fry is offline   Reply With Quote
Old 07-01-2009, 05:37 PM   #179
Britain Smith
I like the grill on that Blue one.
-Britain
Britain Smith is offline   Reply With Quote
Old 07-03-2009, 10:07 PM   #180
Mullet '72
Mullet '72's Avatar
*** super subscribed to this one***
: NO, I will NOT take $200 for it
'72 C-20 Suburban
Mullet '72 is offline   Reply With Quote
Old 07-07-2009, 12:40 AM   #181
lofly'a
lofly'a's Avatar
just read this entire thread, and again i tip my hat to your mad skills.
any post with your name, LFD, or Portbuilt attached i read like a bible. not always the direction that i'm going but the thought process and problem solving is near genious.(there are others too), it's just that these 3 names come to mind first. keep it up guys.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 07-07-2009, 03:11 PM   #182
Frizzle Fry
Thank you sir. Don't read it like a Bible because I do make mistakes as I'm about to show
Here's a long overdue update:
Because of the fact that the front clip on these things is welded on, none of the front sheet metal is easily removable including the inner fenders. It may be hard to see in the pics but the outer wall of the frame rail was left longer than the inner wall so that I will have access to weld the S2000 section on in front of the inner fender.
In order to place the S2000 section where it needs to go I had to remove the outer wall of the S2000 rail in the same area (was considering a lap). When put together they form a completed box all the way around. And of course I will be adding plate over that.
Mocking up the rest:
I put the wheel on the check centering in the wheel well and DOH!!! How the heck... too far forward
While the wheel was on I checked how much I'll need to shorten the arms by. Looks like about 3" minimum. I may just pickup two more wheels with more backspacing so that the new arms can be a little longer. Luckily these are still in production.
Old 07-07-2009, 03:16 PM   #183
*Dylan
Mean Buzzin' Half Dozen
*Dylan's Avatar
So what needs to be done now for the wheel to be moved backwards?
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale)
1967 C10 SWB
Dylan
*Dylan is offline   Reply With Quote
Old 07-07-2009, 03:23 PM   #184
Frizzle Fry
I considered building the wheel centering offset into the arms by moving the balljoints back the required amount, but I really want to maintain as much of the S2000 geometry as possible. So I took the route of moving the the rail section back 3/4".
Yep, 3/4" is all it needs... (camera lens not centered on string)
But that's a long 3/4 of an inch considering what's required ...expanding the notch
I didn't take pics of the completed notch expansion but that section id just plated in with flat stock.
3/4" off here:
...and here:
That took it from here:
...to here:
Now that notch is really earning its keep:
Old 07-07-2009, 03:27 PM   #185
Frizzle Fry
In the end it was worth the effort:
Next up: make/update templates of everything I've done on the PS and start welding it in The DS should be much faster after working everything out on the PS (in theory)
Old 07-07-2009, 03:46 PM   #186
Britain Smith
Man, those Plywood wheels look fantastic!
Nice work man. You made the right choice in fixing the positioning and keeping the S2000 geometry.
Gonna need your mad fab skillz later this week to mock-up my thottle cable bracket/conversion on my car.
-Britain
Old 07-07-2009, 05:43 PM   #187
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Bad azzzzzzzzzzzzzzzzzzzzzz
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-07-2009, 10:57 PM   #188
Jvsapp
Jvsapp's Avatar
awesome work FF keep it up
Jvsapp is offline   Reply With Quote
Old 07-07-2009, 11:11 PM   #189
ERASER5
ERASER5's Avatar
Of course they still make those wheels. They are at Lowe's, Menard's, or any other lumber yard!
Or did you buy Kevin's?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-08-2009, 12:16 AM   #190
Frizzle Fry
Those are the new MDF series that you can't get just anywhere
Old 07-08-2009, 02:15 AM   #191
Frizzle Fry
How 'bout two updates in one day to make up for lost time
Here's the notch dressed up and ready for a night on the town:
Reworked inner fender next to the notch cleaned up (was split/torn before):
Now is where some more fun begins. I had been on the fence about making more room up front to accommodate the ride height/stance I have planned. This pics shows about ride height for the front (maybe a little lower )
Well, there wasn't much room left in the wheel housing at that height-maybe just over and inch.
Without knowing how compliant the S2000 suspension will be and therefore how much travel I'll need I decided better safe than sorry...
Old 07-08-2009, 02:28 AM   #192
Frizzle Fry
I gain over 1.5" by sectioning/stretching the inner fender. This is some of the removed area (over 1.5" including the two 1/16" slices):
Prep'ing for welding, the angle grinder/wire-wheel got away from me and took a little bite
Here's the tire bottomed out at full tuck. Obviously it won't ride this low but it's nice to know I have the room:
Diggin this
Old 07-08-2009, 07:07 AM   #193
GRIMSS
GRIMSS's Avatar
You've been busy, looking good.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 07-08-2009, 07:23 AM   #194
OLDIRON69
Now you have me looking for a Sunbeam..course I couldn't do the swap!
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 07-08-2009, 08:57 AM   #195
6772owner
Gearhead
6772owner's Avatar
Ouch sorry about the wire wheel rash, those things get crazy sometimes, build is looking amazing as usual!
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 07-08-2009, 09:56 AM   #196
joe231
joe231's Avatar
Mike,
you never fail to impress me
you need to add a PhD to your sig.....how about MwD (Doctor of Metalwork)?
CHEVY ONLY
Old 07-08-2009, 10:07 AM   #197
ERASER5
ERASER5's Avatar
So, pain hurts, but did the chick dig it? Ya gotta get some sympathy somewhere. Now, back to work!
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 07-08-2009, 10:13 AM   #198
Britain Smith
Awesome...that will provide good clearance when were drifting!
Looks like you got branded from the grinder possi. Here is mine from a couple of years ago...I still have a scar.
-Britain
Old 07-08-2009, 10:36 AM   #199
BlueJeep
BlueJeep's Avatar
Are you using the orbital sander to finish the metal?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 07-08-2009, 11:12 AM   #200
Frizzle Fry
Thanks man
You'd be more likely to find one under the Hillman Marque (Hillman Minx).
Yes they do. It caught an edge and jumped out of my hand. That's when the trigger lock is not a good thing...
Originally Posted by joe231 View Post
Mike,
Hah, working on a masters maybe Lots more to learn.
She was all sympathetic when the bandage was on, but when I took it off she said "that's all? I was expecting some chunks missing..."
-Britain
This is def not my first encounter with a rouge grinder and I'm sure it's not the last... Hopefully while drifting the car will stay fairly flat, but now we can do it from less altitude.
Yes I do. As a last step to get a nice uniform surface that's ready for paint. You can see that the sander won't reach all areas. For that I'll hit it by hand.
