04-30-2019, 01:53 AM | #176 |
I know the pieces fit
Re: Naught's 82 2wd K5 Blazer
Removing the B pillar seam between the cab and bed rails looks really good.
04-30-2019, 11:14 AM | #177 |
Holy crap man! I'd love to do a full restoration like that on my 1982 K10... but I don't have a shop and they are crazy expensive near me to rent.
Maybe someday.
1979 Pontiac LeMans 231/Th350 1982 Chevrolet Silverado K10 6.2 Diesel/700r4 1984 Buick Regal Limited Sedan 4.3 V6 Diesel/200r4 (Hens teeth rare) 1991 Chevrolet Silverado K2500 5.7/700r4 1999 Chevrolet Base LS K2500 6.5TD/4L80e |
05-02-2019, 11:15 AM | #178 |
Loving the color.
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
07-19-2019, 04:23 PM | #179 |
Added some shine to it!!
07-19-2019, 06:55 PM | #180 |
PoP!
07-20-2019, 07:46 AM | #181 |
Just read your build thread again, awesome work!
Rick |
09-30-2019, 09:33 AM | #182 |
Thanks!
11-26-2019, 04:53 PM | #183 |
Body is back on frame!!
11-26-2019, 05:03 PM | #184 |
Trying to figure out wheel offset.
11-26-2019, 06:37 PM | #185 |
01-03-2020, 04:14 PM | #186 |
Trying to get interior and wiring together.
01-03-2020, 04:18 PM | #187 |
Also have received my rear wheels!
01-03-2020, 05:26 PM | #188 |
Man that looks good!
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
01-03-2020, 05:53 PM | #189 |
01-03-2020, 06:43 PM | #190 |
67-72 parts collector,…
Wheels look good,... but look really close to rubbing.
Did they arrive with the backspace that you ordered?
01-04-2020, 11:06 AM | #191 |
01-04-2020, 11:07 AM | #192 |
01-04-2020, 11:07 AM | #193 |
01-08-2020, 10:57 AM | #194 |
chevy truck fan
Naught,
terrific build! I like the detail. I am in the process of building up a Daily driving 1986 swb. I have a few questions for you if you don't mind. I was wondering if you would share (remember) what brake prop valve you are using?was it a "direct replacement"? also I would like to know what radiator you decided on? Finally I am wondering if you had to modify the frame any for your exhaust? I am using the DD mounts on my build. thanks for any input you might provide. I like the color choice too!!! thanks!! Rodstored-72 |
01-08-2020, 03:20 PM | #195 | |
I was wondering if you would share (remember) what brake prop valve you are using?was it a "direct replacement"? I ordered the complete front & rear brake kit from CPP and it came with the proportioning valve with it. It is a OEM style proportioning valve but it is for disc brakes on front and back (disc/disc). I would like to know what radiator you decided on? Griffin Radiator Combo Kit (Radiator & Fans) I am wondering if you had to modify the frame any for your exhaust? Yes we did. Look on pages 2 & 3 on this build for pics. I couldn’t get the exhaust out the back with the trailing arm coilover suspension plus the fuel tank so we boxed in the frame and went threw it to get on the outside to go out the back. I am using the DD mounts on my build. thanks for any input you might provide. I also used DD motor mounts |
01-09-2020, 10:32 AM | #196 |
chevy truck fan
Naught,
thank you for the replies, and it does help. I mainly wanted to verify that I was not the only one that had to modify the frame for this type of install. I believe "glock" had to as well back when he did his, he used custom mounts-reason for verification. I ordered a "std" brake prop valve (disk/drum) and wanted to see if it was similar to yours. I am still not sure what to do about radiator.... here in the desert the heat is a huge concern. I believe these new motors require more cooling than a regular SBC. I am looking at a few from Summit that are "designed" for LS conversions, so again just wanted to check with a few knowledgable members here. thanks again & best of luck with the build finish!! |
01-09-2020, 02:59 PM | #197 | |
01-16-2020, 11:24 AM | #198 |
Formerly- 1972SuperCheyenne
Wow! Those wheels look great under there! Amazing body and paint work as well!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
01-25-2020, 11:03 AM | #199 |
Looks great
02-03-2020, 10:53 AM | #200 |
