Old 02-20-2016, 10:28 AM   #176
racecougar
racecougar's Avatar
Re: My caster mod (with pictures)
I left the saddles in place with the stock rivets as well. Not certain why the OP removed them only to reinstall with socketheads.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 02-20-2016, 11:29 AM   #177
The Rocknrod
Moderator
The Rocknrod's Avatar
I installed socket heads. One of the reasons is someone previously mounted the lower a-arms and didn't ensure they were seated properly, the locating pins were crushed some and I wanted to ensure they worked properly.
Old 02-20-2016, 11:34 AM   #178
chevyrestoguy
chevyrestoguy's Avatar
It wasn't really a requirement to knock out the rivets on the saddles. I just wanted maximum engagement on all four points. I machined the new spotfaces in the shafts .005" over the diameter of the Grade 8 socket heads, and the added height of the sockethead (versus the height of the rivet) makes for a positive interaction where the shaft locks in to the saddle. With the rivet, you're only engaged at the height of the outer lip. It'll work fine, because that's all the factory required, but I tend to overkill when it comes to suspensions.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 04-22-2016, 09:02 PM   #179
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Hey guys, I moved my LCA's ahead by 3/4". They were original steel bushing style shafts.
I got an alignment done today. The caster reading was 5.5 degrees. Just an FYI...
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 05-12-2016, 06:08 PM   #180
69gmcc10
69gmcc10's Avatar
Originally Posted by BMERDOC View Post
I have been thinking about elongating the upper cross shaft locating holes for finer adjustments, leaving the shims only for camber adjustments (1/8" of motion would equal .5 degrees of movement). I need to go back and look over your math and Scoti's alignment numbers.
I spoke with an old hot rodder/racer about this the other day about this and he said the uppers see so much force under breaking that it would probably shift. My uncle was a front end mechanic for chevy for 30 years. I told him what I was doing and the upper arm shaft idea and he suggested to fine tune the uppers he would unbolt the shaft from the studs and twist it. He said he used to do it all the time and each turn on the shaft is just under 1/4" forward or backwards off the top of his head.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 05-12-2016, 07:58 PM   #181
BMERDOC
BMERDOC's Avatar
Was he referring to twisting the upper shaft in the end caps? It would kinda make sense. While installing them you want the caps to go on equally and tighten them down from there. The only problem with this is that you wouldn't want to have the the shaft improperly engaged in one cap (front in this case). I will agree that it is worth a closer look. Im not so sure the shafts would shift if properly torqued but his idea is free and machining isn't. The front suspension on my truck is disassembled at the moment and I was just about to order new u-bolts to reassemble it so it I do think its a good time to investigate the possibilities. Its been a while since I've even thought about this whole thing.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 05-13-2016, 02:56 PM   #182
69gmcc10
69gmcc10's Avatar
Yes, twisting them in the caps...After I talked to him and was thinking about this, I also was concerned about moving the shaft far enough forward that it would bottom out in the front cup during suspension travel and cause issues. Just need to pay attention.
Old 05-13-2016, 04:24 PM   #183
crakarjax
crakarjax's Avatar
I think you'd have to twist one cap one way, the other cap the opposite -- otherwise you'd draw the caps in or move them out equally netting no caster gain. I'd be concerned about removing bearing surface on the one end of the shaft though, causing premature wearout since the caps are the actual friction surfaces.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 05-14-2016, 11:42 AM   #184
69gmcc10
69gmcc10's Avatar
You are correct in tightening one and loosening the other when it comes to the caps, but since both ends are right hand turn when you twist a shaft already installed the shaft moves forward and backwards. It won't squeeze or push the ears of the control arm at all.
Old 10-11-2016, 03:33 PM   #185
ranger2339
ranger2339's Avatar
Thumbs up Re: My caster mod (with pictures)
Ended up doing my arms, got the idea from Rob but decided to take a different approach I saw another member here took. I am on a tight budget so went this way, might brace them up a bit, we will see. I'm not the best fabricator, but I'm happy with them. Moved them over .75
Thanks to everybody.
ranger2339 is offline   Reply With Quote
Old 10-11-2016, 05:38 PM   #186
SCOTI
SCOTI's Avatar
Definitely..... plate & brace them.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-12-2016, 12:45 AM   #187
ranger2339
ranger2339's Avatar
Anybody have any ideas on how to do this with this set up?
Old 10-12-2016, 08:19 AM   #188
jjzepplin
jjzepplin's Avatar
I am sorry? WHY did you do this? I would not run those even with bracing and plating. Seems to have defeated the purpose and created a dangerous situation. Please explain.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-12-2016, 08:46 AM   #189
ranger2339
ranger2339's Avatar
Lol what purpose was defeated here? Little dramatic aye?
Old 10-12-2016, 09:55 AM   #190
SCOTI
SCOTI's Avatar
A piece of 3/16 plate across the bottom & on the sides (F&R).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-12-2016, 09:57 AM   #191
ranger2339
ranger2339's Avatar
Thanks. I have two more sets of arms so if these don't work
I'll try a different method.
Old 10-12-2016, 11:24 AM   #192
gringoloco
A guy with a truck
gringoloco's Avatar
Definitely plate top/bottom. Don't want that breaking off while driving!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-12-2016, 11:33 AM   #193
solidaxel
solidaxel's Avatar
Have you installed "skid plates" on the lower parts of your front end
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-12-2016, 11:39 AM   #194
ranger2339
ranger2339's Avatar
Ok bad idea, I get it. As soon as I did it I wasn't very confident, not sure if bracing will be enough??
Ill just do the way Rob did it with moving the BJ hole over with another set of arms I have.
Old 10-12-2016, 11:51 AM   #195
solidaxel
solidaxel's Avatar
I have had a experience with skid plates and lower suspension parts!
LS 3 4L70E
Old 10-12-2016, 12:15 PM   #196
jjzepplin
jjzepplin's Avatar
OH my! Are you ok? Do tell the story.
Old 10-12-2016, 12:25 PM   #197
solidaxel
solidaxel's Avatar
Long story !
Very interesting ride, until we got the truck off the road!
All fixed and gaining more confidence every day
LS 3 4L70E
Old 10-12-2016, 12:31 PM   #198
jjzepplin
jjzepplin's Avatar
Just trying to save a life here. Sorry I was dramatic. I meant no harm. Just doesn't look safe. If you moved the arm forward by the mod method, and then moved the ball joint mounting then didn't you basically just move the place where the spring sits? I just don't follow what you've done here. I am a little slow today. Again, I mean no harm just trying to figure this out. As I understand the MOD it moves the whole arm and that is what it is intended to do. Or did you move the ball joint in the same direction creating even more caster?
Old 10-12-2016, 12:58 PM   #199
crakarjax
crakarjax's Avatar
I don't see any problem with modding the arms the way ranger has, as long as he ties in the sides and welds a plate across the bottom. He's just moving the balljoint over to improve caster while leaving the spring pocket in the correctly aligned location.
@solidaxel, how did you manage to drag your lower balljoint on the ground? Did your wheel fall off?
Old 10-12-2016, 01:24 PM   #200
tinydb84
tinydb84's Avatar
I did my first set of arms in a similar way.
The plating is more important on the sides than top and bottom. You lost the strength of the arms when you cut through the sides. Think of bending a ruler when it is flat vs standing on its side.
David
Instagram: myfabguy
